Question about Kitchen Appliances - Others
Deep fryer won't turn on
The deep fryer i have purchase will not turn on, it has got a magnetic plug and i don't know if that is the problem but it will not turn on no matter what i do!
  • 6 more comments
  • Anonymous Oct 11, 2008
    mine operated for one day and will not turn on.
  • Anonymous Nov 24, 2008
    yes
  • tcb1992 Dec 31, 2008
    I just bought 2 off ebay and neither one will turn on. I have tried to use the reset buttons and still no power. Am I doing something wrong? Or is this bad luck and both are defective?
  • morgul_man Jan 07, 2009
    I have the same problem with my new Presto Digital ProFry. It worked fine for three or four times after I got it. I took it out again after it had been sitting, clean and empty, for a few days, put in fresh oil, and nothing works. Reset button does nothing...I tried using different outlets. It doesn't beep, no lights, nothing.
  • Anonymous Jan 09, 2009
    the power switch will not turn on, pressed the reset button and nothing, any other problems like this?
    Rival CZF575, will not turn on
  • HOSNY1987 Apr 21, 2009
    pitco fryer sg14R NOT TURN ON
  • mier junior
    mier junior Aug 07, 2017
    The putterer was spot on. I took off the back of my presto fryer and what do you know. One of the wire came loose. Put it back in place tightened it. Working like new. Thanks man
I had the same thing on a Presto deep fryer. I removed that back cover and traced the wires from the AC inlet. One lead goes to a switch that activates when you slide the heater into the case so the heating element will not turn on if it is not in the case. I removed the switch, pushed it in and out a few times, verified that it works with a multimeter, reassembled everything, and "presto", it works. Maybe I was lucky, but it worked for me.
Posted on Oct 18, 2009
  • mier junior
    Thanks a lot you advice was spot on.
    New Friend:
    Problem Solver:
  • 7 Answers
I have a presto fryer. The indicator light would come on before I plugged the element into the fryer, but immediately went off when inserted into the fryer. I took the element part apart and jiggled the pieces inside a bit, put it back together and to my surprise it worked just fine!
Posted on Sep 18, 2010
What make is this deep fryer?
Posted on Aug 27, 2008
I have a ussell Hobbs 17942 3.3 L Digital Deep Fryer - Stainless Steel, and it won't switch on for some strange reason, I have been trying and trying but just no luck, could you please list a possible things I could do?
Posted on Jan 30, 2012
SOURCE:
I have an imperial fryer. Pilot is on but main burners don't ignite. Pilot looks normal & thermostat clicks when turned
Number 5 is your thermopile/pilot generator. It is a pilot generator that does 2 things. It holds open the valve with a safety magnet and it operates the safety valve solenoid whenever the control stat calls for heat. Overtime they get weak and will hold the pilot but not operate the valve solenoid. I would replace that pilot generator.thermopile and party on!
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jul 30, 2012 | Imperial IFS40 Deep Fryer
I change the thermocople but now the burner don't lit
Hi there!
Check if the thermocouple is properly heated by the pilot flame.
Check also if the hi limit has continuity across the terminals.
Regards.
Apr 23, 2012 | Star 30lb Gas Counter Top Deep Fryer 630fd...
Put a new valve in a imperial fryer pilot lights and stays lit but when i turn the t-stat on it shuts off
The reason is the pilot generator will hold the safety magnet but it won't operate the solenoid.
It is old and weak.Ain't putting out enough power to operate the solenoid. Get a new generator
Jul 16, 2011 | Imperial IFS40 Deep Fryer
I just purchased my fryer at garage sale today, it's missing the cord. What type do I need to get and where can I find it. Thank you,
Hi and welcome to FixYa, I am Kelly.
These cords (unless the magnetic type are available at most hardware stores ("Woods" / Woods Industries or Coleman Cable are the product brand names.) These cords are usually in the area of extension cords.
Having said that... The distance between the pins is the difference. There are 1/2" cords 11/16" plug cords and 1 1/16" cords. I need to know the distance between the pins center to center of your fryer connector terminals.
Most Fryers use a 3 Ft cord and roasters use a 6 ft Cord. You cna use a 6 ft cord but do NOT use it for an extended period. The cord you purchase must be wire gage 16/2 NOT 18/2 in wire size.
The 18/2 gage will only handle 1250 watts.
The part number of the cord will be either 0290 or 09326 (You can net "IMAGE search" these for sources)
Here is one source for the cord.
http://www.hardwareandtools.com/Coleman-Cable-0290-6-Foot-Black-Appliance-Cord-0429928.html
If you have the magnetic base / end plug let me know and I will find you the correct plug.
Just repsond here and say you need the magnetic recepticle cord.
Thanks for choosing FixYa,
Kelly
Mar 27, 2011 | Masterbuilt K5713 Deep Fryer
Where can I get a philips deep fryers power cord. I lost the power cord.
If it is a non-magnet type you can purchase them here:
http://brands.hardwarestore.com/33-118-woods-industries.aspx
The first 2nd and 4th cords are the female cords.
I am thinking this is the cord your looking for:
http://electrical.hardwarestore.com/12-33-appliance-replacement-cords/appliance-cord-652573.aspx
Fits all standard brand roasters, broilers and deep fryers using pin spacing of 1-1/16".
Kelly
Oct 05, 2010 | Philips HD6153 Deep Fryer
Need a plug in cord for a bravetti platinium pro fryer 2 prong
Where can i buy a magnetic break-away cord for a Bravetti F1075H Deep Fryer
May 28, 2010 | Bravetti F1075H Deep Fryer
Magnetic plug won't stay pluged in
double sided tape thin type that should hole in place clean both sides, if some one trips it still comes out easy.
Jun 28, 2017 | Bravetti EP4305FS Deep Fryer
I don´t know how to use the magnetic cord
the cord sticks to the back of it (right on top of the two prongs)make sure its facing the right wat!
Dec 09, 2008 | Ultrex 416-101 Deep Fryer
Presto Model 0692001
Same her but I found this info,
Presto multi cooker magnetic cord 09984
Replacement magnetic cord fits Presto Kitchen Kettle multi cookers from model numbers 0600001, 0600002, 0600003, 0600004, 0600007, 0600009, 0600010, 0600101, 0600110, 0600203, 0600305, 0600306, 0600308. Original part number 09984.look on the bottom of the fryer not on the plug to find these numbers.
Nov 13, 2007 | GE 168997 Deep Fryer
GE 106789 Cool Touch Deep Fryer
called Rival,they have loads of MDP-1 power cords sets,just purchased mine today.(1800-323-9519).BTW,,When asking ,its listed as MPD-1 instead of MDP-1,(typo error).Its the same cord.
Jun 17, 2007 | GE 106789 Deep Fryer
Kitchen Appliances - Others Logo
8,970 people viewed this question
Top Kitchen Appliances - Others Experts
Marvin
Marvin
Irene Tulloch
john h
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
