Are you sure you got the wires back on tight? Also it sounds like the bendex is not kicking out like it is supose to.....Did you change the starter cylenoied?
even some new starters are bad, it doesent happen much but it does happen. You might even take the starter back out and run Jumper cables to the starter. See if the bendex will kick out and stay out untial you diconect the starter......Sorry for your run of bad luck and I hope this is of some help.
You have a faulty starter solenoid on the replacement starter or a broken flywheel teeth
