We have an Admiral LNC6748A80 washer do you have a parts breakdown list?
Do you have a parts breakdown list
2 Suggested Answers
  • 69 Answers
SOURCE: Admiral washer (LNC6748A80) does nothing during first spin cycle
Faulty timer ?
Posted on Sep 23, 2007
tiger56h
  • 176 Answers
SOURCE: Looking for a parts breakdown
check in the D&L stor
Posted on Oct 27, 2010
I have an Electrolux EIFLSS55IIWO Washer. The chrome paint on the selector knob is chipping so Electrolux is sending me 2 new knobs for the washer and matching dryer. Can you please advise how to replace...
Good Morning David,
I see that you are looking to replace the selector knobs for your Electrolux washer, model# EIFLS55IIW as well as your matching dryer. This is typically not a common DIY job, and I do recommend contacting an authorized technician. However, I have found a link on the manufacturers sister website, which I have listed below, that provides a parts breakdown. It will also allow you to enter in the model number of your Electrolux dryer and locate the parts breakdown, as well as, a comprehensive listing of authorized techs in your area. Hope this proves to be helpful!
http://b2b.frigidaire.com/support/ResultsPage.asp?strModel=EIFLS55IIW0&User=&Search=Search
-Best Regards-
WP
Apr 07, 2014 | Electrolux EIFLS55IIW - Front Load Washer...
Noisy spin cycle. bearingsnoise mah5500bww. need part breakdownso i can get corrct parts numbers.
Sears Parts Direct carries parts for your washer. click HERE for parts breakdown and price list
Jun 22, 2011 | Maytag Neptune MAH6700A Front Load Washer
I'm looking for a video to replace a snubber in my capacity plus admiral. Any snubber video would be helpful.
I'm assuming that since you mentioned a "snubber" that the washer you are referring is a Maytag manufactured top loader (Admiral is manufactured by Maytag). If so, the following link can give you some guidance on how to repolace the snubber and/or brake assembly:
http://www.fixya.com/support/r3574320-maytag_washer_squeaking_problem
I have included part numbers for tools you may need and some advice on what you can do to avoid having to purchase any higher priced special tools.
Replacement parts (if required) can be purchased at any of the following web sites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
Recommendations on parts that may require replacement:
Brake Rotor with Lining
Brake Stator Snubber
The part numbers will be based on your MODEL NUMBER.
Prices will vary between the sites I have listed, so shop and compare. The first three sites I have listed, have helpful exploded view diagrams to assist you with locating and properly identfying the parts you need. If you search by model number, these parts are listed under the "Transmission" parts list. This is not a difficult repair, and the parts (including most of the tools) are not expensive.
If you have any questions about this repair, please post back and let me know. I hope you find this information helpful.
Feb 03, 2011 | Maytag EPIC MFW9700S Front Load Washer
Need the part # for the door seal for a GE front loader washing machine,model wbvh6240hww
The part number for the model you have listed is WH08X10036. I found your washer listed at pcappliancerepair.com, with a complete illustrated parts breakdown. Other sites you may try are:
repairclinic.com
NOTE: For your search criteria enter your model number a "WBVH6240H0WW".
I found the gasket listed at repairclinic.com and appliancepartspros.com for the best prices.
If you have any questions, please post back and let me know. I hope this helps you.
Mar 05, 2010 | General Electric WBVH6240HWW Front Load...
I need a switch fo a Mcculloch FH140A or rocker parts
The switch number I found is 7022140A02 and list is 2.84. You can go to McCullochpower.com and find a dealer near you or order the part online. You can follo the links to look at the same breakdown I found for other parts
Jul 26, 2009 | McCulloch FH160G Pressure Washer
AAV7000AWW washer
sounds like the thrust bearing is worn causing an imbalance on the shaft. check herehttp://www.partselect.com/AdvancedModelSearch.aspx?ModelNum=AAV7000AWW&mfgModelNum=&fkMfgID=1:- for a schematic on this machine and parts as listed.. hope this is of some help
Oct 22, 2008 | Admiral AAV7000A
Loud squeaking noise on an admiral elec. dryer ADE7005AYW. Where do I find a breakdown diagram, also? Thanks Steve
The most common cause for this noise is a failed belt idler pulley. Lubricating is a temporary solution and will not last, the noise will return. You can get a parts list and breakdown at this website: http://www.searspartsdirect.com.
If you need further assistance, let me know
Regards,
reg501
Jul 19, 2008 | Dryers
Admiral Top load washer won't agitate and squeals
Sounds like the gearbox, unfortunatly this is sealed and is cheaper to replace the machine, presume the machine is quite old.
Jun 28, 2008 | Admiral AW22 Top Load Washer
Washing Machines Logo
79 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
