Question about HP Pavilion a450n PC Desktop
Whats the problem
The light on the tower stays on but on the screen it shows entering save mode
  • 63 Answers
You're monitor is not able to communicate with the computer. tried reseating the cables (video cables). might as well open the chassis and reseat your system's video card.
Posted on Aug 21, 2008
When I turn the computer on it goes into digital power save and windows does not load
The monitor is going into power-save mode because it's not receiving a video signal from your computer. Are you turning on the computer at the monitor or on the tower? If you're turning the tower on are you hearing any noise (i.e. fans running, beeps, drives spinning, etc.)? Does the power light on the tower come on and stay on? If not you may have a bad power supply or other hardware issue.
May 02, 2011 | Computers & Internet
My flatron L1710S flat screen will not come out of power saving mode. When I turn on the monitor the power button/light is green for a few seconds, the screen indicated "power saving mode", then...
I switch on my PC, ensuring that all cables, leads and power supplies are connected properly. The tower powers up no problems at all. I switch the screen on, the green led lights up, the screen is completely black. A blue box appears centrally on the screen with the text 'power saving mode'. The green led light turns amber and then the screen just goes black.
Please don't suggest going to control panel, as I can't get that far.
PLEASE PLEASE CAN ANYONE SUGGEST ANYTHING give me
Mar 08, 2011 | LG Flatron L1710S 17" LCD Monitor
My monitor has gone to Power Save Mode
If your monitor is going in Power save mode it can be cause by following reasons.
>Check the data cable going from monitor to your Dell Dimension 4600 Tower is connected properly.The connector will be blue or white in colour.
>If the Dell Dimension 4600 Tower is powering on.
If still in power save mode then try to shutdown Tower and monitor,disconnect power cable from tower and monitor.Hold the power button on tower for 15 seconds.Then again try to connect monitor and check,if still nogo,and if tower has no lights then issue with motherboard or video card or power supply.If possible try connect spare known good monitor.
Thankyou
Sep 09, 2010 | Dell Dimension 4600 PC Desktop
Switch on computer tower and screen. Screen brings up LG logo and 'Activating power saving' then the screen shuts down. The tower continues to load Windows etc but I can't see a thing as the screen is...
For that when you power up the computer press F8 key then enter in safe mode then go to start menu->run type in run "chkdsk /r" without "" then restart computer then it fix errors .
If still not able to see windows then again press F8 then enter in enabler vga mode then go to display property and change screen resolution to 1024*768 then apply and ok then check.
If still same then you need windows disk boot computer with that disk.
When you power up the computer press F1 or F2 or "del" key then enter in bios then go to boot menu and set first boot device as cd/dvd rom then save settings and exit then it boot with that disk.
Follow the procedure and enter in recovery console then type "chkdsk /r" then it fix errors on harddrive then after completion restart it again boot and this time choose "repair previous windows" then it repairs it then you can use windows again.
Let me know if you need further assistance.
Thanks for using FixYa.
Feb 22, 2010 | Computers & Internet
Power saving mode upon start up
i) usually an computer enter's into power saving mode if computer monitor is not receiving any singals from the computer tower, so it has nothing do withur computer monitor(computer monitor is working fine), there is some problem withur computer tower.
ii) now try  removing all the physical connections going to computer tower(back side), wall socket  and replace them ....., (to avoid loose connections)
   now see whether ur computer is turning on and working properly so that your computer monitor receive singals ....
  let me know what is happening
Thanking you
M. Sridhar
Jan 01, 2009 | HP Pavilion a450n PC Desktop
COMPAQ PRESARIO V-6000 LAPTOP WILL NOT TURN ON
try to start the computer and right after that press the delete key several times as it try's see if u can get into the system bios if so change everything to a default level make sure you pres the f10 to save all info and try to reboot if this doesnot work please let me know good luck
Jul 13, 2008 | Compaq Presario 5000 PC Desktop
Compaq presario 5000 startup problem
Firstly the keyboard does blink, but do you hear 2 beeps one then another a few seconds later, if not memory or graphics fault. Are you able to start in safe mode(press F8 when pc is booting up)when menu comes up highlight 'Start windows with last known good configuration' then press enter and it should re boot. The graphics card(if it's not onboard)may need to be removed and re seated, also the memory. Also check hard disk drive ide and power cable.
Jan 15, 2007 | Compaq Presario 5000 PC Desktop
HP Pavilion a450n PC Desktop Logo
100 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
