Question about NEC Lands Phones
I lost my book for the nec ete 6d 2 and I would like to program the 10 number button keys. Could you tell me how?
I kept trying combinations until it worked.
Posted on Aug 22, 2008
How to change the time on Dterm 6D ETE-6D-2UTEL for NEAX 2400 SDS/Sp
get a new phone for $5 from 2006 @ your local craigslist or join a freecycle group.
Mar 12, 2014 | NEC ETE 6 2 Dterm Series II Phone
I have a NEC Dterm80 I need to program a button on the phone to be my handset button so I may be able to use my handset. I dont what to have to call a DeltaCom tech in to program.
First and foremost we need to know what system you have. Then we can proceed with how to program the button.
NEC Elite 48, 192, IPK 1
First pick the button you want to program. Lets say button 13 in this example. Next check to see if that button is programmed by pressing Feature and that key. If that key says Vacant then it is available for use.
Next you will need to hit "Feature and 4" on that station to find the port #. Port # is Tel 10 for example. That means port 10 is where your extension resides.
Now type in "Feature, #, 0 *, 8974". The phone should say Program Mode. Now look at the Line Keys. These are the keys right above the # pad. Count from left to right 4 keys. Hit Line Key 4 and then type 12 on the dial pad.
Now that we are in key programming we need to enter the port of your phone. Make sure the blinking cursor is on the far left. If not press * to move to the left. Now enter 10 (port 10 or Tel 10) on the dial pad. The cursor should be right near the L. If not then press # to move to that position on the right. Remember * will bring you back to the left and # to the right.
This is where you are to enter the key #. In our example it is key 13. Dial 13 on the dial pad. Next we are going to change the key to a headset key by pressing "Recall, Line key 3". It should say H Set on the right. Now that you have the proper key set you need to hit transfer to write the programming. Remember to try and find a key that is not programmed, this will ensure that you don't undo any programming that is already in place.
Any other system other than the NEC 48, 192 or IPK 1 will not work.
Nov 17, 2009 | NEC Dterm DTP 16D-1 Corded Phone
Starview ntl codes 7/10/09
ntl (5401)
key 00 = f0 0e 91 e0 2d c1 c5 fd
key 01 = f0 cf c3 01 f1 2d ab b8
Oct 07, 2009 | StarTech.com StarView SV211K 2-port KVM...
Code for the starview box
CW Keys 5C01 updated 06/10/09 10:20
00= BC B6 BB DD 97 AD 11 63
01= 42 B7 84 3E BE 8C 4E 65
TW Keys 5A01 updated 06/10/09 10:20
00= C2 B5 BE 41 0D 9B C5 7C
01= 6D EA 8E 97 6A AA DA 71
NTL Keys 5401 updated 06/10/09 10:20
00= A0 51 3B 27 17 7D D0 28
01= F0 CF C3 01 F1 2D AB B8
Oct 06, 2009 | StarTech.com StarView SV211K 2-port KVM...
Eurovox codes for the 05/10/09
5a 01
updated 05/10/09
c2 b5 be 41 0d 9b c5 7c
8e 80 d7 ef 44 93 02 2b
(okey dokey (~:)
Oct 05, 2009 | Sony Televison & Video
How to program speed dial numbers?
To Set:
Do not lift handset
Press FNC button
Press the desired “One Touch” Key
Enter number to be stored (remember”0” for external numbers)
Press FNC button to save
To Dial
Lift Handset
8
Press desired One Touch key to dial
Jun 25, 2009 | NEC ETJ 16DD-2 Corded Phone
Need the steps to program the user defined buttons
go into program mode, find the port number of the telephone and in memory block 4-12, input the button number and browse difference Lk key to look for H_SET. Press transfer to save.
Jun 02, 2009 | NEC Electra Elite DTU 16D-2 Corded Phone
How to program a line to ring keysets
Not sure if I understand your question correctly, but I think I just learned how to do that on an electra professional. Memory block 4-1-1 lets you go through each of the internal extensions, and you can set each extension to ring when a call comes in from any/some/all of the outside lines.
to reach memory block 4-1-1, I used a multi line terminal connected to ports 1. Press fnc => hold => # => 0 => * => line key 4. Use the fcn(?) key to cycle through the internal ports, the line key buttons to map each of the 4 lines (presumably line keys 1 through 4 on your system).
As to where to get a manual, I am not sure, I have 3 thick binders... good luck
Apr 08, 2008 | NEC Electra Professional ETW-16DC-2
I need to program a HeadSet Button
For the DTU phone on an NEC Elite system:
Memory Block 4-12
put in the port number and the Lkey of the extension you want to make a headset key.
Programmin on a 16button phone, Lkey 11 needs to be lit and will display H SET to verify.
For the DTP phone, it is generally on an NEC 2000, which is entirely different.
Oct 12, 2007 | NEC Electra Elite DTU 16D-2 Corded Phone
Lands Phones Logo
54 people viewed this question
Top NEC Lands Phones Experts
Brian LaDuca
Oloyede Monsuru
Are you a NEC Lands Phone Expert? Answer questions, earn points and help others
