The screen on my hp laptop is black when I turn it on and remains that way. What could be causing this and is it an easy and inexpensive fix?
  • blue7 Aug 21, 2008
    Thanks for the response...I will try that.
    President:
  • 2,961 Answers
If you shine a torch on the screen and are able to see your desktop, then the connection to the backlighting may be faulty, but this can be expensive, if its an old laptop, better buying a new one.
Posted on Aug 21, 2008
SOURCE:
Start up
First I will suggest you to Return BIOS settings to their default levels. An overclocked or misconfigured BIOS can cause all sorts of random issues, including black screen
After that restart your computer and then press and hold F8 keys until you get Advanced Options menu screen.Use the arrow key to highlight Safe Mode, and then press Enter, your computer will boot automatically to safe mode.
If you able to start in safe mode then update your graphic drivers from the manufacture site of your laptop
Let me know if it helps you.
Use system utility tool like RegInOut to remove unwanted files , fix registry and windows errors which causing black screen
Jul 04, 2013 | HP Pavilion DV2910US Laptop
Laptop hpg60 black screen and power button remains on
Dear gorgaman1
Open your lap again and ensure that you connected all parts correctly especially the screen chip.
Best Regards
Mazagange
Apr 10, 2013 | HP G60-535DX 15.6in Laptop PDC 2.1G3GB...
My hp laptop screen goes black after being on for a few minutes
The problem could be the backlight or its inverter is bad. IF picture remains but lights only go out. Also it is normal for the screen to go black if the laptop is not used.
If the picture itself remains on the display but it just goes dim, try turning up the brightness, if noting happens, most likely the backlight of the screen or its inverter is or has gone bad.
Would need to be confirmed in person.
If the picture does not remain on the screen and the laptop shuts off, your charger might not be working, and your battery is low.
Would need to be inspected in person.
Jun 11, 2012 | HP Computers & Internet
All the lights turn on on the hp pavilion dv1000, but the screen remains black. Almost as if there was no power going to the screen. I have tried reseating the RAM and the HD. Problem still remains. ...
Hook a external monitor to the video output on the back of the laptop, if okay! there is a LCD problem with the laptop screen, causes! bad inverter board, or back light. If both show black! causes are Video Graphics Card that is part of the motherboard.
Jan 10, 2011 | HP Pavilion dv1000 Notebook
HP tx2000 - black screen.
Hi
The problem you are experiencing is related to the screen of your Hp.
All you need to do is to is to get to a computer store and get your screen replaced.
You can not fix a damaged screen.
GOOD LUCK
Jun 17, 2010 | HP Pavilion TX2000Z Notebook
When go to power on all the lights turn on but nothing on screen. power light and hd light stay on consistently no blink to hd light.
If the laptop appears to boot up and the LCD screen remains black the the fault is most likely a back-light problem and is caused by either a faulty inverter or a faulty CCFL lamp. Please click on this link and follow my instructions to determine the fault and possible fix :-
http://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen
Mar 24, 2010 | HP Pavilion dv8000t Notebook
My HP Pavilion dv2000 turns on, but screen is black
If the laptop appears to boot up but the LCD screen is black, then the problem is a back-light fault caused by either a faulty inverter or a faulty CCFL lamp. Please click on this link and follow my instructions to determine the fault and fix :-
Mar 14, 2010 | HP Pavilion dv2000t 14.1" Notebook Laptop...
Screen is black
do you have any experience in opening notebook?. If not, don't take a risk, go to service center. It's LCD problem
May 24, 2009 | HP Compaq Pavilion dv5000z Notebook
The screen turns black
hi,
Please tell me your laptop model and brand.(I guess and Hp dv200/6000/9000\0 If i am correct then you must replace your Mobo.\this is a heavy job if you dont have the experience or tools. \We can fix your mobo for around 89 usd.
10001 buckwood ave 79925 El Paso Tx.
Contac us if you are interested
Thanks, please leave feedback
Vcrtech
[email protected]
[email protected]
www.vcrtech.com
Apr 29, 2009 | Computers & Internet
Compaq presario v3000 (v3322tu) turns on but appears dead
According to your question ,there is a problem with RAM of laptop ,bring it out again install it properly.
if it not work you to replace it with new one.
Apr 06, 2009 | HP Pavilion dv6000z Notebook
Open Questions:
avast tech support pHoNe {@}{+1888-499-552o] nUmBeR AB USA avast TECH SUPPORT Numberavast tech support pHoNe {@}{+1888-499-552o] nUmBeR AB USA avast TECH SUPPORT Numberavast tech support pHoNe {@}{+1888-499-552o] nUmBeR AB USA avast TECH SUPPORT Numberavast tech support pHoNe {@}{+1888-499-552o] nUmBeR AB USA avast TECH SUPPORT Numberavast tech support pHoNe {@}{+1888-499-552o] nUmBeR AB USA avast TECH SUPPORT Numberavast tech support pHoNe {@}{+1888-499-552o] nUmBeR AB USA avast TECH SUPPORT Numberavast tech support pHoNe {@}{+1888-499-552o] nUmBeR AB USA avast TECH SUPPORT Numberavast tech support pHoNe {@}{+1888-499-552o] nUmBeR AB USA avast TECH SUPPORT Numberavast tech support pHoNe {@}{+1888-499-552o] nUmBeR AB USA avast TECH SUPPORT Numberavast tech support pHoNe {@}{+1888-499-552o] nUmBeR AB USA avast TECH SUPPORT Numberavast tech support pHoNe {@}{+1888-499-552o] nUmBeR AB USA avast TECH SUPPORT Numberavast tech support pHoNe {@}{+1888-499-552o] nUmBeR AB USA avast TECH SUPPORT Numberavast tech support pHoNe {@}{+1888-499-552o] nUmBeR AB USA avast TECH SUPPORT Numberavast tech support pHoNe {@}{+1888-499-552o] nUmBeR AB USA avast TECH SUPPORT Numberavast tech support pHoNe {@}{+1888-499-552o] nUmBeR AB USA avast TECH SUPPORT Numberavast tech support pHoNe {@}{+1888-499-552o] nUmBeR AB USA avast TECH SUPPORT Numberavast tech support pHoNe {@}{+1888-499-552o] nUmBeR AB USA avast TECH SUPPORT Numberavast tech support pHoNe {@}{+1888-499-552o] nUmBeR AB USA avast TECH SUPPORT Numberavast tech support pHoNe {@}{+1888-499-552o] nUmBeR AB USA avast TECH SUPPORT Numberavast tech support pHoNe {@}{+1888-499-552o] nUmBeR AB USA avast TECH SUPPORT Numberavast tech support pHoNe {@}{+1888-499-552o] nUmBeR AB USA avast TECH SUPPORT Numberavast tech support pHoNe {@}{+1888-499-552o] nUmBeR AB USA avast TECH SUPPORT Numberavast tech support pHoNe {@}{+1888-499-552o] nUmBeR AB USA avast TECH SUPPORT Numberavast tech support pHoNe {@}{+1888-499-552o] nUmBeR AB USA avast TECH SUPPORT Numberavast tech support pHoNe {@}{+1888-499-552o] nUmBeR AB USA avast TECH SUPPORT Numberavast tech support pHoNe {@}{+1888-499-552o] nUmBeR AB USA avast TECH SUPPORT Numberavast tech support pHoNe {@}{+1888-499-552o] nUmBeR AB USA avast TECH SUPPORT Numberavast tech support pHoNe {@}{+1888-499-552o] nUmBeR AB USA avast TECH SUPPORT Numberavast tech support pHoNe {@}{+1888-499-552o] nUmBeR AB USA avast TECH SUPPORT Numberavast tech support pHoNe {@}{+1888-499-552o] nUmBeR AB USA avast TECH SUPPORT Numberavast tech support pHoNe {@}{+1888-499-552o] nUmBeR AB USA avast TECH SUPPORT Numberavast tech support pHoNe {@}{+1888-499-552o] nUmBeR AB USA avast TECH SUPPORT Numberavast tech support pHoNe {@}{+1888-499-552o] nUmBeR AB USA avast TECH SUPPORT Numberavast tech support pHoNe {@}{+1888-499-552o] nUmBeR AB USA avast TECH SUPPORT Numberavast tech support pHoNe {@}{+1888-499-552o] nUmBeR AB USA avast TECH SUPPORT Numberavast tech support pHoNe {@}{+1888-499-552o] nUmBeR AB USA avast TECH SUPPORT Numberavast tech support pHoNe {@}{+1888-499-552o] nUmBeR AB USA avast TECH SUPPORT Numberavast tech support pHoNe {@}{+1888-499-552o] nUmBeR AB USA avast TECH SUPPORT Numberavast tech support pHoNe {@}{+1888-499-552o] nUmBeR AB USA avast TECH SUPPORT Numberavast tech support pHoNe {@}{+1888-499-552o] nUmBeR AB USA avast TECH SUPPORT Numberavast tech support pHoNe {@}{+1888-499-552o] nUmBeR AB USA avast TECH SUPPORT Numberavast tech support pHoNe {@}{+1888-499-552o] nUmBeR AB USA avast TECH SUPPORT Numberavast tech support pHoNe {@}{+1888-499-552o] nUmBeR AB USA avast TECH SUPPORT Numberavast tech support pHoNe {@}{+1888-499-552o] nUmBeR AB USA avast TECH SUPPORT Numberavast tech support pHoNe {@}{+1888-499-552o] nUmBeR AB USA avast TECH SUPPORT Numberavast tech support pHoNe {@}{+1888-499-552o] nUmBeR AB USA avast TECH SUPPORT Numberavast tech support pHoNe {@}{+1888-499-552o] nUmBeR AB USA avast TECH SUPPORT Numberavast tech support pHoNe {@}{+1888-499-552o] nUmBeR AB USA avast TECH SUPPORT Numberavast tech support pHoNe {@}{+1888-499-552o] nUmBeR AB USA avast TECH SUPPORT Numberavast tech support pHoNe {@}{+1888-499-552o] nUmBeR AB USA avast TECH SUPPORT Numberavast tech support pHoNe {@}{+1888-499-552o] nUmBeR AB USA avast TECH SUPPORT Numberavast tech support pHoNe {@}{+1888-499-552o] nUmBeR AB USA avast TECH SUPPORT Numberavast tech support pHoNe {@}{+1888-499-552o] nUmBeR AB USA avast TECH SUPPORT Numberavast tech support pHoNe {@}{+1888-499-552o] nUmBeR AB USA avast TECH SUPPORT Numberavast tech support pHoNe {@}{+1888-499-552o] nUmBeR AB USA avast TECH SUPPORT Number
Oct 15, 2019 | Computers & Internet
Computers & Internet Logo
23 people viewed this question
Ekse
Alun Cox
