Question about Sewing Machines
My feed dog fell down and I can't get it to stay up.
I pushed the lever and it feel now I can't get it to catch and stay up. How do I do it? I cannot get the feed dogs to stay in the up position. I took off the plate and lifted them up with the screwdriver and they clicked into place, but when I started to sew they went back down. I did try holding the lever in the up position and turning the wheel one full turn, didn't help.
Something I read made me realize that the owner's manual assumed you were looking at the machine from the back rather than from the front. I had been moving the lever in the wrong direction.
Posted on Aug 22, 2008
Kenmore Sewing Machine Model 385.16221 feed dog is stuck down,m the lever just does nothing. It lowered feed dog, then was useless when I went to raise it to position.
your machine will have a flip type opening at the very front of your machine above the area where the needles are attached to the arm that moves up and down ( it usually has the light globe installed in there ) after opening that door you will see where the dog feed is attached to it should also have a spring that helps the dog feed return to the up position when not in use , make sure it is not stuck in any way and some lubrication oil should be used to prevent it from sticking , while using the dog feed release button push the spring in a up and down motion to help it to dislodge
Oct 28, 2017 | Kenmore Sewing Machines
Singer 4423 feed dogs are not working properly. Tested and verified that this happens without any thread in the machine. The dogs are not lowered. We've cleaned it and still no luck.
Now, I'm assuming that you pushed the feed dog lever in the back to the left successfully. If you couldn't make it move, try pushing the lever down and then to the left. You don't see any difference when that happens, because the feed dogs are actually ALWAYS down -- during ordinary sewing, they rise up to grab and push the fabric, then go down again. Turn the hand wheel (ALWAYS towards you) while looking at the feed dogs and see if they rise up during the cycle. I'll bet you DID lower them, but didn't realize it. What is actually does when you lower them is disengage the mechanism that makes them go up and down.
One more thing -- to set them in the up position again, you have to set the lever, then turn the hand wheel several times -- sometimes as much as five cycles -- and then you'll hear a click. That is true of ALL sewing/embroidery machines.
Dec 22, 2016 | Singer 4423 Electric Sewing Machine
Why is My fabric is not feeding through the pressure foot
the feed dogs are what move the fabric under the presser foot so the needle can sew. check your instruction manual and see where the lever is that operates the feed dogs. if the lever is up then the feed dogs will feed the fabric, if the lever is down, then the fabric will stay in place. if the lever is up and the feed dogs are not working, then it's time to have them checked.
Jun 10, 2014 | Husqvarna Huskylock Computerized 905
I have an Elna 2730. the feed dog is not transporting the fabric anymore and the needle just keeps stitching in the same place. is it broken or just needs adjusting?
if you have a manual, look to see where the feed dogs are, if the lever for the feed dogs is in the up position then the machine will sew a straigh stitch
if the feed dog lever is in the down position then it will only stay in one spot,
if you try to push the lever up and it will not stay or stays and will not sew then the feed dogs need to be checked
Oct 09, 2013 | Elna Quilter's Dream 6003Q
The feed dogs are not moving. First time use
here are 2 links for a manual, just incase you don't have one
check in the manual to see where the feed dogs are, see if the lever for the feed dog are in the up position so the machine will sew, it the lever is down,try pushing it the other way,if it will not go up and stay in position then the sewing machine needs to be checked to see if what's wrong with the feed dogs.
if it's a new sewing machine and the feed dogs won't work then take it back and get another one.
Oct 07, 2013 | Singer 1507
Brother XL 5130. I just got this machine and the feed dogs seem to be in the 'down' position, although I can't find a lever anywhere to move them up. In some of the forum, it suggests that
Look up "darning" and it shows a feed dog cover so that means this machine does not have dropping feed dogs.
Now that that is out of the way... most machines have the ability to adjust the height of the feed dogs. But without seeing your machine I can't advise you. It might be better to go have the machine adjusted and serviced.
Dec 11, 2012 | Sewing Machines
Fabric will not feed through feed dog
check the feed dogs in the needle plate area, you should be able
to feel them with your index finger, if you can't feel them, check for
a lever or knob that sets the up & down postion of the feed dogs.
the name of the machine & model number are not mentioned in the
question. do you have a manual?
Jun 03, 2012 | Sewing Machines
Thread goes off screw when i start sewing
Could it be that the feed dogs are down? I also have the 15358 and when I opened the bobbin area to clean it, I had this problem. Apparently, when you open the clips around the outside of the casing, it pushes the lever that adjusts the feed dogs to the right (lowering them). I didn't even realize it at first. Check your manual for adjusting this lever to raise the feed dogs. That might solve your problem.
Kenmore Owners Manual
Jul 03, 2009 | Kenmore 15358
Feed dogs do not come back up after lowering
Are you talking about the feed dogs or the presser foot. Either way, if you moved a lever to lower them, there is probably a screw that either fell out or has become loose that holds the linkage to the lever.
Jan 02, 2009 | New Home Sewing Machines
Sewing Machines Logo
56 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
