Question about White Sewing 1766 Mechanical Sewing Machine
White sewing machine model 262 serial 13800
Cannot get the bobbin case together properly machine was given to me I have no manual for refrence. Thank You Lise
    Problem Solver:
  • 6 Answers
Here's a way to download the manual:
You can download White manuals from Singer. Just go to http://www.singerco.com/accessories/manuals.html and type W in the search box. The next page will be a list of White machines with manuals available. They may not have the exact model (as in my case), but there will be a similar one.
Posted on Jun 03, 2009
  • whollyfool Jun 03, 2009
    Below are instructions to get the manual, but I had a a similar problem. The manual was not a heck of a lot of help. I found that the needle should be at it's high point. The half moon with the bobbin enclosed in it should go vertically on the right: it will slip in so that it fits if you jiggle it a bit. Then you should be able to push the two bars that hold it in back into place. Let me know if that makes any sense. Here's the promised manual info:
    You can download White manuals from Singer. Just go tohttp://www.singerco.com/accessories/manu... and type W in the search box. The next page will be a list of White machines with manuals available. They may not have the exact model (as in my case), but there will be a similar one.
Manuel for #1304 bobber thread is to loose,puckering.
Do you mean the Singer 1304 Start? Singer has the manual on their product page: http://www.singerco.com/products/2767/1304-start#type-support . The direct link to the manual is http://www.singerco.com/uploads/download/e280f4dc4898708d9534c5420eb1c9ffe9704c17.pdf .
On this machine, you can check the bobbin tension by removing the bobbin and bobbin case together. Hold onto the thread coming off the bobbin and let the rest dangle. Jerk the thread upwards once or twice. Look at how the thread unwinds. If the thread doesn't move, then the tension is too high. If the thread unwinds more than an inch or two, the tension is too loose. Adjust the tension by tightening or loosening the screw on the side of the bobbin case. See page 13 of the manual (page 30 in the PDF) to make sure that the bobbin is properly positioned in the bobbin case. See page 19 (page 36 of the PDF) for the bobbin thread tension.
I hope this helps.
Aug 04, 2017 | Sewing Machines
Need a bobbin diagram for elba tx electronic so I can put it back together
It would probably be better to just purchase a brand new bobbin case. A bobbin case is a very technical piece of equipment vital to the successful operation of the machine. Even if you get it back together, it requires some very finite adjustments to make it operate properly.
Nov 19, 2016 | Sewing Machines
Why the bobbin casing won't snap into place
Usually you need to hold the little latch open until the bobbin case is seated in the machine. Perhaps this video will help;
Singer Promise 1408 Get started
Mar 29, 2016 | Singer Promise 1408 Sewing/Quilting...
How do I put the bobbin case back in to the shuttle holder, mine keeps falling out?
Put bobbin in holder. Thread properly. Pull out arm on bobbin which holds spool in place and gives u a handle. Place into position. Turn slightly so it fits into appropriate slot. Let go of arm. That's it. Good luck.
Mar 03, 2015 | Sewing Machines
Bobbin case Elna 62c
Really you are very appreciated in your machine maintenance. If you wanted to Elna SU 62c machine bobbin case
please see the link :
http://www.ebay.com/bhp/elna-sewing-machine-bobbins .
Dec 29, 2013 | Elna Sewing Machines
I have borrowed my Mother's Singer Machine # 1022 to finish a project. I have never used this model before. The bobbin threads are way to loose, which dial adjusts the bobbin tension? Also, what is the...
First check if the top thread tension is too tight. Make sure that there are no burs or other damage on the needle. Next check for lint or bits of thread between the bobbin case sections. Remove the bobbin and run a small screw driver or needle between the two silver plates on the top of the bobbin case.
Check if the machine is sewing properly before trying this next step. Find the right hand screw on the side of the black bobbin case. Make sure that this set screw is tight. Turn it clockwise. Next find the left hand screw on the bobbin case. Turn the screw 1/8 turn clockwise to tighten. Test the thread tension. If the bottom thread is still loose, turn this screw another 1/8 of a turn. Test the tension again. Do not over-tighten the screw. This can damage the bobbin case. Some sewing machine parts stores do have a replacement bobbin case available. One source is http://www.sewingpartsonline.com/singer-1022-sewing-machine-parts.aspx .
The dial with 0 F 1 2 3 4 controls the stitch length. Use the 0-1 position for zig zag Satin stitch (At 0, these stitches are very close together). Position 4 will give a longer stitch for basting. See page 4 of the manual (page 8 of the PDF) listed below. In the center of this dial is the reverse button.
Most Singer manuals are available here: http://www.singerco.com/support/instruction-manuals . The direct link to the manual for the 1022 is http://www.singerco.com/uploads/download/62d051dd5c881663ac19c0a587e679184d936b18.pdf .
I hope this helps.
Aug 22, 2017 | Singer Sewing Machines
I took apart my bobbin case, plate andbobbin holder. I can
I had the same problem and can't find my Owner's Manual. I found the answer on-line. Hopefully, you have the same type of bobbin casing. To get the answer, go to www.startsewing.co.uk and choose "How to thread a Sewing Machine". If you have the same type of bobbin casing, you should be able to figure out the proper placement of the parts by looking at the one in the demonstration. I am thrilled (!) and hope this works for you, too.
Jan 18, 2009 | Kenmore 15516 Mechanical Sewing Machine
Bobbin Casing - CE150
There is a website for support (http://futura-support.com/futuraMachine/manuals.htm), but together with your software you should already have that manual and other help materials, check under menu section Help.
Aug 31, 2008 | Singer CE-100 Futura Computerized Sewing...
Bobbin shuttle problem not solved
Did you download the manual from the link I provided? Both the normal & quick set bobbins are covered on pages 27 - 30 Here is the direct link to the manual: http://welcome.solutions.brother.com/BSC/public/files/dlf/doch000242/xl3500_t_3510ug01enes.pdf Please update the question & let us know if the information given was useful to you - Good Luck!
Sep 03, 2007 | Brother XL-3510 Mechanical Sewing Machine
Putting the bobbin back together
You can download the manual from the link below: http://welcome.solutions.brother.com/bsc/public/us/us/en/doc/manual_index.html?reg=us&c=us&lang=en&prod=hf_xl3500t3510eus&type2=-1&flang=English&dlid= Please update the question & let us know if the information given was useful to you - Good Luck!
White Sewing 1766 Mechanical Sewing Machine Logo
507 people viewed this question
Top White Sewing Sewing Machines Experts
Tally Girl
Tally Girl
tsalagi152
Are you a White Sewing Sewing Machine Expert? Answer questions, earn points and help others
