Question about HP Photosmart C5280 Printer
Printer error No matter what I do it says printer jam and it doesnt have paper in it to jam I dont know what the problem is with it I have printer C5240 someone help please
Check it well, there might still be a small bit of paper. if problem continues remove the cartridge and reload the systems >>>>SANUSI
Posted on Sep 03, 2008
SOURCE:
LaserJet 2420 Printer: hp 2420n 13.20.00 jam inside rear door...
i have 2420 dn printer..printer reddy mode the power on...but not initlizing...13.20 paper jaming error coming but paper is not jam..hw to resolve
May 06, 2010 | HP LaserJet 2420 Printer
I have a paperjam on my colour laser printer CLX 3170 and I dont know how to get to the paperjam inside the machine
Step 1
Turn the printer off and on to see if it can automatically clear some or all of the jam. Many printers provide an error-code listing on the front panel display for the area where the jam occurred. If your printer shows an error code, be sure and check the printer manual to see if that identifies the area of the printer where the jam occurred.
Step 2
Turn off the printer.
Step 3
Remove any paper trays. Inspect them for wrinkled or damaged paper.
Step 4
Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
Step 5
If necessary, remove the toner or ink cartridge. Place it in a bag or away from light to avoid damaging it.
Step 6
If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
Step 7
If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though.
Step 8
Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
Step 9
If the printer paper jam message still appears, then there is still some paper in the printer. Inspect the paper path once again.
Feb 19, 2010 | Samsung CLX-3175FN Color Laser All-in-One...
Open door cariadge jam
this error generally comes in when there is actually a paper jam or it gives a false paper jam.. so first of all make sure that these should not be any paper stuck inside the printer.. clean all the paper rollers with a little moist lint free cloth.. then plug the printer directly to the wall jack for the power supply if not connected..
if it doesnt resolve the issue.. we may have to perform a reset as well ..
Oct 22, 2009 | HP OfficeJet 4255 All-In-One InkJet...
My Samsung CLP-510 printer shuts down frequently for paper jam. However, there is no paper jam. To fix, I turn off the power to the printer for 30 seconds and after turning the power back on the paper
give this a try
  1. Turn off the printer.
  2. Remove any paper trays. Inspect them for wrinkled or damaged paper.
  3. Also open the back cover of the printer if this model has one.
  4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
  5. If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
  6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
  7. If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside.
  8. Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
  9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
  10. see alternative if the problem is still not solved.
alternative :
Load a piece of thick paper, for example photo paper and press the resume button (may be diffrent button on diffrent models) a few times to the printer picks up the paper and puts it through the machine.
Apr 14, 2009 | Samsung CLP-510 Laser Printer
E4 comes up on panel saying clear paper jam
With out knowing which stylus you have there error either refers to a paper jam or ink cartridge error. If it takes the beging of the paper but then stops it could be a matter of worn rollers that are not able to grip and move the whole page.
Nov 19, 2008 | Epson Stylus Multifunction Inkjet Printer/...
Paper jam
i would Isolate the printer to know if the printer is getting
the error stand alone. Disconnect printer from pc and turn the printer off. take out any remaining paper. Check for small pieces of paper and look for obstruction inside the printer and the paper feeding area. Then try and do a stand alone nozzle check by holding the paper button down and turning the printer on keeping finger on the paper button for arounf 5 sec. now if that still doesnt feed the paper there could be something worng with the machine. hopefully your still under warranty.
May 06, 2008 | Epson Stylus Photo R220 InkJet Printer
Brother MFC-9420CN Paper Jam B!!!
open and check for paper in the back. sometimes a corner may have been caught in there and will give you the error.
jb
Oct 25, 2007 | Brother MFC-9420CN All-In-One Laser...
Paper jam
There is normally an access bay at the rear of most printers to check for paper jam, but the printer may need to be disconnected from the pc and reset. If it still shows the same error it may be worth disconnecting again, ununstalling the driver in add/remove programmes then reinstalling and reconnecting in a different USB port if you have a free one.
Mar 03, 2007 | Canon PIXMA MP150 All-In-One InkJet...
HP Photosmart C5280 Printer Logo
115 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
