Question about HP LaserJet 2420 Printer
HELP Had a paper jam. We were able to retrieve the paper but in the process pushed the green button on left side inside the first paper tray. I believe this caused some type of flap to drop down inside the printer which doesn't allow us to put the tray back into the printer. Any solutions? Thanks
  • HP Expert
  • 141 Answers
Push the duplex pan back up and insert tray. The green button is to release the pan for accessing duplex jams. Just push it up until it locks.
Posted on Aug 21, 2008
Message appears "Paper jam".
Paper jams can be true or false. A false paper jam occurs when the error message displays, but no jammed paper is in the product. The following solutions apply to both true and false paper jam errors.
Print a self-test report Use the following steps to print a self-test report.
  1. Load plain white paper in the input tray.
  2. Press Setup , and then press 2 . The Print Report menu displays.
  3. Press 1 to select and print a Self-Test Report
Solution one: Clear the paper jam Step one: Remove loose paper from the tray Remove any loose sheets of paper from the input tray and the output tray.
Step two: Clear the jam from the back of the All-in-One
  1. Figure 2: Remove the rear access doorc01562020.gif
  2. Gently pull any jammed paper out of the rollers inside the product.
  3. Carefully remove any scraps of paper that are still stuck in the product.
  4. Reattach the rear access door. Insert the two posts on the right side of the door into the holes on the product, and then push the door in until it snaps into place.
  5. Reconnect the power cord to the back of the product, and then press the Power button (c01602202.gif ) to turn on the product.
Step three: Clear the jam from the front of the All-in-One Follow these steps to remove the paper jam from the front of the product.
  1. Without opening the cartridge access door, check the tray for jammed paper that you cannot remove from the back.
  2. If you see jammed paper, gently pull it out.
Step four: Print a self-test report
  • If the issue persists , continue with the next solution.
Solution two: Make sure that the carriage can move freely Follow these steps to make sure that the carriage can move freely. Step one: Check the paper path
  1. Check for any paper or object that might be stopping the carriage. Figure 4: Example of paper stuck in cartridge access areac01950807.gif
  2. Remove any paper or objects you find.
  3. Reach inside the product, and then manually move the carriage.
    • If the carriage is stuck on the right side , move the carriage to the left side of the product.
    • If the carriage is stuck on the left side , move the carriage to the right side of the product.
    • If the carriage is stuck in the middle , move the carriage to the right.
  4. Remove any paper or obstructions found.
  5. Make sure that the carriage can move freely across the width of the product by gently pushing the carriage to the left, and then to the righ
Step two: Print a self-test report
  • If the self-test report does not print , continue with the next solution.
Solution three: Clean the rollers and the rear access door Dust, paper fiber, and other debris might accumulate on the paper feed rollers and cause paper jams and paper feed issues. Follow these steps to clean the paper feed rollers inside the product. Step one: Clean the rollers
  1. Press the Power button (c01602202.gif ) to turn off the product.
  2. Disconnect the power cord from the back of the product.
  3. Press in the tab on the left side of the rear access door, and then pull the door away from the product to remove it. Figure 6: Remove the rear access doorc01562020.gif
  4. Lightly dampen a clean, lint-free cloth with bottled or distilled water, and then squeeze any excess liquid from the cloth.
  5. Press the cloth against the rollers and rotate them upwards with your fingers. Apply a moderate amount of pressure to remove any dust or dirt buildup. Figure 7: Rotate the paper feed rollersc00212278.jpg
  6. Make sure that the paper feed rollers on the rear access door are clean, free of paper bits, and rotate freely.
  7. Clean the surface and the rollers of the rear access door the same way you cleaned the large rollers inside the product.
  8. Replace the rear access door. Insert the two posts on the right of the door into the holes on the product, and then push the door in until it snaps into place.
Solution four: Service the product
Aug 08, 2011 | HP PSC 1610 All-In-One InkJet Printer
Paper jam
If you are experiencing paper jam problem with your printer, please follow these steps: 1. Remove any loose sheets of paper from the input tray and the output tray. 2. Press the Power button (c01602202.gif ) to turn off the product. 3. Disconnect the power cord from the rear of the product. 4. Unplug the power cord from the wall outlet. 5. Turn the product around so that you can access the rear side. 6. Push in the button on either side of the two-sided printing accessory (duplexer), and then remove the duplexer. 7. Gently remove any jammed paper or bits of torn paper from the rollers inside the product. Use both hands to pull any whole sheets of paper to avoid tearing them. 8. If you do not see jammed paper in the rear access area, push the buttons on the latch on the rear of the duplexer, and then lower the cover. 9. Remove any jammed paper from inside the duplexer. 10. Close the duplexer cover. 11. Gently push the duplexer into the product until it snaps firmly into place. Do not press the buttons on the end of the accessory while you reattach it. 12. Reconnect the power cord to the rear of the product. 13. Plug the power cord back into the wall outlet. 14. Press the Power button (c01602202.gif ) to turn on the product.
If you need any further assistance, please comment back.
Feb 13, 2011 | HP 8500 Premier All-In-One InkJet Printer
How to fix paper jam! problem
Clear the paper jam Followthese steps in the order presented to clear the paper jam. Step one: Remove any loose paper: Remove any loose sheets of paper from the input tray and theoutput tray. Take note: Do not remove jammed paper at this stage. Trying to clear jammed paper from the front of the product can damage the print mechanism. Step two: Clear the jam from therear of the product Take note : Never pull jammed paper from the front of the product. If you can pull it from the rear of the product or the tray, always try the rear first. Pulling paper from inside the front cover can cause mechanical damage to the product. 1. Pressthe Power button ( clip_image001.gif ) to turn off the product. 2. Disconnectthe USB cable from the rear of the product. 3. Disconnectthe power cord from the rear of the product. 4. Pressin the tab on the left side of the rear door to release the door. Remove thedoor by pulling it away from the HP All-in-One. Figure 1: Press the left side tab torelease the rear access door Gently remove any jammed paper orbits of torn paper from the rollers inside the product. Use both hands to pullout any whole sheets of paper to avoid tearing them. Take Note: Use a flashlight to thoroughly check the rollers and wheels for torn pieces of paper that might remain inside the product. If any torn pieces of paper remain inside the product, more jams are likely to occur. Figure2: Remove scraps of paper Replacethe rear access door. Gently push the door forward until it snaps into place. Step three: Clear the jam from theautomatic document feeder (ADF) 1. Openthe cover of the ADF. Figure 3: Open the cover of the ADF 1. Gentlypull the paper out of the rollers. CAUTION: If the paper tears when you are removing it from the rollers, check the rollers and wheels for torn pieces of paper that might remain inside the product. If you do not remove all the pieces of paper from the product, more paper jams are likely to occur. 2. Closethe cover of the ADF. Step four: Clear the jam from thefront of the product 1. Lookinside the product through the paper output tray to check if any loose or tornpaper is stuck in the rollers. 2. Gentlypull the paper out of the rollers. You must Remove paper from the front of the product as carefully as possible. If any torn pieces of paper remain inside the product, more paper jams are likely to occur, and this could damage the print mechanism. Use a flashlight to make sure that you find all traces of paper. 3. Reconnectthe power cord to the rear of the product. 4. Pressthe Power button (clip_image001.gif ) to turn on the product. Step five: Print a self-test report Printa self-test report. Please inform me if this help you with the paper jamproblem.
Nov 22, 2010 | HP J3680 Officejet All In One Printer
My hp laserjet 2430 keeps showing paper jam on tray 2 but no paper jam there. I have to press the ok button always to proceed. what could be the problem
Step one: Remove any loose paper Remove any loose sheets of paper from the input tray and the output tray.
CAUTION: Do not remove jammed paper at this stage. Trying to clear jammed paper from the front of the product can damage the print mechanism. Step two: Clear the paper jam from the rear of the All-in-One Follow these steps to clear the paper jam from the rear of the product.
CAUTION: Never pull jammed paper from the front of the product. If you can pull it from the rear of the product or the tray, always try the rear first. Pulling paper from inside the front cover can cause mechanical damage to the product.
  • Press the Power button (c01602202.gif ) to turn on the product.
  • Disconnect the power cord from the rear of the product.
    Remove the rear access door. Press in the release tab on the rear access door, and then pull the door away from the product. Figure 2: Remove the rear access doorc00909313.gif
  • Gently remove any jammed paper or bits of torn paper from the rollers inside the product. Use both hands to pull any whole sheets of paper to avoid tearing them.
    CAUTION: Use a flashlight to thoroughly check the rollers and wheels for torn pieces of paper that might remain inside the product. If any torn pieces of paper remain inside the product, more jams are likely to occur.
  • Check the rollers on the rear access door. If rollers are missing or do not turn freely, buy a replacement rear access door. Click here to order a replacement part from HP .
  • Open the cartridge door.
    Without turning off the product, disconnect the power cord from the back of the product.
    CAUTION: You must disconnect the power cord to move parts by hand without the risk of an electrical shock.
  • Disconnect the power cord from the wall outlet.
  • Look inside the product to see where the carriage is stuck, and then check for any torn paper or objects that might be restricting the carriage.
    NOTE: You might need a flashlight to illuminate areas for proper viewing.
  • Reach inside the product, and then manually move the carriage.
    • If the carriage is stuck on the right side of the product , move the carriage to the left side of the product.
    • If the carriage is stuck on the left side of the product , move the carriage to the right side of the product.
    • If the carriage is stuck in the middle of the product , move the carriage to the right side of the product.
  • Remove all traces of paper or obstructions found.
  • Make sure the carriage can move freely across the width of the product. Firmly push the carriage to the left side of the product, and then to the right side.Close the cartridge door.Reconnect the power cord to the back of the product.Reconnect the power cord to the wall outlet.Press the Power button (c01602202.gif ) to turn on the product.
  • Nov 11, 2010 | HP LaserJet 2430dtn Printer
    I have a 18 mo old 8500 OJPro wireless that won't advance the paper, makes a clicking sound and gives a false paper jam error. I have seen a split white gear within a black clutch assembly on the left end...
    Follow these steps in the order presented to resolve the paper jam. Step one: Remove any loose paper Remove any loose sheets of paper from the input tray and the output tray. CAUTION: Do not remove jammed paper at this stage. Trying to clear jammed paper from the front of the product can damage the print mechanism. Remove any loose paper Do not pull jammed paper c02073375.gif c01994705.gif Step two: Clear the jam from the rear of the product CAUTION: Never pull jammed paper from the front of the product. If you can pull it from the rear of the product or the tray, always try the rear first. Pulling paper from inside the front cover can cause mechanical damage to the product.
    2. Disconnect the power cord from the rear of the product.
    3. Unplug the power cord from the wall outlet.
    4. Turn the product around so that you can access the rear side. Figure 1: The rear side of the productc01617574.gif
    5. Push in the button on either side of the two-sided printing accessory (duplexer), and then remove the duplexer. Figure 2: Remove the duplexerc02051407.gif 1 - Press the buttons on the sides of the duplexer 2 - Pull the duplexer out of product
    6. Gently remove any jammed paper or bits of torn paper from the rollers inside the product. Use both hands to pull any whole sheets of paper to avoid tearing them. Figure 3: Gently remove the jammed paperc02073376.gif CAUTION: Use a flashlight to thoroughly check the rollers and wheels for torn pieces of paper that might remain inside the product. If any torn pieces of paper remain inside the product, more jams are likely to occur. Figure 4: Remove scraps of paperc02073377.gif
    7. If you do not see jammed paper in the rear access area, push the buttons on the latch on the rear of the duplexer, and then lower the cover. Figure 5: Open the duplexerc01617577.gif 1 - Latch on rear of the duplexer 2 - Duplexer cover
    8. Remove any jammed paper from inside the duplexer.
    9. Close the duplexer cover.
    10. Gently push the duplexer into the product until it snaps firmly into place. Do not press the buttons on the end of the accessory while you reattach it. Figure 6: Reattach the duplexerc01617578.gif
    11. Reconnect the power cord to the rear of the product.
    12. Plug the power cord back into the wall outlet.
    13. Press the Power button (c01602202.gif ) to turn on the product.
    Step three: Print a self-test report Follow these steps to print a self-test report. Printing a self-test report verifies if the hardware functions correctly.
    1. Load unused, plain white paper in the input tray.
    2. Press the Power button (c01602202.gif ) to turn on the product.
    3. Press the Setup button (c01726396.gif ).
    4. Press the Right Arrow (c01185072.jpg ) to select Print Report , and then press OK .
    5. Press the Right Arrow (c01185072.jpg ) to select Self-Test Report , and then press OK . The self-test report prints.
    Oct 30, 2010 | HP Officejet Pro 8500 Wireless All-In-One...
    Paper jam
    The way you describe your error, it seems that there is still some residual paper stuck inside the printer that may cause subsequent paper to be mis-aligned.
    Paper jams can be tricky to solve. The paper is usually stuck inside the printer mechanism so even if there is no visible paper jam, you will still get the paper jam error. Try this:
    1. Turn off your printer
    2. Open all trays and remove any paper stuck there
    3. Locate the button to open the printer, open it and remove any paper stuck there also.
    4. Repeate the above step for all buttons that you can find to access the inside of the printer
    5. Close all doors and put back all trays
    6. Turn on your printer
    NOTE: Please rate our help to keep this free service online.
    Jan 07, 2010 | Lexmark X5150 All-In-One InkJet Printer
    HP 6540 Lights flashing can't print
    This indicates a paper jam or the printer is out of paper. Do not clear a paper jam from the front of the printer.
    The printer might be out of paper
    1. Place paper in the In tray.
    2. Press the Resume button on the front of the printer.
    There might be a paper jam
    1. Press the Resume button. If the paper jam does not clear, then go to the next step.
    2. Push the two latch handles on the rear access door toward each other, and then remove the door.
    3. Remove any paper that is inside the printer by pulling it out from the back of the printer. If you are printing labels, verify that a label did not become detached from the label sheet while passing through the printer.
    4. Replace the rear access door.
    5. Press the Resume button.
    If the Two-Sided Printing Accessory is attached to the printer, follow these steps to clear a paper jam from the Two-Sided Printing Accessory.
    1. Turn off the printer.
    2. Press the buttons on the left and right sides of the duplexer, and then remove it from the printer.
    3. Remove any paper inside the printer.
    4. Open the duplexer.
    5. Remove any paper from inside the duplexer.
    6. Close the duplexer, and then re-attach the duplexer to the printer.
    If the Auto Two-Sided Print Accessory with Small Paper Tray is attached to the printer, follow these steps to clear a paper jam
    2. Press the buttons on the left and right sides of the accessory, and then remove it from the printer.
    3. Remove any paper that is inside the printer.
    4. Lift the back lever on the accessory, and then unhook the Small Paper Tray
    5. Tilt the Small Paper Tray forward and open the lower door of the accessory.
    1. Tilt the Small Paper Tray
    2. Open the lower door
    6. Remove any paper that is inside the accessory.
    7. Close the accessory, and then secure the back lever to close the accessory.
    8. Re-attach the accessory to the printer.
    Oct 03, 2009 | HP DeskJet 6540 InkJet Printer
    Paper jam at B2
    remove the paper tray or all paper trays that you have.
    To remove the a tray first you should pull it towards you the most you can than by pulling towards you and in the same time you should lift it up.So again i will explain the procedure, first when is pulled to the max out of the copier you should lift it up for some 45 degrees and than pull it toward you. When you will remove the paper tray or trays inside of the copier where ware the paper tray on the right side of the inside should have some piece of paper which is stuck there. After you will remove the piece of paper the copier should not jammed the paper in B2.
    Also see do the paper in the tray is putted as most close to the right fence of the tray, also see do the right green leveler is also closest to the paper in the tray. If the paper on the left and right side of the upper named fences is loosen than the rubber on the right side of the tray will not be able to pull up the paper in the copier when it will need to do it.
    Jul 11, 2009 | Ricoh Aficio 2015 Copier
    Paper jam
    This video explains how to resolve a recurring paper jam on your product. It sounds like the rollers on the rear access door may not be working properly and are making jamming the paper as it starts to feed up into the printer? Check the rollers on your rear access door and see if they have some give in them and roll freely.
    Sep 27, 2008 | HP Photosmart C7180 All-In-One InkJet...
    HP LaserJet 2420 Printer Logo
    63 people viewed this question
    Seeker5211
    Seeker5211
