Question about Toshiba Office Equipment & Supplies
When I change the setting on my e studio 451 c copier and make a copy it automatically reverts back to the default setting instantly, so when I need to do the next copy I have to set it all up again.
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Toshiba Master
  • 1,362 Answers
If it's somrthing you do regurlarly why not set it up in memory? should be in your manuals book
Posted on Aug 21, 2008
Force Canon iR2270 to always pull from a specific drawer.
There are no need to crazy brother, Print document from any tray is does not control by the window driver in default mode, u have to select the tray from machine in which u want that printout are coming by default,,............
First Of all Pull out ur tray from which u want to print outs are comming by defult, than there is a small gear under circle where u set the page size, in the corner of the tay, u have to turn in toward the ltr mode, after that machine automatically pick up the page from this tray by defult
Dec 14, 2012 | Canon ImageRunner 2270 | IR2270 |
Canon imagerunner 3235i. When it goes to print out the copy it instantly pulls it back into the machine and causes a jam. Any ideas as to what would be causing this or how to fix it/
you have opted for a 2 sided profile in the printer driver.change it to default settings.the copier is trying to print on both sides.if it is happening also during copying then u have to check the settings you have made.you can also clear the settings in common settings in additional functions . if u cant take 2 sided copies then u have to get ur copier check for duplex unit malfunction.
Aug 03, 2011 | Canon ImageRUNNER 3235i Black and White...
My Canon Pixma MX340 printer keeps telling me that there is a document in the ADF and won't print. There is no paper anywhere and none has been stuck in the ADF but the message remains. I have tried...
Solution: Setting the MX340 back to default settings
Instructions to change the machine back to its default settings.
  1. Make sure that the machine is turned on.
  2. Press the Menu button repeatedly until Device settings appears.
  3. Use the l_mark_s.gifr_mark_s.gif button to select Reset setting , then press the OK button.
  4. Use the l_mark_s.gifr_mark_s.gif button to select one of the following, then press the OK button.
    Telephone no. data: Reverts the telephone number settings to default. Setting data: Reverts the machine settings other than the telephone number settings, such as the page size, media type, and other settings, to default. All data: Reverts both the machine and telephone number settings to default.
  5. Use the l_mark_s.gifr_mark_s.gif button to select Yes on the confirmation screen, then press the OK button.
Jul 10, 2011 | Canon PIXMA MX340 Wireless Office...
We have 2 Canon ImageRunner 3320N copiers, but they are behaving differently when they are being used as a scanner. On one copier, when scanning a double sided paper it will automatically scan each side....
it is in the copier settings. one is actually set up to automaticly do doublesided copies as a default. while the other one is only set up to do singlesided copies
first while on the main copy screen change the setting how you want the copier setup ..... double sided printing, black and white, or how ever you want your defaults to be set up
then you will need to goto the additional functions button and under copy settings you will need scroll down to the second page.
there you will want to hit the standard setting button then click the store button, then click yes... now it will default to the double sided copies.....
hopefully this will fix the problem if not get back to me
Jun 18, 2010 | Canon ImageRunner 3320N Copier
My e-Studio 3500c copier has 4 paper drawers, and one is set as LD (supposedly), but when we try to print to that drawer, it changes the paper size to 8-1/2x11 instead of legal size. We had a tech come in...
Once u setup the drawer paper size, make sure u tick the update automatically on the printer driver properties. Otherwise the printer driver wouldn't detect the correct paper size.
Dec 28, 2009 | Toshiba E-Studio 3511 Color Copier
HP PSC 2175 Printer reverts to "default printer" on PC re-boot
click on start ---settings----printer and faxes now from here u can make a default printer just right click on the icon of that print which u want to use and set it as a default print. or if u just want to revert back the current one just uncheck the option by right clicking on the icon
Oct 23, 2009 | HP PSC 2175 All-In-One InkJet Printer
Can the copy setting be defaulted to black and white document?
You can set it to B+W but it will revert to its default setting the next time you print.
Jun 30, 2009 | Lexmark X1150 All-In-One InkJet Printer
Ricoh Aficio MP C2550 does not default to one to one copy after use for 2 to one (front to back) the next person to use it gets charged for 2 copies when they only wanted one.
The machine should be set up so that it resets each and every time the card is ejected.
You might find the setting in user tools, but some where on the machine there should be a setting that resets the machine upon card removal. typically machine are set to reset after so many seconds of inactivity, but on coin and or card controlled machines you want the reset at card removal. You may have to have your service tech come in and set it up as it may be in Tech settings, if not in usee tools on your machine.
Hope this is of some help.
Ed
May 06, 2009 | Office Equipment & Supplies
Wrong count
FYI, if copy 1 side of A4, then is count as 1. If both sides, count as 2.
If copy 1 side of A3, then is count as 2. If both sides, count as 4.
That's the default settings on the MFP.
If u want to be copy 1 side of A3 and count as 1, u need to adjust the setting mode.
Press 08 and ON MFP, Enter 346, change "1" to "0".
Jan 28, 2009 | Toshiba Estudio 200L Copier
47 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
