Question about Kenmore 16602 / 16604 / 16609 Built-in Dishwasher
Dishwasher how do i get dish soap out of the jet dry dispenser?
  • 38 Answers
One typically removes the jet dry reservoir from the door assembly and flushes the detergent out at the sink. Do take care to remove all the detergent though, residual detergent on wares which is ingested can cause diarreah (or worse).
I'm sorry, I don't have a diagram for this particular machine, but I believe it should be relatively simple to remove the inner-door lining to expose the reservoir.
Posted on Aug 22, 2008
How to Clear out dish soap from the jet dry resevoir?
Use a shop vac and suck it all out. Then, spray some Pam-type cooking spray grease into the jet dry reservoir and then, A) start a normal wash cycle and stop it a few minutes after it starts the spray action. Then, open the door and look for suds. B) If you see suds, spray them with Pam spray to knock them down and then C) cancel the wash to drain it out. Repeat ABC until all the suds are gone.
Then, whatever you do, DON'T put dish soap in the jet dry reservoir again!
Good luck
Oct 21, 2014 | KitchenAid Dishwashers
Where is the soap dispenser and jet dry dispenser on a Danby countertop dishwasher (with window)
I've got one of these countertop washers at home. The twist off dispenser you're talking about is for the jet dry (at least on mine) and there should be an area on the right side of the door for your soap. Hope this helps!
Jan 31, 2013 | Danby Dishwashers
GE Triton XL dishwasher, at first I had the left over powder soap issue until I dismantled the lower spray arm and cleaned the nets and removed the rusty particles in the hole in bottom of washer and also...
The scum, film and white residue problems have started since the reduction of phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
Dishwasher Residue and Film on Dishes
heatman101
Sep 25, 2010 | GE Tritonr XL GSD6260JCC Dishwasher
Glassware keeps coming out cloudy and spotty. Have tried various products. I use jet dry hanging basket style. Only get glassware spotless by running without soap and using vinegar. I would like to use...
Use the detergent meant for dish washers. Fill the rinse aid dispenser as per the user guide.If the water quality is hard. Use softeners. If dish washer salt adding provision is provide fill the dispenser.
May 19, 2010 | Dishwashers
Secondary soap dish won't open
i think you mean jet dry compartment.change dispenser. in some cases there is a kit but its better to replace new dispenser
Mar 02, 2010 | Dishwashers
Can I take the bottom part of the dishwaher apart
Mkae sure you are running kitchen hot water faucet before starting dish washer. If not you are getting mostly a cold water wash thru out the cycle. Also make sure the jet dry dispenser is full. Always use the liquid jet dry as the small cubes you can get do not work nearly as well.
Jan 31, 2010 | Kenmore 15762 Dishwasher
I mistakenly put dish detergent in the jet dry dispenser. Now I have soap bubbles everywhere. How do I get it out?
the jet dry is in your door, you need to open it and clean it. open the door screws take the front panel off and get the jet dry unit out ... give me your model number i see how to open the unit and i will tell you.
Jan 23, 2010 | Whirlpool Dishwashers
Soap dispenser does not open during wash
Well you can please follow the below steps -
1. Remove any dishes in the dishwasher. Unhook the dishwasher's dish trays or racks from their tracks, and set aside. Empty the soap dispenser if it contains unused soap that failed to dispense. Use a wet rag to wipe down the interior of the dishwasher, as well as the inside of the dispenser.
2. Close the dispenser, and shut the dishwasher door. Turn the dishwasher on to a manual setting, then stop it and open the appliance. Check to see if the dispenser is open. If it is, continue to Step 2. If the dispenser is closed, skip to Step 4.
3. Switch dishwasher soap. Some dishwasher dispensers have difficulty with dry or liquid dishwashing soap, depending on the make and model of your dishwasher. Incompatibilities typically result in the dispenser sticking shut, which explains why the dispenser opens when empty. Switch to liquid soap if you are using dry powder soap, or vice versa.
4. Check the dishwasher soap dispenser's spring. The spring is located behind the dispenser top's hinge. Consult your dishwasher's original manufacturer's manual or user guide to find a replacement spring. Pop the old spring out with a screwdriver, and replace with a new spring. This should resolve any issues related to the dispenser failing to open.
Please post comments if you need more help or information..........
Good Luck!!
Thanks
Jan 08, 2010 | Kenmore Dishwashers
Dirty dishes
plugged jets, possible
more likely it is leftover food reminance left in the pump area. and on certain dishwashers it could be a swollen check valve, not allowing the evacuation of the used dirty water.
does your soap dispenser open?
May 29, 2009 | Dishwashers
Dishsoap stays in soap dispenser
ok, either a spring, trigger prob, on the latch, or a electronic prob. ok so to see if the latch is ok (or not) look closely for soap residue and scum, that may be hindering the latch or spring under. use metho, and warm water to clean this part. secondly go down to a white goods repair place and take your electrical component, button, lights its all one unit, simple unscrew it, i do think you will need a set of torque screws for that tho... anyhow ask the guy to get you a new or second hand one and install it. the timer will run, and the clip will release. good luck!
Sep 25, 2007 | Whirlpool GU2400XTP Built-in Dishwasher
Kenmore 16602 / 16604 / 16609 Built-in Dishwasher Logo
113 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
vince
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
