Question about Whirlpool GGQ8831L Gas Dryer
Inglis gas dryer heat loss
Hi guys
I have a Inglis gas dryer model # ij72001,my problem is that I get heat for about 5 minutes then the flame goes out. I see the pilot come on but it does not ignite. I have changed the thermal fuse and cleaned the vents. Any ideas would help.
Denis
  • denisd_91 Aug 25, 2008
    Thank you
    Thanks for the suggestion, after reading a couple of forums regarding this problem it was suggested to try changing the coil. Low and behold $17.00 and a 2 coil set, 1 hour to install and it fired up like a champ. Thank you everyone who has posted comments, because of forums and sites like this handymen like us can fix these problems for ourselves.
    Thanks again
  • jch-007 Feb 04, 2009
    I have a white westinghouse gas dryer model #wdg546rbso and when i first turn dryer on it heats for about 3 min then flame goes out after 2 min igniter starts glowing again but no flame starts i took ohm readings across all three heat sensors and they all have continuity none are open could it be the gas solenoids even though gas does come on ist time dryer is turned on after not used for a while is there a simple way to test the solenoids first before buying them or will i need to replace entire gas valve
    any suggestions or help would be greatfull
    Novelist:
  • 177 Answers
It sounds like you have an intermittent gas valve. The ignitor is calling for heat however the gas valve doesnt want to open.
Make sure you turn off the gas and unplug before replacing.
Check for leaks after you reassemble.
Posted on Aug 22, 2008
Why won't my inglis dryer heat up
if electric? check ur thermal shut off and thermistor with a multimeter. does it run at all? if it does it wont be thermal shut off but may be ur heating element? is it gas or electric? Gas? 1. may need to check ur coils which regulate the flow of gas, ? 2. CHECK Igniter which ignites the flame, or 3. CHECK THE glow bar. there are also thermostats on the heating eleemt you will want to check with a multimeter. the thermal cutoff, the hi-lo thermostat and the element itself.
Aug 16, 2014 | Whirlpool Inglis IP8200 Dryer
Inglis 82000 Dryer. No heat, but working otherwise. Where do I find the fuse in the dryer to check?
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 30, 2011 | Whirlpool Inglis IP8200 Dryer
I have a Maytag Neptune model number MDG9700A gas dryer...When I first turn the dryer on the dryer will get hot for about minute then the gas turns off and will not heat up again...It glows fine after...
heatman101
Aug 01, 2011 | Maytag Neptune MDG9700A Gas Dryer
GE dryer starts up ignitor gets hot you see flames everything is working. 2-3 minutes later the flame goes out. Is this a bad thermostat?
heatman101''';;
Apr 22, 2011 | GE DRSR483GD Gas Dryer
When my mdg 6000bww is turn on heating element glows, flame ignites, then flames goes off within 5 minutes. After waiting approximately 15 to 20 minutes, until it seems to cool down can restart and goes...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Aug 23, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Heat cycle stops/goes off
  1. Changing from 3 to 4 wire hookup on a electric dryer
  2. Door switch replacement help for a common door switch
  3. Dryer basics - Venting problems and power supply
  4. Dryer basics - timers and how they work
  5. Dryer basics - power cord problems
  6. Dryer basics - dead dryer
  7. Dryer *general* repair flow chart....Click here
  8. Gas dryer smell
  9. How do dryer thermostats work?
  10. How long can my dryer vent be in length?
  11. How to change a common rear drum seal
  12. How the belt is suppose to look at the motor and idler pulley
  13. Help on replacing dryer motor and some wiring tips for the 279827 motor
  14. Help on replacing dryer motor and some wiring tips for the 279787 motor new25.gif
  15. Help for storing an appliance
  16. Important Disclaimer
  17. I dropped something down the lint filter area....help!
  18. Inglis, Whirlpool and Kenmore most common style dryer - how to take apart ( lint filter on top )
  19. Inglis, Whirlpool and Kenmore most common style dryer - how to take apartslide show( lint filter on top )
  20. Whirlpool or Sears dryer with heater on the floor and four rollers for drum style - take apart helps ( lint filter in the door )
  21. Inglis, Whirlpool and Kenmore electric style dryers - no heat problems
  22. Inglis, Whirlpool and Kenmore electric element changing procedures
  23. Inglis, Whirlpool and Kenmore dryers - air flow
  24. Inglis, Whirlpool and Kenmore style dryers - noise problems....drum rollers and idler pulley information....
  25. Inglis, Whirlpool and Kenmore style dryers - belt change
  26. Inglis, Whirlpool and Kenmore dryer general motor problems
  27. Inglis, Whirlpool and Kenmore gas style dryers - no heat problems
  28. Inglis, Whirlpool and Kenmore dryers - where are my thermostats
  29. If your drum belt looks like either of these....change it!!
  30. Idler pulley slide troubles with newer Whirlpool build Roper dryer
  32. Newer style Whirlpool - Inglis - ( some ) Kenmore dryer front drum support ring install help
  33. Pilot flame help
  34. Sample wiring diagrams
  35. Test for ohm meter checking on electric dryers with no heat
  36. Taking apart an Duet or HE3 dryer for a belt change
  37. Taking apart a Whirlpool Thin twin washer/dryer to replace the belt
  38. Timers and some common Auto dry troubles and solutions
  39. What is a grounded element?
  40. Whirlpool - Kenmore dryer motor problems in the dryer with Even HeatControl....info on this is here + new25.gifExpanded repair helps for a common "Even Heat" dryer
May 15, 2009 | Whirlpool GGQ8831L Gas Dryer
Dryer flame goes on and then off
Try this link I hope it helps, I know it helped me a ton!! ps don't forget to rank my help. Thank you and have a nice day!
http://fixitnow.com/wp/2004/11/13/mailbag-how-to-troubleshoot-a-gas-dryer-with-no-heat/
May 05, 2009 | Dryers
Replace these solenoids on the gas valve. Feel them if you can. They get hot and quit.d910ca8.jpg
Feb 04, 2009 | Dryers
Whirlpool gas dryer heat goes on then off then on again
should have electronic igniter that light gas after turned on.
Jan 03, 2009 | Kenmore 73952 Gas Dryer
Whirlpool GGQ8831L Gas Dryer Logo
791 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
