GE 5.8 Cu. Ft. 3-Cycle Extra-Large Capacity Gas Dryer - White-on-White
Problem for GE 5.8 Cu. Ft. 3-Cycle Extra-Large Capacity Gas Dryer -...
GE 5 cycle automatic heavy duty dryer
By pepfarms on Aug 21, 2008
My dryer is squeeking like crazy - how do I fix it - works fine other wise.
Same Problem
Apr 10, 2009
-   GE 5 cycle automatic heavy duty dryer.
My dryer has a problem.
Without pushing start button it makes a noise.
The noise is not like a moter sound, but not a fully moter sound.
I think it is from the motor.
Just noise only, it doesn't work.
I can turn it off when I rotate the switch off.-   kdw080
Solution #1
posted on Jul 09, 2009
Not Rated)
res8tcap
Rank: Apprentice
Rating: 0%, 0 votes
I have a GE five cycle dryer . This dryer does not heat up what the problem? please help
Was this helpful?
Yes
No
Solution #2
posted on Nov 08, 2008
Not Rated)
mrgreenz
Rank: Wiz
Rating: 84%, 456 votes
Turn off the electricity to the dryer.Try spraying the belt with automotive belt dressing inside that goes around the bucket.. If that does not work it is probably the bushing at the back of the dryer. you will have to remove the bucket to grease the bushing.if it is still good. judging by your details it seems good.But it could be dry.Needs lubrication.
Was this helpful?
Yes
No
Popular Solutions for GE 5.8 Cu. Ft. 3-Cycle
Questions and Unsolved Problems for GE 5.8 Cu. Ft. 3-Cycle
Do you recommend GE 5.8 Cu. Ft. 3-Cycle Extra-Large Capacity Gas Dryer - White-on-White?
Answer
Answer
After taking apart my dryer to lubricate a squeak, the belt came off and I cannot figure out how to... (More)
Answer
ge heavy duty auto dryer model #DDE5300galad does not turn on, power, circuit breaker and timer on... (More)
Answer
GE 5 Cycle Automatic Heavy Duty Extra Large Capacity dryer is getting hot, but takes 3 cycles to dry... (More)
Answer
I have a GE dryer (DDE720SBLWW) that is not working after 1st load. A little frustrating, but I'm... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Dryers Experts
Top Washer & Dryer Repair
(877) 477-7278
Washer and Dryer parts delivered overnight...
AppliancePartsPros.com
(800) 357-1234
Welcome to Action Appliance Repair. We have...
jay_action appliance repair
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
