Question about Western Digital 500GB My Book World Edition 500 GB Hard Drive
500 gB doesn't respond to anything!
I work on a Powerbook G4 and I've had WD 500GB hard drive for a little over a year and its always seemed to be working fine. Even when I'd accidentally unplug it it would still mount after about 5 minutes of "thinking" about it (constantly spinning and showing the solid blue light).
Well, I don't exactly remember having unplugged it without ejecting it first the last time i used it, but when i tried to plug it in today it kept spinning forever (with the blue light still on) without ever showing up in my computer.
Eventually i restarted my machine with the HD still plugged in (thinking it would reset it and the drive would mount no problem when the machine reboots). Goes what - now it completely ignores anything i do:
- it doesn't spin
- the light never goes on
- the computer registers no activity whatsoever!
is it Dead?
(please tell me NO - my whole life is on that thing!)
  • drawleg Aug 28, 2008
    oh wow! after posting here i tried it so many times - it never worked! but now (3 days later) i plugged it in and the light went on again and it started spinning, but it still won't mount!
    ujsummer - you the man! what do i do now?
    Problem Solver:
  • 9 Answers
Leave it unplugged for a minute or so and see if it boots up.
Check the Power supply if it still works.
Posted on Aug 28, 2008
  • ujsommer Aug 29, 2008
    Well mine started having problems with the network after
    going to 2.00.xx firmware which I regret doing.
    Drops the network after some time .....
    There is something on the wd website about mybook and mac
    more here
    http://tinyurl.com/6mugoc
    j.
  • ujsommer Oct 17, 2008
    Well I found all the help and Info I needed with this site:
    http://mybookworld.wikidot.com/start
    What those guy's are doing is just great.
    The learning curve is very high. Linux experience needed.
    It tells you How to do it and fixes the problem.
    J.
3 Suggested Answers
SOURCE: WD Passport Essential 160gb with PowerBook G4
The problem is that your powerbook G4 does not provide enough power to your 160gb passport HD. This does not happens to the new Macs with intel inside.
There are several ways to fix it:
1) Go to West Digital Website and buy a "Power Buster Cable USB" (that connect your 2 USB ports to your passport HD in order to provide more power). I think that it costs 10$. This is the link: http://www.wdc.com/en/products/accessories.asp?ProdID=170
2) The other solution is easier. If you have an external USB hard drive with two USB ports, or a DVD/CD burner with two usb ports, you can pug your passport in one of the ports while the other HD or DVD/CD burner is connected to you PowerBook. You will be able to see and use your q60gb Passport HD.
Posted on Oct 25, 2008
joecoolvette
  • 5660 Answers
SOURCE: Having a similar problem with the La Cie 500gb. Powerbook G4.
The problem that has been inherent with all LaCie external harddrives, is the interface in the case itself.
Interface:
All external harddrives have a Style of harddrive that is used in a laptop, or one that is used in a desktop computer.
Laptop harddrives are 2-1/2 inches across in width.
Desktops are 3-1/2 inches across.
Your LaCie will have a 3.5, (3-1/2) inch desktop style harddrive, inside the case.
There are two main Types of harddrives.
IDE and SATA. (There is also a newcomer. SSD. SSD isn't being used in LaCie external harddrives at the moment, to my knowledge)
Your LaCie will use a SATA harddrive inside it.
This is an example of an average SATA harddrive,
http://en.wikipedia.org/wiki/File:Hdd.jpg
The photo of this harddrive is tilted at an angle, that doesn't readily show the interface connection, but it helps to explain.
At the bottom of this harddrive in the photo, and to the left, is the interface area.
Viewing the harddrive, look at the four metal pins on the extreme right of the harddrive. To the left of these pins is the Jumper pin area. (Has a white jumper on two of those pins)
To the left of the Jumper area is an opening, and to the left of that, is a long slot. The first small slot area is for the 7-pin Interface cable.
(Data cable) The next slot to the left, is for the 15-pin power cable.
This 7-pin Interface mates up to socket holes in a connector, of the case of the LaCie external harddrive.
It is this interface connector, inside the LaCie external harddrive case, that is the problem.
Solution?
Buy a quality, in-expensive External Enclosure, take the harddrive out of the LaCie, and install it in this enclosure.
Examples of 3.5 Sata External Enclosures,
http://www.tigerdirect.com/applications/category/category_slc.asp?CatId=2780&name=3.5-eSATA-enclosure&Nav=|c:2778|&Sort=0&Recs=10
(From $15 to $35, is a good range for a decent external enclosure)
Posted on Jul 22, 2009
I have a WD that i've had for a little more than a year, tonight it won't turn on, it shows an icon in my computer and lights blink very dimly except the bottom one which blinks brighter, i have a...
You can try a free program like Recuva to save your data: http://www.piriform.com/recuva
A good choice for fast remote data recovery performed over the internet is: http://FreeDataRecovery.us
Another reasonably priced choice but you need to ship out the drive is: http://300dollardatarecovery.com
Jul 26, 2011 | Western Digital 500GB My Book Pro-External...
My wd 500gb hardware is not opening
Test it on another computer, if it still doesn't work. Look to return/rma or purchase a new one.
Jul 22, 2011 | Western Digital My Book Essential Edition...
Light blinks on my portable WD elements 500 but the computer dosent recognize it. Im using a Powerbook g4 power pc. I have info in it i need to reach & other computers recognize the HD but not my...
click start control panel administrive tools ,computer management ,device manager scroll down universal serial bus controllers you should see a yellow question mark?
right click to reinstall drivers
make sure the lead/s that attach to this drive have a secure seating and are not bad/faulty the light on only tells that its getting power it might not be getting enough power you might test the lead/s or
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again, sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable,
hope this helps
Apr 14, 2011 | Western Digital 500GB ELEMENTS 500 GB USB...
Well i bought my first hard drive(WD) yesterday 10-25-10 and when i plug it into my mac power book G4, its not recognized. I went to utilities to try to format it. I see the hitachi drive and the Macintosh...
if you are trying to install through usb then check if the usb you are using is working try to connect a flash drive on the same usb and try of use the other HD on that usb and see if it gets detected if no then uninstall the usb drivers from device manager and restart the system and it will work and it will get instaled automatically
Oct 26, 2010 | Western Digital My Book Essential 500GB...
Seagate Hard Drive Pro 500 GB not detected
You need to test it by connecting it to another computer. This is the cheapest, easiest way to test if it's working.
If it does not detect on another computer then you can get it replaced by seagate. All freeagent series of drives have a 5 year warranty on them, so your drive will still be under warranty.
However, bear in mind warranty will replace the drive but does not include recovering your data. If your data on the drive is important you will need to speak to either your mac specialist or a company specialising in data recovery who can assist you.
If however the drive works in another computer, then you have confirmation that it's only something on your computer that is giving the problem. You can try connecting to a different usb port if you have not already tried that.
Apr 06, 2010 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
My seagate hard drive cannot be detected on the desktop anymore. Any ideas what to do? I have a Mac Powerbook G4
am not so sure if this is a similar issue with iomega external drive in which the drive wont show up on My Computer but when the external drive was plugged into an ubuntu machine the drive was being detected and working just fine.
Please try to do the same. plug your external drive to an ubuntu machine and lets see if it can be detected. If it is then the hard disk has a similar issue with iomega drives. check this link.
Apr 05, 2010 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
WD 320GB portable Hard drive not recognized by my powerbook G4
NTFS file system on Hard drive .
http://www.macyourself.com/2012/03/11/how-to-format-a-drive-for-mac-and-pc-compatibility/
Nov 26, 2017 | Western Digital My Book Essential Edition...
WD Elements 500 GB
Hi bobo08,
I'd first check to see if the drive is working correctly with some utilities that WD provides, then once you determine if the drive works, you can either return it the retailer or it's working correctly by using these utilities. Here's the link to that drive. HERE
Good Luck
Mark
Jan 01, 2009 | Western Digital 500GB ELEMENTS 500 GB USB...
My drive won't start up
Don't use a power strip or surge protector.... try to connect the power supply adapter directly to a wall socket. Always safely remove hardware after use
Aug 14, 2008 | Western Digital My Book Essential Edition...
500 GB WD external hard drive not mounting
Just go to the drive icon in the mycomputer and open the drive you can get the files no need to go the utility
Jul 23, 2008 | Computers & Internet
Western Digital 500GB My Book World Edition 500 GB Hard Drive Logo
490 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Marcin
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
