Bosch HBN 131560B / 131520 hot-air Electric Single Oven
Problem for Bosch HBN 131560B / 131520 hot-air Electric Single Oven
Dropped!!!!
By badbrad75 on Aug 21, 2008
Hi, my girlfriend accidently dropped a teapot (full of hot tea!) on our new Bosch hob and oven (Bosch HBN 131 1.0 B).
The clock mechanism on the oven started going crazy before I switched the oven off. I waited a while before turning on again and a faint buzzing flicker could be heard from inside the timer. I used the hairdryer on a coolish setting afterwhich some water came out after some time. We also turned the oven on at a relatively high heat and left it to run for a period.
It seems to be ok now with everything working correctly but does anybody know if I should do anything else or should have done anything else?
Thanks.......
Popular Solutions for Bosch HBN 131560B / 131520
Questions and Unsolved Problems for Bosch HBN 131560B / 131520
Do you recommend Bosch HBN 131560B / 131520 hot-air Electric Single Oven?
Answer
Answer
Bosch stovetop,HDS7052U. Electronic Ignition problem. Need a match to turn on a cooking burner.
Answer
Steam escapes above door when cooking. I have cleaned the door and seals but the heat continues to... (More)
Answer
there is no display on the oven even the switch is put to on position
Answer
the outer glass door shattered BY ITSELF just 30 mins. ago......we have not used the oven in two... (More)
Answer
Hi where can I get a picture of the wiring diagram of the switch selector
Describe your Ovens problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Oven Experts
Top Range & Oven Repairmen
in , PA
(423) 303-3784
Oven and Range parts delivered overnight...
 Appliance Parts Pros.com
(410) 609-0006
A Leader In Kitchen Equipment Sales,...
Allegro Restaurant Repair
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
