Question about Digital Media Syndicate Soundcast Audiocast Wireless Audio Transmitter
Soundcast act 211 wireless audio system wireless interference w/airport
I am a teacher trying to get wireless music from laptop to room speakers. I am not allowed to use my own airport because they say it will interfere with the school network wireless. I am now trying a soundcast act 211 system. When I plug it in, my wireless school network/internet airport connection disappears. I have tried all 3 channels without consistent success. Any fixes for this? Thank You
  • 2,794 Answers
I'm not familiar with this product but my guess would be that the wireless signal from the audio transmitter is either overriding the wireless in your room.
You might want to consider going to a bluetooth system. It's range is only 30 ft and it doesn't impact wi-fi equipment.
Posted on Aug 21, 2008
Bose link AL8 will not connect with the Lifestyle homewide powered system
Your v35 system needs to be programmed to work with the second zone wireless unit. Read the instruction manual how to do it, or let a Bose dealer set it up for you.
Dec 27, 2013 | Bose link AL8 wireless home-wide audio...
Have wireless router. need adapter for old hard wired computer speakers
You can't use a wireless adapter like one you connect to a laptop or PC. Simple reason is that your speakers don't have an Operating System that can translate the wireless signal.
The easiest way (and I don't know what you call "reasonable priced") is to use Airport Express from Apple. A nice how-to can be found here. You can get them used for about 50$.
Another option is to use Sony HomeShare Wi-Fi Network Speakers - they cost about the same. Example here and a little how-to here.
Hope this helps - let me know if you have any questions.
Jan 08, 2013 | Computers & Internet
Sound cast will not play from my ipod by wireless green light on speaker blue flashing light in the transmitter
Usually this happens when you have a damaged power supply. Once you replace it everything goes back to normal. You can contact tech@soundcastsystems.com for support on this.
Dec 01, 2010 | Digital Media Soundcast ICT-111 iCast...
I'm having trouble finding a reliable software to download that will enable me to play youtube/slacker/pandora (non- itunes music) on my Mac and listen through my stereo using my Airport Express,...
Welcome to Fixya community.
Please try download and Install MacTube Player to play Youtube video or music... Let me know the result please...
Also to play the music in stereo receiver please follow below steps.
  1. Plug in the Apple AirPort Express into a power outlet near the stereo. Connect an audio cable from the audio port on the AirPort Express to the audio in port on your stereo. If your stereo has a different sized audio port than the 3.5 mm one on the AirPort Express, you will need to use an adapter to connect it.
  2. Plug in an ethernet cable from the AirPort Express to your computer or wireless router for a wired connection. For a wireless connection, connect the AirPort Express to your existing home network, or use a computer with a wireless network adapter to connect directly to the AirPort Express.
  3. Connect to the AirPort Express with your computer as directed in the manual to run the setup with the AirPort utility. Follow the instructions on the screen.
  4. Open iTunes and play the music to your stereo. There should be a pop up in the lower right corner after you run the Airport utility.
Let me know how far you could able to reach in a result. Our expert friends are here anytime to solve your issue.
Thanks once again for joining us.
Have a good day.
Aug 02, 2010 | Computers & Internet
Airport card only works in same room as router
Do you have a cordless phone in the apartment?
how many rooms do you have and in which room is the signal low? What router do you have?
Intermittent Connectivity:
NOTE: Before following the steps in this article, check if your wireless computers have stable connection when connected to other wireless networks (hotspots).
This article assumes that all wireless computers are experiencing intermittent wireless connection with the router.
Frequent wireless disconnection can be caused by different factors such as:
  1. Wireless interference within the network.
  2. Wireless settings of the router are still set to default.
  3. Firmware is corrupted.
Reducing Wireless Interference
If you are experiencing frequent disconnection from the wireless network, it helps if you check the following factors, all of which can greatly affect your wireless signals:
your cordless telephone system (or even your neighbors’), or other nearby equipment. Try to change your router’s channel to 1 or 11 (the default channel is 6) and restart the wireless computers.
Physical obstructions: Your router or wireless computers may be losing connectivity because of physical obstacles such as walls and floors. Try to move the equipment to different locations to find a better link.
  • Placement of the router:
  • Router mfg'ssuggests that you place your router as high off the ground as possible. When placing the router in a high location, leave a distance of two feet between the router antenna tips, ceiling, and wall. If your signal passes through multiple floors, place the router on the upper-most floor, and high up in the room.
  • Surroundings: Keep the router away from large metal objects, bodies of water (fish tanks, bathrooms), and any electrical equipment including television sets, microwaves, radios, etc.
Customizing Wireless Settings of the Router
Having default wireless settings on the router may cause conflict with other routers within your network range. change the SSID (network name) and the Wireless Channel of your router. Also, if it is possible, enable the Wireless Security of your router.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
May 20, 2009 | Apple iBook G3 Clamshell (M2453B) Mac...
Macbook will not connect to wireless connection.
Try to use NetSpot app (it is free) http://www.netspotapp.com/
May 06, 2009 | Apple MacBook 13"White /2.0Ghz Intel Core2...
Airport express streams audio for a short period then quits
Make sure that your setup for the Express is set to "join the network" and not extend.
Also remember that with wireless technology there can be interference from microwaves, phones, etc.
If you are running programs that use a lot of bandwidth, this will cause the drop outs as well.
If you have a newer Express, another cure can be to use the 5GHz band for the broadcast channel.
Feb 14, 2009 | Apple AirPort Express (M9470Z/A) 802.11g/b...
Just installed Airport Express. I can select it from iTunes on my PC running vista. The music plays but songs intermittently stop...it like it can;s download fast enough...suspect the laptop can't send...
Make sure that between the laptop and airport express you don't have devices that can interfere, like microwaves, phones, etc.
Also, if its a newer express try using the 5GHz band and that the airport is set up to "Join the network" not "Extend".
Dec 25, 2008 | Apple AirPort Express (M9470Z/A) 802.11g/b...
Scrolling text interfering with audio when docked
Thats a new one. I wonder if there is some sort of RF interferance going on. Are there any other attachments plugged into your nano or the gear4? how about wireless?
May 19, 2008 | Apple iPod nano 3rd Generation
Digital Media Syndicate Soundcast Audiocast Wireless Audio Transmitter  Logo
224 people viewed this question
Top Digital Media Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Digital Media Audio Player and Recorder Expert? Answer questions, earn points and help others
