Canon MP530 Printer Error 6B10 will not reset after first page printed fine. Yes, I have exactly that problem, don't know what to do
SOURCE: canon pixma mp530 problem error code 5100
i had the same problem. aall i did was open the printer up and moved the thing that holds the cartridges to the middle by hand. mine seems to be working fine. post again if its still not working.
Posted on Nov 16, 2007
  • 159 Answers
SOURCE: Canon MP530 U052 Error
The dreaded U052 error means that the 'chip' fitted to the Cartridge is not responding .. Canon (like all printer mfgs) makes all it's profit from selling Ink .. so they fit these chips to try to prevent you refilling or using a 'compatible' replacement cartridge
You have to move the chip from the Canon cartridge to the 'compatible' and (it seems) the chips are particularly sensitive to static / damage .. many people end up blowing the chips during the swap over .. or even when fitting the original genuine cartridges to a brand new unit for the first time ...
If the unit is brand new, take it back and demand a replacement ... if you have just swapped over the chip onto a compatible cartridge, you can try buying a genuine Canon cartridge (which will have a new chip) = hopefully that will do the trick
NB. I have seen some suggestions that canon's have a 'Service Mode' that allows you to disable the cartridge chip checking and allow you to print no matter what .. however I've never found any details ... perhaps some-one else has the details ??
Posted on Mar 22, 2008
SOURCE: scanning from Canon MP530 to Mac Powerbook
If you;ve installed the MP Navigator software from the CD, then you should be able to press the scan button on the printer with your Mac connected and the MP navigator will open automatically on your Mac ready to scan. You can also try going into Preview (the Mac app) and from the file menu select Import... and it should open a scan window.  Hope this helps!
Posted on May 07, 2008
old marine
  • 2068 Answers
SOURCE: Printing a book from Word using duplex printing
In the Printing Preferences window, on the Page Setup tab, you have already selected Duplex Printing and Automatic. If your book is to be bound on the long side, you should have 'Long-side stapling . . ' selected in the window below that.
If that is what you have selected and the pages are printing wrong, try the 'Short-side stapling . . .' option.
Posted on May 09, 2008
Had to move the printer cartridge and shut down three times, but it finally kicked in and started working again. Don't give up just trying it once.
Posted on May 27, 2008
My MP530 won't print. It isn't coming up with an error and all the inks are fine.
I know this sounds rather patronising but are you sure you have removed the tape on the black in cartridge before you fitted a new one. You would be amazed how many people forget to do it.
Jun 27, 2014 | Canon PIXMA MP530 All-In-One InkJet...
Canon Pixma MP530 multifunction printer
1.Power off the printer
2, Unplug the printer's power cord, wait 5 seconds then replug the power cord in.
3, Hold the Power button for 6 Beeps
4, Release the Power Button
Sep 15, 2008 | Canon PIXMA MP530 All-In-One InkJet...
Can you do macs? how do i print duplex with this printer, duplex is suported by my mac
The Canon-supplied MP530 driver doesn't have duplex printing as a print option. Mac OS 10.5 has Gutenprint drivers built-in for a number of popular printers, including the Canon MP500 which is a near match for the MP530 and includes the two-sided option for printing.
With the MP530 plugged into your Mac (or, presumably, available over the network) go to the Add Printer wizard ( System Preferences > Print & Fax > + ). Pick MP530, name the printer something like "MP530 Gutenprint" and under "Print Using:" choose "Select a driver to use...", select "Canon PIXMA MP500 - Gutenprint v5.1.3" and then Add the printer.
The MP500 Gutenprint driver isn't a perfect substitute for the MP530 one, however, so you should do this in addition to installing the proper MP530 driver from the Canon website and adding the printer using that driver with a name like just "MP530" or "MP530 Canon". In a year or two of using the Gutenprint driver I've only once had a print job that wouldn't render correctly (some missing lines on the printout), and for that one time I had to switch to the Canon-supplied driver to get it to work. All the other times I find it very convenient to have two-sided printing available as an option.
The two sided printing isn't particularly fast, but it's a whole lot more convenient than manually printing the odd pages and then the even pages.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
Mar 28, 2011 | Canon PIXMA MP530 All-In-One InkJet...
I need Canon MP530 manual
Mar 17, 2010 | Canon PIXMA MP530 All-In-One InkJet...
MP530: After printing one page, it gives "Paper Jam" error, I open and close the ink cover, and print another page, with the resultant "Paper Jam" error, etc. Any solutions?
Either you have a bad sensor, or the sensor arm is bent so that it doesn't return properly after paper passes thru, It's hard to see, on the right side behind the platen roller, above the white guide plates.
Aug 28, 2009 | Canon PIXMA MP530 All-In-One InkJet...
Canon MP530
it may need to be reset or the worse the power surge blew out its memmory chips inside the printer. printers come with an amount of memmory about 4 to 8 megs so that it can remember print jobs try a test page after you leave unpluged for half hour
the printer should be able reset itself
May 04, 2008 | Canon PIXMA® MP530 All-In-One Printer
Canon mp530 getting error message 6a00
HI Guys 6A00 error usually cant't be fixed according to the service centre, I was lucky and actually bought an extended warranty, the service centre said that the MP530 are a good printer and worth fixing as they don't see many at all compared to other models and other brands. There was a broken piece of hardware that something to do with the print carriage. cheers vailey
Jan 30, 2008 | Canon PIXMA MP530 All-In-One InkJet...
Two-sided printing
On a PC...
- Ctrl + p to print
- Choose the Canon MP530 if it's not already selected
- Click Properties button
- Page Setup tab
- Select Duplex Printing
My paper always gets jammed, so I always uncheck the Automatic checkbox. Hopefully you won't have to do that.
Good luck.
Nov 13, 2007 | Canon PIXMA MP530 All-In-One InkJet...
114 people viewed this question
