Question about Dell UltraSharp 1907FP 19" LCD Monitor
Dell 1907FPt picture appears for three seconds, then off, LED power remains
My Dell 1907FPt LCD was the victim of a power surge. Now the LED powers on and the picture appears for three seconds then disappears but the power LED remains green(not orange). I can repeat this every time I power it on and my ear to the back reveals a slight crackling sound before picture disappears. Is this something I can fix or do I need some professional help here? How does back get removed? I unscrewed the four visible retaining screws and gingerly tried to pry back off. Am I on the right track?
  • 4 more comments
  • Anonymous Aug 30, 2008
    We have the same problem - power on, screen comes up for a few seconds then goes black yet green On light stays lit. Can repeat by powering Off then back on. This was an expensive upgrade when I bought my system a few years back and I hate the thought of having to dispose of the monitor if there is a known fix.
  • SquidgyB Aug 31, 2008
    I've just picked up a 1907FPt for free, with the same problem... I've had a look inside; no dry joints or any obvious electrical damage to any of the components.
    I've read either here or on another forum that it's down to the inverter. I work in an IT helpdesk, and we use these monitors at work, so I'll have a chat with the hardware guys and see what their take is on the problem tomorrow... If I come up with a solution, I'll post it here.
    More than likely I'll have to order a new inverter, chances are I should be able to get one through work, but we'll see.
  • 7007 Sep 09, 2008
    We have the same three second blackout. We change computer to rule out any bad cards or time savers.
    No luck
  • spect8r Sep 19, 2008
    I too have the same problem. Comes on for about three seconds then goes off but by looking really close I can see the test screen floating around. The monitor is not hooked to the pc to check if it was the video card or the monitor. HELP!
  • rufus808 Dec 09, 2008
    same as every1. jut lookin' 4 a solution. i got mine off the side of the road :o)
  • up_grade1 Apr 01, 2009
    This is not a power surge problem, I have the same problem with a 1707Fpt three seconds and then it blanks out. I've checked the cold solder joints and retouched many of the shotty looking ones but to no avail. The caps all look good, it's possibly the IC's but I need someone who knows more than I do to have a look. I've got three of these monitors all with the same problem which means more will come. The inverter board is a cop out there are only two boards one is the video the other is everything else. So yes if you change everything else you're likely to find the problem.
I have the same problem. I talked to a few people and it is believed that the condition has been caused by a power surge.
My monitor is out of warranty, so I intend to open it up to check the fuse(s).
I will post result of that soon.
Posted on Sep 09, 2008
HOw to replace the power fuse in a OCOSMO LED TV
There is no replaceable fuse.
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
Take it to a repair shop.
Aug 27, 2014 | Televison & Video
NO POWER
Need to know how many times the led is blinking.
Re: tv kdl-55ex620 red light blink 8 times Do a Power Reset. 1. While the TV is off, unplug the power cord of the TV from the electrical outlet. 2. Let the TV remain without power for 60 seconds. 3. Plug the power cord back into the electrical outlet. (If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.) 4. Turn on the TV. 5. When the TV powers on and a picture is displayed, reset the TV to factory default settings.
  • If the Reset message does not appear and the TV turns off and on, begin again from step 5.
  • If the standby light begins blinking eight times, return to step 1.
6. After the Reset message appears, allow the TV to reset. Do not press any buttons on the remote control or on the TV and do not make any other adjustments for 1 minute. 7. Unplug the power cord from the electrical outlet. 8. Allow the TV to remain without power for 10 seconds. 9. Plug the power cord back into the electrical outlet. 10. Turn on the TV.
  • The initial setup screen displays if the above procedures were performed correctly.
11. Follow the on-screen instructions to complete the initial set up. 12. Perform a system software (firmware) update.
Sep 04, 2012 | Sony KDL55EX620 55 inch BRAVIA 1080p LED...
DELL 2208WFP LCD-Comes on normally, but almost immediately goes dark You can see something on the screen if you look closely. Turn it off and back on you see it then dark. any help?
I believe the power led button is still on while the screen goes dark, if yes, it means the picture board of your monitor is bad that is why it appears for a second and goes dark after that
Since the power led button is on, It means the picture board on your monitor is faulty that is why it appears for a second and goes dark.
The best thing for you to do now is to take the monitor to a local repairer or any service center within your vicinity to help with the replacement of the picture board because the fault is not something you can fix yourself in other to complicate issues.
Take care.
May 01, 2010 | Dell UltraSharp 2208WFP 22" Widescreen LCD...
When I press the power button, caps lock, scroll lock, num lock, power led and hard disk led blink in every 5 seconds
they continue to blink every 5 seconds until you turn it off? It should blink all lights upon powering on but then remain off,
Aug 13, 2009 | Dell Latitude C600 Lcd LCD Display
I have dell 1907fpt, the lcd screen powers up for just 2 or 3 seconds.
The backlight might be bad. As far as I know, there isn't a way to replace that, so you'll have to get a new monitor.
Jul 17, 2009 | Dell UltraSharp 1704FPT 17" Flat Panel LCD...
I turn on the T.V. and the blue light is blinking and the T.V. doesn't turn on
1. simultaneoulsy press and hold [menu] and [vol-] on TV side panel
2. press and release [power] on TV side panel
3. count to 5 and release[menu] and [vol-]
4. TV should have turned on
5. if not, unplug TV and press[power]
6. repeat from step 1 if the TV does not power on the 2nd time
Jul 10, 2009 | JVC LT42P789 42 in. LCD TV
Flat Panel Monitor: 1907FPt
Your monitor provides a self-test feature that allows you to check whether your monitor is functioning properly. If your monitor and computer are properly connected but the monitor screen remains dark, run the monitor self-test by performing the following steps:
  1. Turn off both your computer and monitor.
  2. Unplug the video cable from the back of the computer. To ensure proper Self-Test operation, remove both Digital (white connector) and the Analog(blue connector) cables from the back of computer.
  3. Turn on the monitor.
    The floating 'Dell Self-test Feature Check' dialog box should appear on-screen on a black background if the monitor cannot sense a video signal and is working correctly. While in self-test mode, the power LED remains green. Also, depending upon the selected input, one of the dialogs shown below will continuously scroll through the screen.
    1. This box also appears during normal system operation if the video cable becomes disconnected or damaged.
    2. Turn off your monitor and reconnect the video cable, then turn on both your computer and the monitor.
    If your monitor screen remains blank after you use the previous procedure, check your video controller and computer system; your monitor is functioning properly.
Jun 04, 2017 | Dell E173FPb 17" TFT LCD Monitor
Dell 1907FPT lcd monitor
Could be the power supply. Get one at www.partstore.com. I've had very good luck with them fixing various LCD monitors.
Jan 08, 2008 | Dell E173FP 17" LCD Monitor
Dell UltraSharp 1907FP 19" LCD Monitor Logo
532 people viewed this question
Alun Cox
