Question about Olympus Camedia C-350 Digital Camera
Selected resolution will not save
I have an Olympus Camedia C-350 which will not save it's resolution settings. It keeps reverting back to the HQ setting. I can change to SHQ, SQ1 and SQ2 and it stays on these settings all the time the camera is switched on but when I turn it off and back on again the resolution has reverted back to HQ.
Any ideas please?.
    President:
  • 919 Answers
You need to change the setting in the Menu of ALL RESET from ON to OFF so that it will retain any setting changes that you make. To do this Press Ok button - right arrow to Mode Menu - down arrow to Setup tab - right arrow to All Reset - right arrow and choose Off and then press Ok. This will retain the mode setting until you manually change it again or change all reset back to On.
Posted on Dec 17, 2008
Hi, I have a Olympus Camedia C-460. When opening to take a picture it defaults to a resolution of HQ 2288x1712. Is there any way I change the default to 640x480 which is available but has to be manually...
You need to go to the Menu and set the value for All Reset from ON to OFF. This will retain any setting changes that you make in the camera once it is powered off and back on. Press Ok - right arrow to Mode Menu - down arrow to Setup tab - right arrow to All Reset - then right arrow over to the selections of ON or OFF. Change it to OFF and press OK. It should retain SQ2 until you switch All Reset back to ON or manually change the resolution to be something else.
Jul 13, 2008 | Olympus Cameras
Resolution
No, it resets itself because it is an older camera.Most older cameras will, once turned off, return to their original settings.
So, if you want it to be 76 frames, you will have to do that each time you turn on your camera.
Mar 25, 2008 | Olympus Camedia C-350 Digital Camera
Camera gose back to defult setting
http://www.fixya.com/support/t161213-replacement_internal_battery
Just found the above on the same web site. This looks like the solution..
Dec 01, 2007 | Olympus Camedia C-750 Ultra Zoom Digital...
How do I lock the pictures size at SQ3?
The image quality should stay at what previously set not keep reverting to a 'default' Have you studied the manual re this ?. There is usually a more comprehensive manual on the CD in a PDF file Check Olympus customer support for further info
Jul 20, 2007 | Olympus Camedia C-50 Zoom Digital Camera
OLYMPUS CAMEDIA C-860L
If you find an online user manual for the Olympus C-860L camera, please tell me (send an email to "dave at burtonsys dot com").  Thanks!
In the meantime, try this...
With the data cable unplugged,
Open the sliding front to turn the camera on.
Press and hold the green button on the back, light up the LCD display,
Press the menu button on the top edge of the camera (the button farthest from the shutter button).  That should bring a menu up on the screen.
Press the menu button repeatedly to switch between menu screens.  E.g., press it twice to get to the resolution screen (SHQ / HQ / SQ).
Press the "+" and "-" buttons to move between menu items.
Press the shutter button to select/OK the menu item you have selected.
I hope this helps!
-Dave Burton
Apr 11, 2007 | Olympus Camedia C-860L Digital Camera
Camera doesn't keep settings
Here's the link to the manual if anyone else needs it; http://www.olympusamerica.com/cpg_section/cpg_support_product.asp?id=961 Thanks for the feedback sgalg, hopefully will help someone else :)
Apr 01, 2007 | Olympus Camedia C-8080 Wide Zoom Digital...
Features of each record mode
The details for each record mode are as follows: RAW: RAW data is unprocessed image data in its original state to which white balance, sharpness, contrast, color conversion and other processes have not been applied. CAMEDIA Master can be used to display RAW data and save it in other image formats. A RAW plug-in is also available for Adobe Photoshop which also provides the ability to process images in 32-bit color depth. TIFF: This is the highest-quality mode. images are saved as uncompressed data, which is the best for printing or image processing on a computer. SHQ: This is a high quality mode using the JPEG format. Because the compression rate is very low, high quality images can be stored. HQ: This is a high quality mode using JPEG format, with medium compression. Because the compression rate is higher than SHQ, file sizes are smaller. More images can be saved to a card. The file size can be changed in the 3:2 or Enlarge size mode as well as SHQ. 3:2 Mode: Ordinarily the image aspect ratio is set to 4:3. Due to change the ratio to 3:2, the picture size becomes 2592 x 1728 so that the image can be printed without losing the image borders at a photo lab. 3:2 can be set in the TIFF, SHQ, or HQ mode. SQ1/SQ2: SQ1 is used for resolutions above 1600 x1200 and SQ2 is used for resolutions below 1600 x1200. For both, you can choose high compression to reduce noise or normal compression to save more images.
Sep 04, 2005 | Olympus Camedia C-8080 Wide Zoom Digital...
Settings affected
The functions accessed from the arrow pad—Self-Timer (arrow left key), Exposure Compensation for adjusting brightness (up arrow key), Macro and Super Macro Modes for close-up photos (right arrow key)—will all be reset using the RESET arrow pad button. Also, the quality/resolution will be set back to the default of HQ. Settings such as language, date and time, and sleep time settings are not changed by using the reset button. These settings need to be manually selected through the menus in order to reset or change them.
Aug 31, 2005 | Olympus Camedia D-435 Digital Camera
Settings affected
The functions available from the arrow pad, which are Self-Timer (arrow left key), Exposure Compensation for adjusting brightness (arrow up key), Macro and Super Macro Modes for close up photos (arrow right key) will all be reset using the RESET arrow pad button. Also, the quality/resolution will be set back to the default of HQ, but settings such as the language, the date and time, sleep time settings are not changed by using the reset button. These settings need to be manually selected through the menus in order to reset or change them.
Aug 31, 2005 | Olympus Camedia D-425 / C-170 Digital...
Internal memory
Quality Mode Resolution 14MB Internal Memory 16MB xD-Picture Card 512MB xD-Picture Card SHQ 2288 x 1712 4 images 5 images 178 images HQ 2288 x 1712 14 images 16 images 523 images SQ1 1600 x 1200 27 images 32 images 1030 images SQ2 640 x 480 144 images 165 images 5324 images Storable movie length and resolution (approximate figures). The number of movies saved is based upon the storage capacity of the xD-Picture Card and length of each movie. Quality Mode Resolution 14MB Internal Memory 16MB xD-Picture Card 512MB xD-Picture Card HQ 320 x 240 30 fps movie 20 sec. max movie 24 sec. max movie 12 min. 54 sec. movie SQ 320 x 240 15 fps movie 41 sec. max movie 48 sec. max movie 25 min. 48 sec. movie
Olympus Camedia C-350 Digital Camera Logo
82 people viewed this question
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Jerry Greenberg
Jerry Greenberg
Are you an Olympus Camera Expert? Answer questions, earn points and help others
