Question about Mitsubishi VS-60719 60" Rear Projection Television
Mitsubishi VS-60719 60in. Have horizonial lines that flicker and a problem with the convergence
I have a Mitsubishi VS-60719 60 in projection TV. It was working fine and then all of a sudden it turned off and then when we turned it back on the blue convergence has a bow to it bowing up in the center of the screen and is offset from the rest of the screen. I have changed the convergence module and didn't help it. there is 2 white lines on each side of the glass part of the 3 color tubes, one on the front and one on the back on the red and green they are both while but on the blue the front one is yellow and the back is blue. any ideas I would like to get it fixed because it was a great TV till this happened.
  • 42 more comments
  • fredcrabtree Aug 22, 2008
    I've tried that before and it wouldn't work
    Fuses are fine
    Mirrors are fine
    I have a manual for it what I'm trying to figure out the most is why they are small black lines that flicker and also why the lines on the glass part of the blue tube is blue and yellow and the other 2 tubes are white
    No speakers on the TV
    can you buy one of them boards
  • fredcrabtree Aug 23, 2008
    Its the old board but I have changed the IC's and the resistors and checked the fuses they are showing good I had 2 resistors that was bad.
    theres nothing that comes up when I held the input button and menu button but when I first plug it in the green power light flashes 3 times real fast.
    the blue is the only thing that is offset about an inch in the middle and the 3 or 4 inches on each side and its the only color that is bowed the picture its self is not and when the lines flicker on the screen the whole picture flickers
    the STK IC's that your talkin about is the black one on the huge heat sink or is it somewhere else. and the fuses that I checked was on the board on the right side there was 2 almost where the boards come togather
    ok I got it to give me a code the code is 12
    No no one had adjusted anything it was working fine and then went off and then when we turned it back on it was messed up
    yes that is the one that I replaced but i'm wondering if there is a chance that I got a bad one when I ordered it they sent me 2 of them I'm wondering if I should take it all back apart and put the other one in it or it its something else.
    yeah I got it to work it gave me a 1-2 code
    Does the strips in the glass tubes mean anything with the 2 in the red tube and the 2 in the green tube being white and the 2 in the blue tube one was yellow and one blue. I'm just wanting to make sure that the tube aint bad
    yeah I had and I even had my father-inlaw double check it cause he as done alot of had soldering
    I'll see if I can find anything on that website
    yeah its the factory board from the TV. and the code the TV gave was a 1-2 with the power light
    I will I was hopeing to be able to fix it cheaper than to buy a new one
    thanks
    I will try this and let you know thanks alot
    I'll try it
    i'll try it and let you know
    I never replaced the board its the same one I just changed the STK and 2 of the resistors
    yeah I checked the other ones on the board and no I never got any reading out of the old ones
    the 2 I replaced was 2W 6.8oms
    I'll look that site and see if it helps any thanks
    my STK IC's number was STK393-110
    i'll check it out
    I order one and they sent me 2 of them and I'm wondering if it would be worth taking it back apart and putting in the other new one.
    I will
    I'm going to retry the stk again by putting a new one on it and see if that will fix it
    what do you mean this is a problem of wheel
    whats the chances of the tubes going bad
    what is the problem of the wheel that you are talkin about
    there is only one STK on my board i'm going to try it again and if it still dont work then i'm going to get a tv repairman to come look at it or see if he can try the STK again incase i'm not getting it soldered good enough but I've never had that problem before when it came to soldering
    there is 3 tubes in there one has a red lens on it one has a green lens on it and one has a blue lens on it
    no not yet i'm going to try the STK again
    ok but if the lamp is gone it wouldnt light up would it cause they all light up the same
    i will I"m going to replace it tonite when my father-inlaw gets home to help and i'll post on here if it fixes it
    I've got one that I downloaded
  • fredcrabtree Aug 24, 2008
    replaced the STK with another new one and now my picture is got an hourglass look to it Can you but a new board for them or do they no longer make them
    service manuals
    Thanks you to all of you who have tried to help me fix this TV but I have decided to throw in the towel on it and just go buy a new one.
  • 1,879 Answers
We appreciate your patience - good luck on your new TV
Posted on Aug 25, 2008
  • 83 Answers
The Signal Is Very Bad
Posted on Aug 24, 2008
  • Mitsubishi Master
  • 13,433 Answers
You can purchase a service manual from this website
http://www.asm-service-manual.com/List/Mitsubishi%20List%20ASM.htm
  • 813 Answers
U have to with prodessionl service man
    Genius:
  • 1,665 Answers
This is the convergence circuit gone bad. but if you want to do this you must have great soldering skills.
This is a hard repair.
( if you call a shop a cost will range around 400.00 for the repair)
    Scholar:
  • 133 Answers
U have to go with a professinol service man
    Genius:
  • 1,011 Answers
Sir,
Try to reset the convergence and check the calibration settings.
Calibration Settings:
  • Contrast: 20
  • Brightness: 30
  • Color: 36
  • Tint: 34
  • Sharpness: 24
  • Color Temperature: Low
  • Picture Mode: Natural
  • Video Noise Reduction: Off
  • Sharp Edge: Off
  • Deep Field: On
Perfect Color
  • Magenta: 32
  • Red: 24
  • Yellow: 31
  • Green: 46
  • Cyan: 32
  • Blue: 32
Perfect Tint
  • Magenta: 47
  • Red: 29
  • Yellow: 29
  • Green: 55
  • Cyan: 46
  • Blue: 28
good luck
  • 928 Answers
You can go to www.shopjimmy.com and you can buy the part that you need. They specialize in hard to find parts. Although they are used parts you cant buy them new any longer
    Scholar:
  • 163 Answers
Rare but replaced convergence module may be also faulty.check what is the difference with new or old module on.
Posted on Aug 23, 2008
  • 6,487 Answers
If that's really the one that is causing the problem replacing it should fix this concern now..
Feel free to contact us back for further help..
Good luck........
  • 2 more comments
  • Mark Gil
    Mark Gil Aug 23, 2008
    Go ahead and replace the STk so we can all see if that really fix the problem if not we need to look for another part here that is causing this and hopefully that time your concern will be resolve..
  • Mark Gil
    OK keep us posted if it fix the problem or not
    Thank you...
  • Mark Gil
    Mark Gil Aug 24, 2008
    I believe they are not making a board for this unit, but you can call Mitsubishi and better ask that to them if they still make a board for this..
  • Mark Gil
    Sorry for that if we cannot fix it now. but getting a new one I think will be the best thing that you can do now...
    Master:
  • 521 Answers
Stk---stk---stk--- thats it.check the board properly.and get it soldering properly.and check the continuity is complete after fitting stk on the board.thanks
  • tech expert12 Aug 23, 2008
    did any of the solutions solved ur problem yet
  • tech expert12 Aug 25, 2008
    taking it to the repair center can save lot of your money.as they have the possible parts available with them.hope that works.give the last try.please rate the solution.thanks.bye.
    Genius:
  • 1,269 Answers
What was the value of resistors have you replaced? What about try 5 ohms higher. e.g. if it was 150 ohms, try 155 ohms. Double check again any shorted pins near that IC that was replaced
    Genius:
  • 1,011 Answers
Did you try after changing the resistor near the STK in convergance portion.
if you replaced the board then is it the compatible one with the right STK ic..
regards,
    Master:
  • 505 Answers
Http://www.retrevo.com/support/Mitsubishi-VS-60719-TVs-manual/id/276bh840/t/2/
This Site Mite Be More Help
  • Hellow removed all speakers and magnetic things away from tv then unplug tv by power point for 30 minutes they are 30 min turn back on
  • 435 Answers
You have tried plenty of steps to resolve. Now try this link for more troubleshooting steps: :-)
http://www.retrevo.com/support/Mitsubishi-VS-60719-TVs-manual/id/276bh840/t/2/
This has a very exhaustive list of problems.
Thanks.
  • 69 Answers
Its the board on the television. You also said its an old board. a 1-2 code would stay in tact if it was a bad board. it's hard to tell you this, but either get a new board, or the television is shot :[
please think before you rate.
  • 157 Answers
Did someone play with the PAL NTSC settings of the tv
Try and retsore factory defaults and see what happens
Or maybe its an issue with the voltage regualtor
Cheers
JigSaw
  • John Smith
    John Smith Aug 25, 2008
    i reckon you should just go and buy a new one
  • Kurt Coyle
    Kurt Coyle Nov 13, 2013
    Jigsaw is a NERD with no help skills!
  • 4,234 Answers
FIrst of all, lets get back to the original problem... If the entire convergence board is replaced, a complete convergence/alignment procedure must be done. If you still have the original board, replace the ICs on that board along with any low valued resistors or fuses. That should return the set to the old convergence/alignment values. Once this is done, please let me know if you still see the lines.
Thanks,
Dan
  • Kurt Coyle
    NOW, this is what I am talking about for help Jigsaw, take note "on how it works"
    Genius:
  • 2,920 Answers
Your convergence board is out
Posted on Aug 22, 2008
    Sergeant:
    Champion:
  • 298 Answers
If you have surround sound insure the center channel speaker is not on the top of the tv, or any other speakers are around it that will throw off the convergence.
    Master:
  • 623 Answers
Get manual here
  • 2,336 Answers
If you've replaced the entire convergence module and still does not work the way it should, I would say that there could be a fuse(s) in the -24VDC and +24VDC line that were probably blown when the other module failed.
These fuses are not located in the convergence module but in the power supply.
Let me know if you need further assistance.
  • 2 more comments
  • Jaime Hernandez Aug 23, 2008
    Have you verify the voltages on the STK ICs?
    You should be getting the -24VDC and +24VDC to the ICs.
    The STK393-110 that is the one that controls and adjust the convergence settings.
    Did you replace that IC?
    I just need to ask the question. Have you done any hand soldering before replacing the STK IC?
  • Jaime Hernandez Aug 24, 2008
    I will send you the servive manual for you to check where all the connections go from the convergence board.
    I would suggest to check all the voltages as per the schematics.
  • Mitsubishi Master
  • 19,396 Answers
Try unplugging power cable for ten minutes.
  • 15 more comments
  • Ginko
    Ginko Aug 22, 2008
    Check also that the mirrors in the light tunnel are fine, and that the bow it is not a shadow from a misplaced mirror.
  • Ginko
    Ginko Aug 22, 2008
    Also bad color wheel can give you similar problems.
  • Ginko
    Ginko Aug 23, 2008
    Ok, keep us updated if you need any more help.
  • Ginko
    Ginko Aug 23, 2008
  • Ginko
    Ginko Aug 23, 2008
  • Ginko
    Ginko Aug 23, 2008
    here you find
    Details and datasheet on part: STK393-110
    here you can buy part
    STK393-110
  • Ginko
    Ginko Aug 23, 2008
    Let us know if you need further help.
  • Ginko
    Ginko Aug 23, 2008
    I dont this a problem of wheel.
  • Ginko
    Ginko Aug 23, 2008
    If it is a projection tv does not have tube , it have a lamp projecting a light beam inside light tunnel on color wheel, and then on display.
  • Ginko
    Ginko Aug 23, 2008
    See here:
    How To Replace the Color WheelUsually you know that you have to replace color wheel when colors get very bright and you get color spots, particularly at screen corners.
    Yours does not look like a color wheel problem.
    It is convergence.
  • Ginko
    Ginko Aug 23, 2008
    They are not tubes they are lamps. When one is gone you replace the bulb
  • Ginko
    Ginko Aug 23, 2008
    You do not seem to have understood how your tv works, you should call a tech, as you are risking to destroy your tv set.
    Tip: not all information you receive is correct, sometimes experts can get confused by the fact that they cannot inspect you TV directly. Get the service manual for your tv.
  • Ginko
    Ginko Aug 23, 2008
    If lamps light up they are ok, If you get bows on side of the screen then one of ICs can be bad, or more likely you have to perform a setup procedure.
    If you do not perform convergence setup procedure you won't have TV fixed even after replacing ICs.
    You find out if convergence ICs have blown or are good by testing the pico fuses at the base of the ICs.
  • Ginko
    Ginko Aug 23, 2008
    You need to buy the service manual for your model, there you will find convergence setup procedure that must be performed after replacing convergence ICs and whenever there is a problem.
    You buy service manual from any of the TV part sellers already posted.
  • Ginko
    Ginko Aug 23, 2008
    If you keep refusing all solution you will only get generic comments.
  • Ginko
    Ginko Aug 23, 2008
    What did you download?
  • Ginko
    Ginko Aug 24, 2008
    You can buy service manual here for $5.
    Mitsubishi Service Manual and Schematic
    If you keep refusing all solutions nobody will be able to give you decent support.
Screen resembles 3D look with predoment red and green to images - did the blue blub burn out and need to be replaced?
The tv have a problems known as a convergence problems,it dead.Tv have colors lines R,G,B mis alignments,have colors shadows pictures or 3D pictures look alike?The tv convergence board have dead 2 STK convergence ICS and some or all it resistors too.By replacing all these parts on the tv convergence board to fixed it to solved the tv pictures convergence problems.The shop,will cost u like $300-350 for parts and labors.
Feb 05, 2011 | Mitsubishi VS-60803 60" Rear Projection...
My picture is almost 3-D like and is red, green and yellow.
The tv have a problems known as a convergence problems,it dead.The tv colors lines R,G,B mis alignment,have colors shadows pictures or 3D pictures look alike.The tv convergence board the 2 STK convergence ICS and some or all it resistors are dead.These parts on the tv convergence board,must be replaced to solved the tv picture convergence problems.The shop,will cost u like $300-350 for parts and labors.
Oct 28, 2010 | Mitsubishi VS-60609 60" Rear Projection...
VS-60719 60 in. Rear Projection Television: Blue Convergence is off, can't solve by using the ...
When the convergence problems happen.100% ur tv convergence board the 2 STK convergence ICS,and some or all it resistors are dead.These parts must be change,to be solved convergence problerms.Tries Websites like TvrepairWorld.com,Tvrepairkits.com to buy a convergence kit to repair it ur self.Only if u know how to do soldering,and have soldering equipments and solders.The shop will cost u $300-350 for the parts and labors.
May 18, 2010 | Mitsubishi VS-60719 60" Rear Projection...
Mitsubishi VS-55609 distorted Picture Flickers
This is a convergence problem and not really a DIY Many amateurs try it to save money but end up spending more on it than a professional. There are dozens on here that managed to fix it for a day or two only to have it fail again.
cost of fix about $300.
Please rate my help++++Thanks for using FIXYA
Mar 24, 2010 | Mitsubishi VS-5059 50" Rear Projection...
My Mitsubishi VS-60621 seems to have a convergence problem
Projection TV2_bing.gif sets have several common problems listed below.
Problem #1) Convergence
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Screen may look distorted
  • No Audio/Video - TV2_bing.gif makes a chirping sound.
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Halos around objects
  • Red/Orange looking video
You can see some examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Mar 05, 2010 | Mitsubishi VS-60621 60" Rear Projection...
Blue convergence is shifted right slightly
CHECK FOR THE SUFECE MOUNT CAPACITORS AT THE SMALL CONVERGENCE CIRCUIT BOARD
Jul 13, 2009 | Mitsubishi VS-60609 60" Rear Projection...
Color convergence
The convergence IC's will need to be replaced along with possible resistors and/or fuses.
Dec 17, 2008 | Mitsubishi VS-45607 45" Rear Projection...
Mitsubishi Vs-6047 Convergence Problem...Please Help!
usally convergence green is split between 2 ics. so if your blue and red are still good. it might be the green output resistors. The
Jan 08, 2008 | Mitsubishi VS-6047 60" Rear Projection...
Mitsubishi VS-60707 60" Rear Projection TV
1. THE CONVERGENCE CAN BE RESET BY PRESSING "MENU 12596" TO ENTER THE CONV MISC. MENU THEN "8970" TO RESET
Aug 21, 2007 | Mitsubishi VS-60707 60" Rear Projection...
Mitsubishi VS-60719 60" Rear Projection Television Logo
244 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
