I cant figure out how to put my computer desk slide part together where da keyboard goes
  • 2,961 Answers
Assuming you have fitted the 2 piece sliders on the keyboard shelf, slide them out as far as they go to reveal screw holes, then screw them to the cupboard sides and the keybord will slide in and out
Posted on Aug 21, 2008
I cant figure out how to put the bobbin carriage back together on my brother vx1010
I think you're talking about the shuttle and race. It goes together like this:
Jan 21, 2014 | Brother Sewing Machines
How to take apart a metal tray slide? Like the one in desks?
Check if the keyboard tray slide rail has any screws...?
If not, i guess that means total disassembly of the desk and ofc...rebuilding back! :)
Nov 16, 2017 | Computers & Internet
How to change the outer seal near da tire on a 1985 chevy silveraldo rearend
you need to remove the cover in the middle of the rear axle rotate the drive shaft until you see a bolt with a 5/16 head on it slide out the pin that the bolt held in remove the c clip that holds the axle in slide out the axle and replace the seal you should do both sides while its apart then put it back together and fill threw the plug on the front side that uses a 3/8 drive
Mar 30, 2012 | Cars & Trucks
Trying to insert the bobben some peices fell out and cant figure out to put it back together
Go to and download a free manual. Then enlarge the diagrams, so that you can see how it goes together. Save the download to your computer, so you will always have a copy. Then go to page 33 and you will see how your bobbin case goes back together
Oct 30, 2010 | Singer 1120 Mechanical Sewing Machine
Button from laptop pulled off..need quick fix!!!!!!
The pieces snap into place if you place them correctly on the keyboard and press down until you hear them click together. You may need to pry one off to see the orientation of the white plastic piece that goes on first. Lay the piece like the one you just looked at and firmly press the key evenly on top of it until you hear the click sound. You may have to rock it a little to get it to fully engage. If it sticks down, take a paper click and gently pry it up and it should work fine.
Feb 08, 2010 | HP Compaq Evo N800v Notebook
Need help to put weight machine together
i need a diagram of a marcy by impex weight machine 150 lbs. i cant figure out how thw pulley system goes.
Aug 14, 2009 | Exercise & Fitness
Under desk sliding tray won't slide
It sounds like She closed it with it not quite aligned properly.
First try lift up on it a bit while pulling it out some, if it's jammed it may take quite a bit of force. If you have more than one person 1 might lift and the other pull.
If this is tried with no success, you may have to go underneath the desk with a screwdriver and remove one of the sliderails in order to dislodge it. Once loose seperate the sliderails from the mounts and then reattach the mount to the desk. Then insert the rollers into the mount (Holding tray at a 45 deg angle.) Once the rollers are in tilt the tray down and push the tray in to seat it. It should click into place when it catches. It should now be able to slide as normal.
Hope this helps
Try changing with a new set of batteries. also try to reset the connection of the wireless mouse and keyboard. you can locate a connect button on both the reciever and wireless keyboard. press both of them together and release them. this would reset the connection. try doing the same for reciever and wireless mouse connect buttons. this should work. also check for any possible alignment issues.
Jan 15, 2008 | Computers & Internet
Computers & Internet Logo
David Payne
David Payne
