Question about HP LaserJet 4 plus Printer
Pc load letter
My printer is saying pc load letter when the catridge is full of paper
    New Friend:
I have the sensor flag. And i got Drivers.... It is just instaled printer....
Posted on Mar 05, 2013
    Renaissance:
    An user who is expert in 3 categories / brands.
  • HP Master
  • 1,362 Answers
1-are the guides set correctly?
2-is the sensor flag there? on the bottomof the machine when you take out the tray you should see a piece of plastic hanging and is very loose it is the sensor for the paper, ( although I have seen it work without it !!!!!!)
Posted on Aug 21, 2008
SOURCE:
What is the problem when the display keeps on showing Tray 1 load ltr on Lexmark c500
Load ltr means to load letter size paper. If its saying try 1 load ltr - its saying that you are out of letter size paper in tray number one of your printer.
Aug 27, 2011 | Lexmark C500n Laser Printer
Printer says " PC LOAD LETTER" will not print
Change in printer driver to use paper "A4" not "Letter" format
Jan 30, 2011 | HP LaserJet 4 plus Printer
Changed cartridges, printer doesn't align or function
Something seems to be physically wrong in the mechanism.
Try the rolling wheels and the belt on which the cartridges run.
Jul 19, 2010 | HP OfficeJet 6110 All-In-One InkJet...
Prints 2 pages and says to load paper
Somehow after adding paper you changed the paper size to B5. Change it back to Letter and it should resolve your problems
Apr 11, 2010 | Dell 2135cn All-In-One Laser Printer
I have a PIXMA iP4000 - won't print-says no paper, load and resume- printer has paper but low black catridge -is it related to no paper problem
I have seen - with canon printers - where a low ink cartridge did result in a 'load paper' error. It is not uncommon.
Feb 10, 2010 | Canon PIXMA iP4000R InkJet Printer
Printer wont print. It keeps saying PC Load Legal. The printer has paper in it.
Well the printer is telling you to load "Legal Size paper, which is 8.5" X 14" paper.
More than likely, the application you are using is telling the printer to print the page on legal sized paper.
If you want the document to print on "Letter sized paper (8.5" X 11") then in the application, go to the File drop down and select "Page Setup". From within page setup's window, change the paper size to letter and then re-print the job.
Don
Dec 16, 2009 | HP LaserJet 4 plus Printer
Load A4
A4 is for european size, if you are printing on a letter size this is a mismatched.
you need to change your files printer properties to A4 or letter size, or change your printer paper size.
better yet cancel this document and send it again , this time by checking the printer properties was set to your desired paper size
Jul 28, 2009 | HP LaserJet 2840 Printer
Lasejet 4 plus- try to print. lower paper cassete full. printer screen says pc load letter and have to manualy load paper. print icon on computer says out of paper
There is a paper empty flag sensor, looks like a plastic paddle, in the tray area. Pull out the paper tray and flick it; make sure that it is not jammed.
Also on the right hand side there is a paper pick- up roller, clean it with a cloth with some alcohol. See page 4-13 for the location of paper feed pick-up roller. page 5-27 shows the paper empty sensor flag
Here is the service manual:
http://home.comcast.net/~wannabeyote/hp-lj-4-5-m-n-plus.pdf Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Jun 06, 2009 | HP LaserJet 4 plus Printer
Pc load letter
Hi there this issue is caused by your driver defaulting to letter and a4 paper being used set your default paper size to a4 in the driver and also set tray to a4 this should cure the problem Regards AL "alstech"
May 28, 2009 | HP LaserJet 4 plus Printer
Printer keeps saying unable to print
Take out both the catridges from the Printer......... Take 2 Paper Towels one should be wet with Luke warm water and the other one should be dry........... Take the Colour catridge first turn it upside down and u will see a small copper plate on the catridge from where the ink comes out....... Place the wet paper towel using ur thumb on the Copper plate and press it a lit bit for 10 Seconds...... Now remove it and see whether u see any ink on the paper towel.......... U should see some ink on it now place the dry paper towel on the ink catridge in the same way........ Now do the same procedure again.......... Do the same procedure twice on the Black Catridge................. Now take the dry paper towel and turn the direction of the cartridge so that u can see a Copper plate on it with small boxes just clean that copper plate with the Dry Paper Towel.......... Know insert both the catridges inside the Printer
Good Luck
May 06, 2009 | Brother MFC 420CN All-In-One InkJet...
HP LaserJet 4 plus Printer Logo
147 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
