Question about Brother MFC 8440 All-In-One Laser Printer
'Doc Cover open' error message
I cannot get rid of this message even though the cover is closed. Is there a sensor switch I can disable? My email address is alfred@sfsgo.com
Regards
Fred Pettit
    Scholar:
  • 136 Answers
NO no Sensor to disable
Check the Tab on the top of the Document Door
there is a table on it. Make sure the Senor Tab is NOT broken.
if it is you will have to have someone replace the Cover. their's a sensor on the document door make sure that not offset if it missing the tab it will ask you to close the door.
Check those two things first.
Worst Case you have a Bad Sensor and will need replacement.
Posted on Sep 13, 2009
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Brother Master
  • 1,362 Answers
Look for switch where the doc door closes and insert a piece of paper to trigger it, message should clear, adjust switch.
Posted on Aug 21, 2008
Bizhub 211 - doc cover open
Something is open. Check and make sure you closed everything securely.
May 30, 2012 | Office Equipment & Supplies
Tip
Main Error MINOLTA DI 1611, DI 2011 Messages and Their Remedies
PAPER JAM A paper misfeed occurred in the
main unit.
Open the cover at the indicated
location, and then remove the
misfed paper. (“When the Message
(Flashing alternately)
OPEN XXX SIDE COVER
All misfed paper was not removed
from the main unit.
Check the message in the display
for the location of the paper misfeed,
and then remove the misfed paper.
ORIGINAL DOC.JAM A paper misfeed occurred in the
Document Feeder.
from the Automatic Document
Feeder.
Open the Document Feeder Cover
and the Document Feeder, and then
OPEN DOC.FEED COVER
∗REMOVE PAPER IN
BYPASS TRAY∗
Paper is loaded in the Manual
Bypass.
Remove the paper from the Manual
Bypass.
FRONT COVER OPEN The Front Cover of the main unit is
open or not securely closed.
Securely close the Front Cover.
CLOSE FRONT COVER
DUPLEX COVER OPEN The Duplex Unit Cover is open or
Securely close the Duplex Unit
Cover.
CLOSE DUPLEX COVER
DOCUMENT COVER
OPEN
The Document Feeder is lifted up
(while a document is loaded into
it).
Securely close the Document
Feeder.
CLOSE DOCUMENT
COVER
DOC.FEED COVER OPEN The Document Feeder Cover is
open.
Feeder Cover.
CLOSE DOC.FEED
COVER
TONER EMPTY The toner is empty. Copying and
printing cannot be performed.
Replace the toner bottle with a new
one.
SUPPLY TONER
PAPER EMPTY The selected paper tray has run
out of paper.
indicates the paper tray, and
“XXX” indicates the paper size.
Load paper of the specified size into
the specified paper tray.
on Dec 18, 2009 | Office Equipment & Supplies
The error message says Doc. Cover open but the cover is closed
You will probably have a broken hinge at the back left hand side of the Doc. cover.
This means that the cover won't close properly at the back corner, and the cover sensing switch won't actuate.
Dec 08, 2009 | Brother MFC-8840D All-In-One Laser Printer
I changed the ink in my Lexmark 3400 printer and I keep getting an error message "cover open" and it's not open. I tried everything....unloading the software then reloading the software, shutting it off...
The printer displays a 'Cover open, please close cover' error message, even though the cover is closed.
This can happen if the lever on the cover open sensor is knocked off the switch assembly.
Nov 30, 2009 | Office Equipment & Supplies
Lexmark x3470 printer says "cover open" and it will not do anything. Curtis
Try these as I found them from Lexmark's website
Solution What you will see
Possible cause of the error
What to do
Take the following steps to try to determine if there is a hardware fault:
Steps Actions 1 Remove and replace the cartridges from the printer. 2 Disconnect the power cable and the USB cable. 3 Check that the power cable is plugged directly into a wall socket. 4 Reconnect the power cable. 5 Close the printer cover. 6 If the error persists, please contact Lexmark Technical Support for further instructions.
Nov 18, 2009 | Lexmark X3470 All-In-One InkJet Printer
HP Deskjet 5150 - top cover open
I had the same problem, and the cause turned out to be the cover switch not being fully pushed in. On the underside right edge of the top cover, there's a little triangular protrusion that pushes down a black rectangular button (the cover switch) when the cover is closed. The problem occurs because the flimsy top cover is made of plastic and flexes slightly when you close it. This means that sometimes, the right edge of the cover won't seat properly even though it appears as if the cover is closed all the way. When this happens, the triangular protrusion isn't fully pressing the switch down.
To test if this is this is happening, send a print job to the printer and wait for the "top cover is open" error message to appear. Next, open the top cover door and locate the cover switch. It's a little black button in a rectangular hole at the right edge of the doorway near the ink cartridges. Take a pen or a car key and use it to push the cover switch down. You can also use your fingertip to do this if it's skinny enough. If you keep the cover switch pressed down, the power button should start blinking to indicate a print job is coming through. If the print job actually starts printing, then you know the problem was the cover switch.
In my case, all I had to do the fix the problem was close the cover and make sure it was fully seated by firmly pressing down the right edge of the cover until I heard a plasticky "click" noise. After that, the problem went away.
Hope this helps.
Jul 23, 2008 | HP DeskJet 5150 InkJet Printer
Cover open error
There is a latch that preses a small switch when you close the cover (look for this) to indicate that it it close if it is broken you can tweek it using a toothpick or anything that may press the switch temporarily this may alow it to work as long as the switch stays down.
May 28, 2008 | Lexmark X3480 All-In-One Printer
Error Message
There is usually a small tongue on the card cover that engages either a switch or some other device to detect if the cover is open.
Check that it is not broken or that the sensor is not damaged etc.
Hope this helps...
Apr 17, 2008 | Olympus Camedia C-4000 Zoom Digital Camera
Document Cover Open
I had the same problem with mine. Lift the top scanner, and check the hinges on the left. That error message means that the little black sensor on the left next to the hinges is not meeting flat with the unit when closed. Hold the sensor in for a few seconds, and your printer will start working properly.
Oct 11, 2007 | Brother MFC-8840D All-In-One Laser Printer
Coolpix s6 lens cover error
I have a solution posted in doc "nikon s5 s6 lens cover error repair.doc"  uploaded on site http://www.esnips.com/web/papputatiyasStuff    It will be helpfull for you. Its is a step by step solution with images.
Regards Mukesh
Aug 30, 2007 | Nikon COOLPIX S6 Digital Camera
Brother MFC 8440 All-In-One Laser Printer Logo
238 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
