My laptop boots up, and all the lights come on and everything works but my screen will not come on at all, not even dim. I have a gateway m675 17.1.
  • 177 Answers
You may have a faulty Inverter or loose connection.The nearest Computer Repair shop can test it for you.
Posted on Aug 21, 2008
6ya staff
SOURCE:
I have sony vaio vpceh25fd ,my screen was broken but was still working before i replaced it to a new one,after replasing the screen i am having a very dim display.even i tried the previous (broken lcd) its...
The dim display could be caused by a faulty inverter. The inverter supplies high voltage to the CCFL lamp that provides the back light to the LCD screen.
If your laptop appears to boot up and the hard disk LED flashes, then the problem is probably a back light fault. This can be a faulty inverter or a faulty CCFL lamp. Please click on this link and follow my instructions to identify the fault and possible fix :- http://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen
Apr 14, 2013 | Computers & Internet
No backlight
A) Replacement LCD screen backlight could be bad.
Happens. Sometimes you get a bad part. (Bad LCD screen assembly, in this case)
LCD screen may not be the correct one.
http://support.gateway.com/s/Mobile/2008/GodzillaFX/2528410R/2528410Rsp2.shtml
http://support.gateway.com/s/Mobile/2008/Godzilla/2528407R/2528407Rmv.shtml
A screen Inverter, and an LCD screen; are a MATCHED unit.
B) Screen Inverter:
May be bad, or the Wrong one
C) You may not have the screen Inverter, connected correctly to the Backlight.
Connections aren't tight.
D) The Display Cable TO LCD screen connection may not be tight, or correctly connected.
I know the display shows graphics, but a poor connection of Display Cable to LCD screen, can make the Backlight dim out.
I'm betting it is a poor connection, or the wrong screen Inverter, or wrong LCD screen.
Regards,
joecoolvette
(Be shame to kick that laptop to the curb. Nice laptop)
Jan 07, 2013 | Gateway P-6860FX Notebook
Gateway laptop screen darkens after boot up
Have you updated a Graphic driver? Does it Dim on battery and AC? Look at power settings. Control Panel, Power. You could Rool-Back the graphic driver to see if that changes the problem. A Gateway mt6841 has Windows XP OS, right?
Nov 27, 2012 | Gateway MT6841 15.4 WXGA SHINY LCD SCREEN
I have a Gateway 450ROG with very dim video on the display, I can hook up an external monitor and the video on the external monitor is fine but still very dimvideo on the monitor of the laptop. You can...
Hello !
Since an external monitor works, it is the display's backlight or inverter board.
If you were experiencing discoloration in the screen (pinkish lower light hues) before it failed, that would indicate a CCFL backlight issue. If the screen suddenly went dim on you rather than a slow degradation the inverter would be indicated.
In either case, a technician in your area should be able to help. Evaluate to see if the repair is cost-effective.
Hope this helps.
Oct 26, 2010 | Gateway 450ROG Notebook
Gateway notebook goes BLACK when connecting new lcd tv to laptop
try setting the frequency down to 60hz and the resolution before you connect. then if it works you can set it up again with a setting the TV likes
Jan 08, 2010 | Gateway MT3705 Notebook
Gateway 450sx4 has very dim lcd, almost invisible. otherwise it (the computer) is ok
Hello and thank you for using Fixya's services.
I have a couple of questions and some troubleshooting tips for you:
Questions: Is the splash screen coming on at all? Any picture or text right when you boot up? What Windows are you running (Windows XP or Vista)? Are there any lights on when you boot up or beeps? If so how many beeps do you hear?
First troubleshooting: If it boots up and is at least showing the splash screen (Gateway splash screen or text) then it would be that the operating system is corrupt. This can be caused by several things included viruses, power surges or hardware failure.
The solution for this would be to take the hard drive out and slave it to another working desktop computer to retrieve your data. The attach the hard drive back on and reformat it (I can add specifics to doing this once I know the operating system).
Second troubleshooting: If you hear the operating system chime but do not see a picture and all the lights are on, then this would indicate that the back light on the screen is out. You can test this simply by hooking the laptop up to a monitor and see if you get a picture. If the computer screen shows on the monitor, then your back-light is out. If it doesn't show up then your video graphics card is out.
If the back light is out, it is easier to order a new screen (new or used) from eBay and just switch out (simple process and you can find a replacement for under 50 dollars on eBay). If it is the video graphics card, then you can also purchase one from eBay and switch out (a little tougher because you have to take the top of the laptop off). You can get assistance with this from the manufacturers website and pull specs for free.
Third troubleshooting: If you do not hear any beeps and the above solutions did not work. Then your motherboard has failed. This can be caused by surges or dust. You can purchase a replacement from eBay for a fraction of the cost and replace (this is tough and I am not sure if they have specs for this). You can do it yourself, just be sure and put everything back together as it was.
Fourth troubleshooting: To test the battery, take the battery out of the laptop and turn on with just the adaptor. If it boots, then the battery will need to be replaced. There is no way of testing the power adaptor but 85% of the time, this is the problem. Even if lights come on, the adaptor sometimes gets so overheated that it silently goes out but gives just enough power to make the lights come on. The power adaptor can be found on eBay for under 20 dollars and is cheap enough to replace (first) to make sure that is not the problem. The battery can also be found on eBay for under 60 dollars.
Please let me know if you have any questions and I will be glad to assist.
Nov 05, 2009 | Gateway 450SX4 Notebook
My laptop doesn't boot up. Only get a black screen.
have you tried connecting to an external monitor?
Oct 15, 2009 | Gateway M285-E Notebook
I spilled juice on my gateway T-6330U laptop keyboard. I shut if off and pulled the power cord. I noticed it trying to boot up when cleaning it off, the LCD was fadding, and I heard sizzling under the...
Check the video connectors on the motherboard.
You may have a defective CCFL backlight, it may have the following symptom: Screen flashes on and off or displays reddish pink hue. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickers on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replace the CCFL lamp.
To determine if the video card or the LCD is faulty, connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight. It could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out, this is the most likely case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out LCD Parts for service, parts, and DIY info Use this link to their WEB site :-
www.lcdparts.net
Sep 21, 2009 | Gateway T-6330U Notebook
Booting
Has the fan been replaced? If not then the laptop will power itself off to protect from overheating. The fan is like a switch in the loop. Like old Xmas lights. One not working then none will work.
Aug 30, 2008 | Gateway M305CRV Notebook
Dim screen
If its very dark and you can barely see anything its probably a bad back-light. I'd suggest to take it to your local Best Buy. And yes, they can look up PSP#'s with your credit card, but even easier by telephone number.
Jun 24, 2008 | Gateway SL1450-30165297 Notebook
Open Questions:
how do i change my YAHOO password #{18OO~828O294} phone number usa asif There are two circumstances that can cause someone to want to change his/her YAHOO password: 1 forgetting the YAHOO password and needing to recover it and 2 to change the YAHOO password. The latter can be because the YAHOO password has leaked to someone or the user wants to adhere to the good practice of changing his/her password periodically. It is a good practice to change one's YAHOO password at least once in a month. Contact YAHOO Mail Password Reset 1-8OO-828-O294. For your convenience to contact YAHOO Mail Password Reset We have provided all possible information of YAHOO Mail Password Reset. You can contact YAHOO Mail Password Reset on the given phone number 1-8OO-828-O294. Changing an YAHOO Password The following steps show in detail how to change an YAHOO password when the current password is known: Sign into the YAHOO Mail Account from YAHOO Do you want to recover/reset your YAHOO email password? So you'll be do the some steps to recover your YAHOO password. We'll help you to fix your problem and we'll guiding the some steps to recover your YAHOO password. Follow and do the below steps to recover your YAHOO email password- Go to the YAHOO - login page. Enter your Username or Email address and click next. Click Forgot Password below the Password field. Enter your Email address and click Next. Verify your Email address or Phone Number and click on the Next. Open your Email account and check your YAHOO mail message on your Gmail account. YAHOO is an abbreviation for America Online, one of the country's earliest providers of internet and email services. While YAHOO's dial-up internet is not as widely used as it once was, many people still use the company's email service. It's a great email service that lets you stay connected with your family and friends -- that is if you remember your password. Forgetting your password on any internet service is an annoying and sometimes painful process; thankfully, YAHOO has made it easy to recover or reset your account's password. *Please Read* If you don't remember or didn't sign up with one your alternate email address, or you didn't use a mobile phone to register, you will not be able to reset your YAHOO password. If you find yourself in this situation, create a new account. If you do have access to your alternate email or mobile number, follow the steps below to reset your YAHOO password.
Oct 23, 2019 | Yahoo Computers & Internet
YAHOO customer service reset password #{18OO~828O294} phone number usa asif There are two circumstances that can cause someone to want to change his/her YAHOO password: 1 forgetting the YAHOO password and needing to recover it and 2 to change the YAHOO password. The latter can be because the YAHOO password has leaked to someone or the user wants to adhere to the good practice of changing his/her password periodically. It is a good practice to change one's YAHOO password at least once in a month. Contact YAHOO Mail Password Reset 1-8OO-828-O294. For your convenience to contact YAHOO Mail Password Reset We have provided all possible information of YAHOO Mail Password Reset. You can contact YAHOO Mail Password Reset on the given phone number 1-8OO-828-O294. Changing an YAHOO Password The following steps show in detail how to change an YAHOO password when the current password is known: Sign into the YAHOO Mail Account from YAHOO Do you want to recover/reset your YAHOO email password? So you'll be do the some steps to recover your YAHOO password. We'll help you to fix your problem and we'll guiding the some steps to recover your YAHOO password. Follow and do the below steps to recover your YAHOO email password- Go to the YAHOO - login page. Enter your Username or Email address and click next. Click Forgot Password below the Password field. Enter your Email address and click Next. Verify your Email address or Phone Number and click on the Next. Open your Email account and check your YAHOO mail message on your Gmail account. YAHOO is an abbreviation for America Online, one of the country's earliest providers of internet and email services. While YAHOO's dial-up internet is not as widely used as it once was, many people still use the company's email service. It's a great email service that lets you stay connected with your family and friends -- that is if you remember your password. Forgetting your password on any internet service is an annoying and sometimes painful process; thankfully, YAHOO has made it easy to recover or reset your account's password. *Please Read* If you don't remember or didn't sign up with one your alternate email address, or you didn't use a mobile phone to register, you will not be able to reset your YAHOO password. If you find yourself in this situation, create a new account. If you do have access to your alternate email or mobile number, follow the steps below to reset your YAHOO password.
update YAHOO password on computer #{18OO~828O294} phone number usa asif There are two circumstances that can cause someone to want to change his/her YAHOO password: 1 forgetting the YAHOO password and needing to recover it and 2 to change the YAHOO password. The latter can be because the YAHOO password has leaked to someone or the user wants to adhere to the good practice of changing his/her password periodically. It is a good practice to change one's YAHOO password at least once in a month. Contact YAHOO Mail Password Reset 1-8OO-828-O294. For your convenience to contact YAHOO Mail Password Reset We have provided all possible information of YAHOO Mail Password Reset. You can contact YAHOO Mail Password Reset on the given phone number 1-8OO-828-O294. Changing an YAHOO Password The following steps show in detail how to change an YAHOO password when the current password is known: Sign into the YAHOO Mail Account from YAHOO Do you want to recover/reset your YAHOO email password? So you'll be do the some steps to recover your YAHOO password. We'll help you to fix your problem and we'll guiding the some steps to recover your YAHOO password. Follow and do the below steps to recover your YAHOO email password- Go to the YAHOO - login page. Enter your Username or Email address and click next. Click Forgot Password below the Password field. Enter your Email address and click Next. Verify your Email address or Phone Number and click on the Next. Open your Email account and check your YAHOO mail message on your Gmail account. YAHOO is an abbreviation for America Online, one of the country's earliest providers of internet and email services. While YAHOO's dial-up internet is not as widely used as it once was, many people still use the company's email service. It's a great email service that lets you stay connected with your family and friends -- that is if you remember your password. Forgetting your password on any internet service is an annoying and sometimes painful process; thankfully, YAHOO has made it easy to recover or reset your account's password. *Please Read* If you don't remember or didn't sign up with one your alternate email address, or you didn't use a mobile phone to register, you will not be able to reset your YAHOO password. If you find yourself in this situation, create a new account. If you do have access to your alternate email or mobile number, follow the steps below to reset your YAHOO password.
i forgot my YAHOO password #{18OO~828O294} phone number usa asif There are two circumstances that can cause someone to want to change his/her YAHOO password: 1 forgetting the YAHOO password and needing to recover it and 2 to change the YAHOO password. The latter can be because the YAHOO password has leaked to someone or the user wants to adhere to the good practice of changing his/her password periodically. It is a good practice to change one's YAHOO password at least once in a month. Contact YAHOO Mail Password Reset 1-8OO-828-O294. For your convenience to contact YAHOO Mail Password Reset We have provided all possible information of YAHOO Mail Password Reset. You can contact YAHOO Mail Password Reset on the given phone number 1-8OO-828-O294. Changing an YAHOO Password The following steps show in detail how to change an YAHOO password when the current password is known: Sign into the YAHOO Mail Account from YAHOO Do you want to recover/reset your YAHOO email password? So you'll be do the some steps to recover your YAHOO password. We'll help you to fix your problem and we'll guiding the some steps to recover your YAHOO password. Follow and do the below steps to recover your YAHOO email password- Go to the YAHOO - login page. Enter your Username or Email address and click next. Click Forgot Password below the Password field. Enter your Email address and click Next. Verify your Email address or Phone Number and click on the Next. Open your Email account and check your YAHOO mail message on your Gmail account. YAHOO is an abbreviation for America Online, one of the country's earliest providers of internet and email services. While YAHOO's dial-up internet is not as widely used as it once was, many people still use the company's email service. It's a great email service that lets you stay connected with your family and friends -- that is if you remember your password. Forgetting your password on any internet service is an annoying and sometimes painful process; thankfully, YAHOO has made it easy to recover or reset your account's password. *Please Read* If you don't remember or didn't sign up with one your alternate email address, or you didn't use a mobile phone to register, you will not be able to reset your YAHOO password. If you find yourself in this situation, create a new account. If you do have access to your alternate email or mobile number, follow the steps below to reset your YAHOO password.
Computers & Internet Logo
35 people viewed this question
Ekse
Marvin
Marvin
