Question about Maytag Neptune MAH5500B Front Load Washer
Storage of Maytag Neputune stackable unit
What should we do to store our Maytag Neptune stackable. We are moving out of our house and then back in a year from now. The unit will be put into a self-storage stall for less than a year.
  • 2,071 Answers
Just put inside a big cartoon or a box crete, just to preserve,the paint and the machine ...
hope this nay help;
Posted on Aug 21, 2008
I have a maytag neptune washer/dryer stackable. Moved hooked it up dryer works great but washer wont turn on???
Make sure you have power to the outlet, I have seen where a 110 outlet was working on either the top half and not the bottom
Jan 30, 2015 | Maytag Washing Machines
Maytag Neptune stackable washer/dryer dryer not heating up?
check house braker, element, thermal fuse, thermostats, wires and connections including to the motor as the motor switch acts on the element. if all is good your electronic board should be the problem.. a local part dealer will usually help you in testing your parts if you dont have a multimeter..
Jan 28, 2015 | Maytag Washing Machines
Stackable Neptune Front Loader Washer Leak.
check that the door seals correctly on the rubber boot, check the boot for holes or rips, check the drain hose, tub to pump hose and pump.
Jul 08, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Very loud spin cycle
It sounds like the bearings have gone out in the tub. The major cause of this is using powder soap. There is nothing you can do but replace the rear outer tub. This is a costly fix but maybe worth it for a stack unit.
Jun 26, 2009 | Maytag Neptune MLG2000A Front Load Stacked...
Neptune stackable washer...
You put the detergent directly on top of the clothes.
Jul 31, 2008 | Maytag Neptune MLG2000A Front Load Stacked...
Maytag front lead stackable
That is correct. Take the screws out of the console up top. look for a burn mark on your circuit board. If it's on R11, replaced your door lock wax motor as well at the board.
Jun 04, 2008 | Maytag Neptune MAH5500B Front Load Washer
Water problem with stackable Maytag Neptune
You have to make sure your self if water is getting through the hoses first.Remove the hot& cold hoses on the back of unit.Make sure there isn't a clog in side of the water valve screens ,if so clean them.Still not filling?Possibly a blown fuse.
Feb 09, 2008 | Maytag Neptune MLG2000A Front Load Stacked...
Maytag Neptune Stackable washer continues to fill with water when unit is off
If the machine continues to fill even after the power has been switched off, this sounds like a stuck inlet valve. To identify the valve, look at your model in the "parts store" section of Maytag's website. The valve is item 21 on the "Control Panel, Top & Lid" drawing. From the drawing, the valve looks like a fairly standard item; I suspect you might get something suitable a bit cheaper elsewhere. A
Feb 05, 2007 | Maytag Neptune FAV6800AW Top Load Washer
Maytag Neptune MAH5500B Front Load Washer Logo
105 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
