Question about Microwave Ovens
Viking microwave VMOS200 timer works but no microwave or turn table
Microwave and turn tabe inoperative, timer and light works. Missing the silver cardboard square by the light.
  • dberlin101 Nov 20, 2008
    turn table does not work
  • Microwave Ovens Master
  • 9,098 Answers
This is usually caused by either a bad door switch, a loose door switch mount, or occasionally a problem on the control panel.
Even though a door switch clicks, it may still be bad inside. Its continuity must be checked.
Door switch or mount trouble can be caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
One test that sometimes helps is to gently lift up (and/or push down) on the door or handle as you try to start it. If it works or tries to work, then it's a door switch mount or door alignment issue.
If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa:.
The square piece you mention is the waveguide cover and it will need to be replaced. It provides important protection for the magnetron.
To buy one, you can contact Viking here or call 1-888-845-4641.
Posted on Aug 21, 2008
Viking microwave vmos200
mine did the same thing took back apart cleaned put back togerther no fix bout new one
May 10, 2013 | Viking VMOS200 Microwave Oven
Vmos200 microwave-set microwave timer goes down no power but when open switch is pushed in a little bit it works holding it in slightly
On these, this is usually due to a failing bottom door switch, or its mount. Sometimes the door can also get misaligned due to slamming.
See my help file on door switches here.
The Viking VMOS200 is essentially just a rebranded Sharp R-530E-series oven. The R-530E service manual is here and it's helpful in working on your unit.
All the internal parts will be the same, but outer parts are cosmetically different.
You can order Sharp parts from Encompass here or you can call them toll-free at 866-779-5835.
Viking Customer Support is at 888-845-4641.
For Viking parts, on the West Coast call 1-800-488-9868. Otherwise call Hadco at 800-241-9152 or see
Aug 27, 2012 | Viking VMOS200 Microwave Oven
Our Viking VMOS200 just stopped working. The lights and the countdown timer work, but no fan noise and no turntable spin.
it has nothing to do with the magnetron. first you have to fix step one. then you will know if the magnetron is bad. its one or two of the primary switches on the bottom of the switch tower. usually with these mw if you dont press cancel to stop the mw, and you just push the latch to stop it, those wires heat up and cause the microswitches to burn and loose proper contacts.
put a cup of water in the mw. set it to one minute and as its counting down. push on the latch LIGHTLY, as to not fully open the door and you will hear the magnetron kick on and the turn table start to rotate
Mar 06, 2011 | Viking VMOS200 Microwave Oven
Looking for vmos200 microwave safe plate
The Viking VMOS200 is just a stylized rebranded Sharp R-530E-series microwave.
So you could use the Sharp tray (part # NTNT-A099WRE0 - zero on the end, not oh) from Encompass here or at 866-779-5835.
r contact Distinctive (Viking's parts supplier) at 248-380-2007 if you'd prefer their version.
Aug 21, 2010 | Viking VMOS200 Microwave Oven
Re. Viking DMOS200 1100 watts microwave oven does not turn on
I'm guessing that's a VMOS200?
If so, that's a rebranded Sharp R-530ES (as is the Dacor DMO2420S) and its secondary interlock (bottom door switch) or that switch's mount is bad.
See this file on door switches. If you only need a switch, you can order a universal type here for $5 postpaid.
The Sharp R-530E service manual will aid you in disassembly and it is here.
Jul 02, 2010 | Viking DMOS200 1100 Watts Microwave Oven
The Viking VMOS200 is essentially a rebranded Sharp R-530E.
One or both of these service manuals should cover disassembly and location of the bulb:
May 28, 2010 | Viking VMOR205SS Microwave Oven
My viking vmos200 miro wave is not heating everything else works
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Basic Microwave Oven TroubleshootingTips
Mar 02, 2010 | Viking VMOS200 Microwave Oven
Microwave power just stopped
if the lights and turn table still work, then its either your h.v. diode,h.v. capacitor or the magnetron tube at fault, if nothing operates then its the internal ceramic fuse under tho outer unit cover thats bad or your outlet is dead at the wall
Oct 16, 2009 | Viking VMOS200 Microwave Oven
Microwave Ovens Logo
365 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
