Question about Sakar Cameras
Does the small digital 98376/98377 98378/98379 work on emachines computer
  • 9 Answers
Sakar (Digital Concepts) model 98379
Driver/manual download--
http://www.sakar.com/productdetail.aspx?id=2275&categoryid=170
Pho Tags/Web Express software download--
http://downloads.sakarhelp.com/camerafrontend/Photags_Express.zip
Posted on Mar 20, 2009
The camera SHOULD work with all computers with Windows on them, if you can get the CD to work
Posted on Dec 30, 2008
Forgot password emachine
not saying this will work for you but it does for most pcs,turn off your pc and remove the comos battery,its a small round silver one that you will see on your motherboard,remove this for about 2mins then put back in,,it might bypass you password.
Feb 06, 2014 | E-Machines eMachines Desktop PC
How to take pictures off dead emachine
The hard drive must still be working to get the pictures off. The best thing to do is remove the hard drive from the machine and use either an external USB type case to mount the drive into so you can use another computer to explore the drive or there is a tool that just plugs on to the drive with a USB cable and power supply built in that will serve the same purpose. You must get the appropriate type to match the drive type which could be either IDE or SATA. SATA drives use the small cable and IDE use the wide ribbon. If the hard drive is not working, you would have to get specialized and expensive company to retrieve the data from the drive.
Jan 14, 2014 | eMachines Emachine T1742 Power Supply...
I am being told to stick a paper clip in the hole in front of the tray but there is no hole. I can't find the hole. Where else can I stick soomething in?
Generally there is a small hole under the tray. (The tray is where the disk sits in)
You may have a eMachines desktop computer, where there is an outer door which flips down, and the tray slides out.
Ease the outer door down, and see if the optical drive unit (CD/DVD drive) has a small hole under the tray.
If not then unplug the computer from power, observe Anti-Static Precautions, and open the computer case. Remove the Front Panel. (Plastic front of computer. Now remove the optical drive, and open it up.
I need the Model Number of your eMachines to be more detailed.
Post in a Comment.
Regards,
joecoolvette
Jun 22, 2011 | E-Machines emachines (emachinees) CD-ROM...
An emachine w5243 when i turn it on it post and then turns off
Check all the connections and try again. If that does not work you will need to open the computer up and check the connections in there. When you have the computer open look at the motherboard for some small round like tubes (called Capasitors) if any of them are bulging or have crud on the top of them they have gone bad and this could be causing the issue with your computer.
Jul 01, 2010 | E-Machines eMachines Desktop PC
Expansion slota
eMachines Support > ET1331 desktop computer > Product Views > Rear View,
http://support.gateway.com/emachines/desktop/2009/emachines/et/ET1831/ET1831rv.shtml
The metal covers that have the Plus sign ( + ) holes, are Expansion Slot Covers.
Insert a flat tipped screwdriver blade in the + sign hole.
Insert the screwdriver blade horizontally, in the + sign hole, on the right side. ( ---- , not vertical I )
Gently bring the back of the screwdriver down.
This will make the metal slot cover, bend the small metal tab that is holding it.
Go to the + sign hole on the Left side. Do the same on the Left side as the above.
Bring the back of the screwdriver up.
Keep working the metal expansion slot cover back, and forth, until the two small metal tabs that are holding it in, break.
Remove the metal expansion slot cover.
Before you begin, ensure that the expansion slot cover you wish to remove, lines up with the wireless adapter card.
Have any questions concerning this, post in a Comment.
Jun 25, 2010 | E-Machines eMachines Refurbished EMA...
Yesterday my friends emachine ET1331G-03w just bought 2 months ago, due to microsoft software updates issues upon restarting her computer won't start windows due to problem above, we tried to do f8 on...
As the computer is only 2 months old, you should be able to contact Emachines and have
them send you a recovery disc out for the particular model. As the computer may seem identical, in most cases a recovery disc from your computer will not work because of a different
driver or some other small issue.
Feb 12, 2010 | Gateway Computers & Internet
How to connect emachine flat monitor to my computer?
It sounds as if you are missing the power cord for the monitor. If the cord did not come with your monitor/PC, you can pick one up at any Radio Shack or electronics store. If you could forward me your eMachine model number as well as the monitor model number, I will see if I can better solve this for you without you having to spend anymore money.
Best Regards,
Franklin, C2Solutions
Jul 21, 2009 | E-Machines eMachines Desktop PC
We have a emachine w2060 and my mother unhooked 3 small cords looking for a power problem the small green and white the small red and white and the small black and white? i dont know where they belong so...
Unfortunately eMachine manuals are not very thorough. Here is a link to the support page for your computer:
w2060 Support
At the bottom of the page is a support telephone number. Call and explain that you need the front panel pinout for your computer. That's what it sounds like you have disconnected. There is also a link for online chat if that is an option.
I did find this page eMachine Pinouts that may be of help to you. It does not give the colors of the wires, but look for the abbreviations on the connectors such as HDD, PWR, and PWR LED.
May 12, 2009 | Computers & Internet
My speakers will not play on my computer
Those speakers were originally supplied with Gateway computer system that had sound cards with digital outputs. While some versions had analog and digital sound inputs, most often the speakers had digital input only. The on-board sound in the eMachines is analog output only, so the speakers are most likely not compatible with your computer. If you want to use those speakers, you will need to locate a PCI sound card with digital output.
Mar 08, 2009 | Boston Acoustics BA735 Computer Speakers
Emachines T2385 startup problem
Psu is a Power Supply issue but the black screen with a blinking white line is not.
The blinking white line can mean there is no instructions to tell the Computer to boot up. Which could be possibly the system battery (cmos) or Hard Drive.
I would narrow those 3 things down first.
Jun 26, 2008 | E-Machines eMachines Desktop PC
Cameras Logo
1,317 people viewed this question
Top Sakar Cameras Experts
Robert
Steven Wander
Steven Wander
Are you a Sakar Camera Expert? Answer questions, earn points and help others
