Question about Black & Decker Compact Power Screwdriver
Black & decker pivot driver cordless
Help! My 1st drill. I haven't a clue how to use and have tried to insert screw into wall to put up rod in closet. Tried different bits. Nothing. Drill is working. Can't find instruction book. Don't know how to proceed using anchor with screw. Do you drill hole first ? Screw in anchor first?
First DIY project I have failed since divorce. Need to show face with my daughters.
Thanks
    Master:
  • 623 Answers
1.drill hole
2.place rod and anchors
3.screw in
Posted on Aug 23, 2008
  • Anonymous Aug 23, 2008
    visit this site for more detailed instructions
    http://articles.directorym.co.uk/Cabinet...
  • 157 Answers
Hello sir
    basically you put the drill piece in the drill and tighten it in
    Put screw in the wall and press the on button
    Cheers
    Our online service website is for Black & Decker parts and manuals.
    There are two areas to assist you in finding what you need. You need to
    enter at least 3 digits/characters of a model #, part #, or product
    description into the “Find It Now” field on the upper left side of the
    page. It is helpful to have the model # of the product to easily locate
    information.
    http://www.dewaltservicenet.com/servicen...
SOURCE:
How do remove the battery from my black and decker pivot plus drill
It's in the **** end. You must unscrew all the black screws in the lower handle. Remove the black heel. Then unplug the Red wire. Carefully pull out the battery pack. Then unplug the black wire
You can order a new battery from HERE
Jun 22, 2011 | Black & Decker Pivot Plus Cordless...
How do i put a small drill in the pivot i think i
Hi
These drills have hexagonal tool holders, and does not have an adjustable chuck like larger drills do. However, I recommend drill bits with hexagonal bases whicha are readily available at any tool store these days.
Good luck
Feb 25, 2011 | Black & Decker Pivot Plus Cordless...
How do you turn it on?
Click on the link below to access the Black & Decker Pivot Cordless Drill/Screwdriver owners manual, inside this manual will show you how to turn it on:
http://servicenet.blackanddecker.com/documents/English/Instruction%20Manual/5145342-00,PD600PD600G.pdf
Feb 04, 2011 | Black & Decker Pivot Plus Cordless...
How do I change the screw drivers on the black & decker power screw driver?
The black collar should slide forward, allowing for the removal and insertion of bits.
Nov 25, 2010 | Black & Decker Pivot Plus Cordless...
CANT GET DRILL BIT OUT OF BLACK DECKER BATTERY CHARGE DRILL HELP
dear sir
please use drill bit remove key with drill machine and try to turn it anti clock vise then your bit will being loose and you can remove it easily .
thank you
hope answer the question
please vote !
Oct 04, 2010 | Black & Decker Pivot Plus Cordless...
PD600 Pivot plus B&D drill.
Mine gets stuck sometimes too, I grab the inserted tool in the vise or with pliers and a twisting back and forth while pulling gets it out.
actually I just threw mine out when the trigger switch quit
Mar 21, 2009 | Black & Decker Pivot Plus Cordless...
I lost my ac adapter. Where do I get a
http://www.blackanddecker.com/ProductGuide/CategoryOverview.aspx?cPath=1496.1571
Mar 05, 2009 | Black & Decker Pivot Plus Cordless...
this one dosn't charge. It takes batterys. how do i change them
Dec 20, 2008 | Black & Decker Pivot Plus Cordless...
Where to insert AC adaptor to charge Black & Decker Pivot Plus El
The female plug is directly in the center of the underside of the handle...Inserted the AC Charger/
That was it.
Nov 13, 2008 | Drills
Black & Decker Pivot Plus Cordless Drill/Screwdriver AC Adaptor
extend the handle straight and all will be reavealed! Just in front of the triger inside the piviot point.
Mike
Nov 13, 2008 | Black & Decker Pivot Plus Cordless...
Black & Decker Compact Power Screwdriver Logo
488 people viewed this question
Top Black & Decker Hand Tools Experts
Marvin
Marvin
Don Numinen
Don Numinen
Dan Apthorp
Are you a Black & Decker Hand Tool Expert? Answer questions, earn points and help others
