Question about Microsoft Xbox 360 Console
CONNECT XBOX 360 TO COMPUTER
EVERY THING WORKS FINE BUT THE DNS FAILS...IP IS OK...I CAN SEE VEDIOS AND HEAR MUSIC........BUT NO XBOX LIVE..........THE XBOX IS HARDWIERD TO THE COM.......
  • RAGARGOONER Aug 21, 2008
    thanks for that, my com is conected to the internet by a usb wireless sender and i do not have acsess to the modam router , i should have told you this!
  • Anonymous Jan 16, 2009
    hey i have a ? my xbox says wired but my gateway or sumin like that says it cant connect but its same ip as my pc.. i changed my xbox settings to my pc ips but still says gateway has failed.. how do i fix that ? by the way its an ethernet cord conencted to my xbox to my pc ... plz help me find solution thank you
    Problem Solver:
  • 11 Answers
Try bridging your USB network connection with your ethernet network connection.  This will allow you to share your network connection and your Xbox should be able to hit the internet through your computer.  sandrew is correct, but by sharing your internet connection you can fool your xbox into thinking your computer is actually a router.
As you can see your computer, I'm assuming you have the necessary crossover cable, so you should be good to go after that.
Posted on Aug 21, 2008
    President:
  • 2,961 Answers
You are only sharing files with your pc to xbox, you cannot connect to the net throught the pc, the xbox has to have connection to a modem/router, or a router itself which is connected to modem.
SOURCE:
Xbox 360 DNS failure
unless a 360 has a modem built into it, you're gonna need one. also, you may need to set up an Xboxlive account to do ANYTHING. check your settings on the console as well to make sure things are working.
Jun 14, 2009 | Microsoft Xbox 360 Console
Can't connect to Xbox 360
reset it...look at back side of modem.....
and if it not works then contact your isp ...
Aug 18, 2017 | 2wire HomePortal 1100 Router...
IP ADRESS FAILED ON XBOX 360. TRIED 2 DIFFERENT ROUTERS SAME ERROR
xbox configures the connection automatically as long as it is able to detect an internet connection(either wired or wireless). For wirless connections though, make sure xbox is using the correct security key or wep key for the wireless connection.
Mar 22, 2009 | Linksys Wireless-G WRT54G Router
My Xbox 360 ADapter Cannot Aquire a IP Address from my Modem
can u please tell me which router it is? in most of the router there is a feature call DMZ. u need to enable the DMZ in the router & then u need to provide the static ip to Xbox 360 like 192.168.1.5 etc in the default getway u need to type the router IP address & on DNS u need to try three different settings 1st on primary DNS type the router ip address like 192.168.1.1, if it didn't work try with univeral DNS try on primary DNS as 4.2.2.2 & on secondary 4.2.2.1, if this didn't work either call ur ISP and ask for the DNS server address of ur ISP and try with that.
Jan 23, 2009 | Microsoft Wireless Network Adapter Xbox...
IPaddress failed
When this sort of thing happens it is usually a DNS error. The easiest thing to do would be to cycle your network. You can do this by unplugging your dsl/cable modem for a minute and plugging it in again.
XB360 also has a network test option that will tell you where in the network the connection is failing in the case that it is not a DNS problem.
Jan 16, 2009 | Microsoft Wireless Network Adapter Xbox...
ADSL Zoom x6 5590 DNS 360 Problem
Yes the router assigns an internal IP address. connect it up then using your PC go into the configuration of your router (http://10.0.0.2) and look under system status, scroll to the bottom and under DCHP status you will see a list of all clients connected. Your Xbox will be listed along with its internal IP address.
Jan 04, 2009 | Zoom X6 (5590) DSL Modem (55900003)
Xbox 360 Connection to internet
the IP address will fail when it is set on manual, rather than automatic. Be sure, once you enter it, it is set to automatic
Jan 03, 2009 | Microsoft Xbox 360 Console
Can't connect to Xbox Live
mtu is not working cant hook up xbox live
Nov 25, 2008 | Microsoft Xbox 360 Console
Xbox live
ok, this is what i have to do whith normal computers.
(the xbox is the same)
(make sure youve got a crossover cable (red one))
1.turn on ur xbox
2.goto the system tab
3.goto Network settings
4.edit settings
5.ip settings
6.change it to manual
7.ip address
8.type in 192.168.1.2
9.Subnet mask
10. type in 255.0.0.0
11.default gateway
12.Type in 192.168.1.1
On your computer
(vista)
1.start
2.control pannel
3.Network and Sharing Center
4.manage network connections (on side Bar)
5. right click on Local Area Connection
6. go propertys
7. doble click on tcp/ip v4
8. click use the following ip addess
9. ip address
10. 192.168.1.1
11. subnet
12. 255.0.0.0
13. default gateway
14. 192.168.1.2
15. click ok
16. click ok
17. right click wireless network
18. goto propertys
19. got the sharing tab
20. tick the only box you can
21. press ok
22. your done!
phew that was a long one.
hope this helps.
Maxicube.
Feb 09, 2008 | Microsoft Xbox 360 Console
Xbox 360
Contact the people you get your internet from. tell them you need to register your xbox. I have the DNS issues when i visit my girlfriend at college since they dont like to keep the Download speed high for the students. always fails
Dec 16, 2007 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
111 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Ekse
Nathan Hamilton
Nathan Hamilton
Paul Castley
Paul Castley
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
