Question about Dryers
GE Front Loader DRYER shows E62 Code!
My GE Dryer shows E62 and will not do anything while it shows that code. I have switched the breaker and turned it back on in the past which has fixed the problem temporarily. however, now that isn't even working. When the dryer says E62 I can still open the door and the light turns on, but I cannot do anything else. No other buttons work while it says E62. I also cannot find a "Service" Manual to tell me what E62 means.
Can anyone tell me what E62 means for my GE Dryer?
SOURCE: Frigidaire LEQ2152ES Electric dryer
Just to verify does it also beep six times? This model has the actual pushbuttons. Press all buttons lightly and see if any release. Disengage button.
Posted on Jan 03, 2008
Illeagle
  • 525 Answers
SOURCE: LG Front loader Electric Dryer want heat but will run and spin
If your dryer doesn't heat, check these:
Power from the house
Heating element
Thermal fuse
Wiring
Power from the house Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected.
Heating element Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable.
Thermal fuse On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
Wiring A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
This link will show teardown illustrations: Parts and more help available on other pages of the website.
http://www.repairclinic.com/0100_16.asp
Hope this helps.
Illeagle
Posted on Aug 27, 2008
ngfam1
  • 639 Answers
SOURCE: I have an error code
DEAR FRIEND,
ngfam1 here for you!
I am happy to be of assistance!
Codes can only be repaired by factory service!
If you want clean clothes, call service !
For this problem you will need to use factory service!
Here is the service company I refer my appliance customers too!
A&E Factory Service
A Nation Wide Company. / Available 24 / 7 for arranging appointments! In the USA.
1(800) 905-9505
If this dryer is 10 years old or more do not spend any money on it!
The new ones are much more efficient! If you have to replace it buy a Speed Queen , it will do 8 loads a week for 25 years!
It's the last washer and dryer I will ever buy!!!! And less expensive than a top of the line unit!
You will be fine now!
Thank You
Bless you,ngfam1
PS. PLEASE GIVE ME A GOOD RATING HERE ON FIXYA.COM BEFORE YOU SIGN OFF!
Posted on Aug 28, 2008
aborcass
  • 2651 Answers
SOURCE: Maytag Neptune Gas Dryer "do" code
sonds as if you have abad door switch assy, uint not reconozing the door closed
Posted on Nov 05, 2008
  • 111 Answers
SOURCE: What does display code 1H on GE Profile dryer mean?
It means you have it set for a 1 (one) hour delay start
Posted on Dec 16, 2008
Electrolux dryer error code e62
Good Afternoon Friend,
I understand you are receiving an E62 error code on your Electrolux dryer, model# EIED55H. I suggest resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Restore power and start any cycle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your dryer status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jun 11, 2014 | Electrolux EIED55H Dryer
E62
Good Morning John, thank you for your post!
I see that your Frigidaire washer is continuously beeping and displaying error code E62. However, I show that the correct error code is EB2. Typically, EB2 indicates that the incoming line voltage is above 130VAC. Please verify that the power supply is correct. You may also disconnect the power to your washer for up to ten minutes by flipping the circuit breaker off and back on. This often clears most false error codes. If the error code does not clear, it would be advisable to contact a professional the since the main control board is possibly faulty.
May 23, 2014 | Frigidaire ATF6000ES Front Load Washer
Why is my dryer beeping and showing E60?
The last alarm code memorized can be displayed even if the appliance is in normal operating mode (e.g. while the drying programme is being performed): - Press (start/pause) and first option button simultaneously for at least 5 seconds: the display shows the last alarm.The alarm sequence continues to flash as long as the two buttons are held down.
The appliance continues the cycle while the alarm codes are being displayed. If the appliance is in programme selection mode, the options previously selected are stored in memory.
E60 is family fault code but after reading last alarm you will see exactly fault code (E61; E62; E63)
E61 - Insufficient heating (maximum time exceeded)
  • Heater unit faulty
  • Wiring faulty
  • NTC sensor incorrectly calibrated/out of position
  • Electronic board faulty
E62 - Power reley to heater unit faulty
  • Wiring faulty
E63 - Intervention of auto-reset thermostat on the heater unit
  • Thermostat faulty (replace heater unit)
  • Wiring faulty
Dado
May 10, 2014 | AEG T57800 Electric Dryer
E62 code on display
E62 - Power relay to heater unit faulty
Could be:
  • Heater unit faulty.
  • Wiring faulty.
  • Electronic board faulty.
At this fault appliance forced cooling cycle.
Dado
Mar 11, 2014 | AEG T57800 Electric Dryer
Error code
E62 = System Contact Error. System contact error is just a fancy way of saying the washer has a loose connection. This connection can be anywhere on the machine, so check all connection plugs by unplugging and re-connecting all connections one at a time. If you don't find a loose connection, replace the control panel.
Read more: http://www.appliancepartspros.com/ge-main-pwr-board-we4m488-ap4980176.html#ixzz2qOlJ8wDy
Jan 13, 2014 | Dryers
Frigidaire FEQB4000FS1 keeps beeping; error code seems to be 62 but cannot find what the 62 leads to :(
Good Afternoon Jennie, I am happy to assist you!
Typically, an E62 error code is an indication of a short circuit. Let's try resetting the dryer by either unplugging it or flipping the household circuit breaker to the off position. It is important to wait approximately ten minutes and then turn the dryer on. If resetting the power does not correct the issue, your appliance could be experiencing a potential heater relay failure, control board issue or wiring problem. I would suggest contacting an experienced service technician to determine the precise cause.
Best regards!
Oct 19, 2013 | Frigidaire Electric Dryer
Hi I have an Electrolux dryer which has started showing the error message e60, when i hold the start button and the one next to ity I get error e62 showing can you help?
the "E60" error code will appear when there is an error with the door switch and sensor, An unbalanced door will produce the E60 code. Try to close the door gently and listen for the click. If the error remains, the door switch may need to be replaced.
the "E62" error code will appear when the lint filter and tubing need to be cleaned or replaced. The dryer will start and run for 15 seconds before shutting off. It will restart when prompted and run for another 15-20 seconds before shutting off. These steps must be repeated until the dryer continues to run the full cycle. Tim
May 12, 2011 | Dryers
Dryer kicks off circuit breaker, pf code is on dryer. now won't let me do anything
pf is for power failure. sounds like You may have a short somewhere. Be careful of electric shock.
Apr 21, 2009 | Dryers
Dryers Logo
1,163 people viewed this question
Top Dryers Experts
