Question about Epson CX8400 All-In-One InkJet Printer
Epson CX8400 I have a 8400 and when I try to print the black does not work. I have cleaned the heads and done nozzle checks and the black still does not print. But if I use scanner and copy I get black perfectly. Only had printer since march and this is upsetting.
  • 2 more comments
  • shelbycobra Aug 22, 2008
    I have tried the head cleaning and the nozzle check and when i print out the nozzle check the black either does not print or is just really faded and broken up. I have tried to print out documents and they come out blank if in black but if I change color to something else it prints fine. Now if I place a picture (color) in scanner and make a copy, I get a perfect reproduction, including black, I tried this with a black and white photo and it comes out a reddish black.
  • Anonymous Sep 26, 2008
    every time i clean the printer heads, the lack of color gets worse. ive tried and tried, and can not solve the problem. i have removed the ink cartridges and applied windex to the points with an oral syringe and the problem gets better, but as soon as the heads are cleaned again, the problem is back. it started with the black, but has now started with the others as well. i am tired of apending hours trying to fix it. i love the printer, just do not love the hassles that have seemed to come with it.
  • kmtk Nov 18, 2008
    My printer will only print the nozzle checks for the colored inks and not the black. Not even faint lines. The cartridge is new and I tried it with another brand new cartridge too. I've only had it since March.
  • Mark Simpson May 11, 2010
    Does the black print out on the nozzle check?
No it doesnt print black at all ever. And I've tried two different brand new black cartridges.
Posted on Nov 19, 2008
    Novelist:
  • 110 Answers
Your next step is dependent on exactly how the nozzle check prints.
Let me know
Posted on Aug 24, 2008
Cant get my Epson Workforce 633 to print. WILL NOT print black.
check if ink came out of the head or nozzles if not then first open the nozzles and head with warm water.
Feb 10, 2015 | Epson WorkForce 633 All-in-One Inkjet...
My Epson wf-2540 printer won't print black I have done head cleanings and have new ink in it as well. What can I do to fix the problem?
Run a print head nozzle check to see if any of the nozzles are clogged. Then clean the print head, if necessary.
Printing problems can be caused by cables that aren't connected properly, corrupt drivers, incompatible drivers, printer settings, missing updates, and problems with your printer. Might be best to start by insuring you have the latest printer drivers? Lastly, you might give the printer manufacturer a tech call. Good luck, Pete
Jan 17, 2015 | Epson WorkForce WF-2540 All-in-One Inkjet...
I have an epson NX400 inkjet printer, all ink cartridges are full and are installed correctly. When trying to print, the black ink is not being printed. I have tried doing several head cleanings,...
hey friend,
This should be the problem of print head ink nozzle block.The nozzle for the black ink cartridge got dry.So the ink getsdried state.It won't allow any inks passing through the micro nozzles.Head cleaning won't help with the heavy nozzle block.So try replacing a new black cartridge or else bring the printer to the nearest service center.It'll help so.
Mar 06, 2011 | Epson Stylus NX400 InkJet Printer
I have a 4 month old epson sx215 printer... everything was working fine two days ago and today i went to print some very important documents and my black ink wont work... the inks are all full, I have done...
you have two option,
1.you can do nozzle check and head clean , many time can repeat, there is any improvement you can continue the same process.it will work
2.change print head(better go for new printer,you should understand one thing, Epson print head along with printer so, you have to take printout at least every day one copy,if you are using HP inkjet printer,this kind of problem you can solve every easily, just change cartridge only,because hp cartridge along with print head not with printer.
Sep 25, 2017 | Epson Office Equipment & Supplies
Epson stylus C88 makes black horizontal lines on the print
This "banding" is caused by uneven ink flow through the print nozzles.
Have you tried a cleaning cycle? If not, try one (right click the little printer icon in the bottom right corner of the screen and select head clean). Now run a nozzle check (right click the little printer icon in the bottom right corner of the screen and select nozzle check). Is there any sign of ink on the paper. Try up to three
cleaning cycles. If ink is now flowing, but not yet perfectly, don't carry out any more cleaning cycles. Just leave the printer for 24 hours (to allow any air in the print head to disperse). Then repeat the cleaning cycle/wait process. It may take a while to restore a perfect nozzle check print.
If you have already done lots of head cleans with no perfect results, are you sure you have good ink cartridges properly installed? The printer determines the amount of ink left in the cartridge by counting the number of ink "shots" when printing, head cleaning etc. This information is stored in the "chip" on the cartridge. Thus, it is not an actual measurement of the ink left, but an estimate calculated by subtracting the total shots from the original full ink quantity. This estimate can sometimes be grossly in error, usually due to a cartridge replacement not being carried out correctly. To eliminate this possibility, buy a new set of compatibles on E-Bay - they're very cheap. You can always re-use the old ones later if it turns out they DO have ink in them.
If none of the above works, then you may have blocked print head nozzles. You can try soaking the print heads for 24 hours (or more), as follows. Turn the printer on, and as soon as the print head moves out of its parking position, pull the power cord out of the back, or turn the printer off at the mains. You may now carefully move the print head by hand over to the left hand side out of the way. Look inside the print head parking area on the right and you will see a small rubber cup that comes up to cover the print nozzles when the head is parked (to stop it drying out). Use a syringe or dropper to fill this cup with head cleaning fluid or distilled water. DO NOT USE TAP WATER. Carefully push the print head by hand fully into its parking position so that the cup full of fluid
comes up over the print head. Do not turn the printer on at any stage in this process. Leave this for at least 24 hours, then turn the printer on and try a head clean/nozzle check again. If you get any black ink on the nozzle check, then there is hope! Repeat the process until you get a full black nozzle check. If nothing, repeat the process once more.
If still nothing, post a new comment detailing what you have done and the results.
Apr 04, 2009 | Epson Stylus C88 InkJet Photo Printer
Epson stylus C88 won t print color ink black is
If you have carried out 4 to 5 head cleans, waited about 8 hours and done another 3 or head cleans doing nozzle checks after each clean (as recommended by the manual) and there is still no improvement then you will need a third party head cleaning solution such as this one:
http://websites.uk-plc.net/UK_Inkjet_Cartridges_PLUS/products/Print_Head_Cleaner.htm
Other makes & brands are available just google "inkjet head cleaning solution" Hope this helps.
Apr 02, 2009 | Epson Stylus C88 InkJet Photo Printer
Black not printing about every 3rd line
You have the classic single nozzle failure it appears. You say you have done a nozzle check. This should reveal that one of the black nozzles is not working i.e. there is a single gap in your nozzle check printout for the black nozzles. Now, this may be due to a blocked nozzle. Try the following print head soak process.
Turn the printer on, and as soon as the print head moves pull the power cord out of the back, or turn the printer off at the mains. You may now carefully move the print head by hand over to the left hand side out of the way. Look inside the print head parking area on the right and you will see a small rubber cup that comes up to cover the print nozzles when the head is parked (to stop it drying out). Use a syringe or dropper to fill this cup with head cleaning fluid or distilled water. DO NOT USE TAP WATER. Carefully push the print head fully into its parking position so that the cup full of fluid comes up over the print head. Leave this for at least 24 hours, then try a head clean again. If still nothing, report back
Dec 08, 2008 | Epson Stylus C84 InkJet Printer
Lines on prints
Hi kids! I decided to have another go at sorting out my 'lines' problem and have sorted it. See if this might work for you: I had previously done the head cleaning via the printer itself - holding the central ink/paper black button for 3 secs. This time I went to the Epson 1290 window on my Mac and clicked on the utility box. Though the Nozzle check print came out fine I went ahead and did the head cleaning in this box. The next print came out almost perfect so I ran the Head cleaning again and it printed a perfect print. Hope this might work for you. Keep on trying! All the best. Trant
Mar 07, 2008 | Epson Stylus Photo 1290 InkJet Printer
Epson CX8400 All-In-One InkJet Printer Logo
195 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
