The best way to speed up a slow running computer is to clean it for viruses. Also optimize your system, browser and registry using some reliable cleaner such as Reginout Cleaner.
> Turn on Windows Updates.
> Keep your device drivers updates.
Thanks
Too many reasons out there that may cause a computer running slow: system errors, registry issues, too many unneeded/conflict programs running, poor security software etc. These are manual ways to ahieve, for a tech geek, it's easy; for a computer newbie, it's hard. As a result, l recommend this computer speed up utility to you, which can help you easily and instantly speed up your PC & fix all issues with just a few clicks. Wish you good luck. Regards.
Remove files from temp folder
clean duplicate entries and fix broken entries in windows registry using Reginout...!
Hi, factors affecting your PC to slow down are;
1. When it was new, it really has a good startup and faster response, once you are connected to internet/online and the auto update is enabled it will continue to download updates files and automatically install discreetly. This updates can slow down your PC. You can uninstall updates at Control Panel add/remove software. Disable you auto updates.
2. Virus can also be another reason, if your PC has outdated antivirus it cannot detect new virus that can slow down the performance of your PC. Have your PC scan with updated antivirus.
3. Multi-tasking operation, if you open plenty of application it can also slow down your PC since every application is loaded in your PC memory cache for calling and loading. Upgrade your memory to increase computer performance.
