Question about Memorex MVD2042 DVD Player
No disc after putting my cd in my dvd it says loading on the screen for about 1 min. then it changes and says no disc. is there a quicck fix?
    Sergeant:
    Champion:
  • 317 Answers
It could be that the firmware for the DVD drive is out dated, especially if you purchased it before 2003, and some of the new DVD movies have a different encoding then the old ones, hence why it thinks there is no disk, so my only suggestion is see if yopu can get updated firmware. Also try cleaning the lens with one of those laser lens cleaning discs, I have heard stories that that has fixed it a couple of times.
Posted on Aug 22, 2008
My computer will turn but it only shows a blank screen with a flashing dash in the top left hand corner. Can you help?
Insert your system recovery disc to repair your startup.
1. Change your Bios to boot from disc:
When your computer powers on, hit F2 (on some computers, F8 on others). Use your arrow keys and move to the right to your BOOT option. Hit the down arrow until you select your CD/DVD drive. Look at the bottom of your screen, and it should say to change the option hit F7 or F8. Use the specified keys, and move your CD/DVD drive above your hard-drive. Save your settings.
2. Boot from your disc. Insert your system recovery disc and restart your computer. Let the recovery disc load. If the option comes up to hit any button to boot from CD/DVD, then hit any button. Once it loads, it should come to a spot where it wants your language, then select the option "Startup Repair". Click on it, and let it repair the startup. Restart your computer, and hopefully it will boot from your hard-drive correctly.
Hope this works.
Chadlnrd
P.S. If it continues to boot from your recovery disc, then using the same method in step 1, go to your bios, and move your CD/DVD drive below your hard-drive.
Feb 28, 2011 | Computers & Internet
When I put in a dvd the screen says loading then says no dvd
normaly in this condition the laser pick up is defactive first you clean the pick up with cd cleaner if problum solved ok other wise you have to change the pick up from any otherized service shop
Dec 02, 2009 | GPX PD808B Portable DVD Player with Screen
Dvd player wont load disc
try cleaning the lens first.then load a disk.try a different disc like VCD, CD etc.if only the DVD's are not read, the lens and the mainboard itself is faulty.but, if after cleaning it, it goes ok ,then its just dirty.
May 28, 2009 | Sony RDR-VX530 DVD Recorder/VCR
Coby DVD Player wont play
try running an optical disk cleaner it worked for me but I have to clean often.........a cheap fix if it works.
Jan 26, 2009 | Televison & Video
Wrong disc problem
This is a known problem - there is no fix - if you call coby customer service they will tell you to try a dvd lens cleaner -this will not fix the problem. Best advise - throw it away.
Feb 26, 2008 | Coby DVD-224 DVD Player
Screen reads NO DISC
I had the same problem but I solved buying "Laser Lens Cleaner " Philips Magnavox after 3 attempts the DVD starts to work fine again. First only 3 min, then 10 min and now the entire CD cleaner and after I left the CD cleaner for 15 min I tried to play the DVD and WORKS!!! perfect!!!
Nov 08, 2007 | Audiovox D1420 Portable DVD Player
Dvd probelems with samsung DvD-611
i put a dvd or a cd in the dvd player it say," loading" THEN it says "No Disc" BUT i known the cd or dvd dont be mess up so how can i fix this problem....Kindly reply me
Oct 30, 2007 | Samsung DVD-611 DVD Player
Loading...loading...loading...(10 minutes later)...no disc
I just fixed this problem. This will not fix any underlying problem, but it will get you up and running again. THIS MIGHT SCRATCH THE CD.
Unplug the unit. Remove the top cover. There are screws on the side and the back. Once you do you will see the dvd is not in correct position. Slide it around till you feel it drop into place. YES, YOU MAY END UP SCRATCHING THE CD. Plug the unit back in and it will eject.
For me the underlying problem is that the disc drawer closes while I am putting the cd in, causing it to not be seated properly. If anyone knows how to fix this .....
Apr 25, 2007 | Apex Digital AD-1225 DVD Player
Memorex MVD2042 DVD Player Logo
94 people viewed this question
Top Memorex Televison & Video Experts
 Grubhead
Grubhead
Are you a Memorex Televison and Video Expert? Answer questions, earn points and help others
