Question about Dryers
4 way dryer venting
I have a maytag model medz400tq dryer ,i want to vent to the left,they have a kit avail. is it hard to do
    Novelist:
  • 177 Answers
No its very easy to do, I assume it is an Electric Model.
Buy the kit if you want, it will have instructions!
Most dryers have a circle on the side that just needs to pop out, however its not that easy! it may take a slight tap or two
If your really good, go to your local Hardware store and buy the metal 4 inch flex venting, and do it yourself. Unplug dryer, remove front panel, and create your own vent the direction you want it, Use a really good duct tape, and seal the seams. make sure the vent doesnt touch anything else, :" Heater, wires, etc.
Reassemble and use the venting, I would recommend cleaning the dryer venting at least once a year.
Posted on Aug 22, 2008
Can i change which side the driver vent is located?
Hello Laurie. Your dryer allows rear vent, left or right vent. Here is a diagram which shows you all three http://www.searspartsdirect.com/partsdirect/part-model/Maytag-Parts/Dryer-Parts/Model-MDE5500AYW/3048/0151200/M0606011/00002?blt=06&prst=&shdMod=
Just pull the dryer out from the wall to access the rear and sides. Joe
Thanks for choosing Fixya!
Jan 11, 2011 | Maytag Neptune MDE5500AY Electric Dryer
Moved dryer to a new home. Dryer vent comes out of the middle of the dryer. New home vent is next to the outside wall so i have a bend off the dryer vent and then a bent to the out side vent, Can you...
Some Kenmore dryers have a knockout at the back, lower corner that can be "knocked out". If you have one of these it can be vented out through the side. If the knockout is there, a kit is available for the venting. Just go to www.sears.com and under the parts direct tab enter your model number aka 000.00000, and search out the kit.
Aug 29, 2010 | Kenmore Dryers
What is a Side Vent Kit ? And what is it used for??
Side vent kit for electric and gas dryers allows your dryer to be vented to either side depending on the model.
Aug 15, 2010 | Maytag Kitchen Appliances - Others
How do i side vent my maytag atlantis electric dryer?
Attached is a link to a diagram of your dryer.
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5170653
You would have to remove the back panel. Remove the existing vent pipe, install a 90 deg elbow of the same size diameter. Then cut a hole in the right or left side of the dryer cabinet that would line up with the new elbow.
Check the side cabnet of your dryer, it appears on the diagram that there may be a 4" knock out for a side exit vent.
Good luck, let me know.
Regards,
Jul 21, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
Does maytag make an electric dryer with bottom vent?
you want to vent of of the base of the dryer, directly down? None of the maytag/whirlpool line can handle this anymore. Only side vent options. GE may still be able to bottom vent. no dryer is really made for it out of the factory but some can be converted to it with a kit. usually if they can there will be a knock out panel for the duct in that place. GEs heater is on back wall making more room on the base for this kind of thing.
Jul 11, 2009 | LG DLG2525S Electric Dryer
Hard time find replacement hose
Have you tried a dryer vent kit from your local hardware store?
May 16, 2008 | Maytag NMPEB08F2A Air Conditioner
Maytag Electric Dryer MDE308DAYW doesn't turn on at all when pressing the button
Since the vent was filled with lint I would check the High Limit termal fuse located on the front of the heater asm. It is best to replace the fuse and thermostat. These parts are part of a kit that can be purchased from your local supplier. The heater asm is located in trhe bottom left of the dryer. and looks like this
Jan 16, 2008 | Dryers
Maytag Dryer
You can order a side vent kit for it or make one yourself. The kit has a couple of extensions and an elbow that will turn the exhaust out the knock out on the side. You can pick up everything you need at the hardware store but the kit has precut pieces and installation instructions. If it is not a big inconvienience to wait for it, I would recommend you order the kit through a maytag dealer or sears. That way you have the right pieces and instructions to follow.
Oct 21, 2007 | Maytag Neptune MLG2000A Front Load Stacked...
Dryers Logo
3,358 people viewed this question
Top Dryers Experts
