Question about Hotpoint HSS25GFP Side by Side Refrigerator
Ice maker auger not turning
I have removed ice bin and all ice that might be preventing auger from turning. There is no ice or frost build up at the back of the bin and I have chipped off the little ice from the motor prongs that engage the auger. Still, when bin is reinstalled and I push on pad to engage motor all I hear is a click and the auger does not turn. With the bin removed and door switch pressed in, I repeat this process and the motor prong does not turn, although I can turn it by hand. If the motor needs to be replaced, how do I do it? Many thanks for any advice you can give me.
  • 639 Answers
WELL DID YOU GET THE PLUG OUT OR END UP CALLING SERVICE ?AND FOR MY HONESTLY GOOD OPINION AND TRUTH IN ADVISING YOU!
YOU GAVE ME AN INAPPROPRIATE RATING AT FIXYA.COM
Shame on you! I know, sometimes the truth hurts!
BLESS YOU ANYWAY NGFAM1
There are many parts in this component that may be the culprit .
One or more will need to be replaced.
This is not easy to diagnose. I've seen service order parts 2 or 3 times till they completed the ice maker repair on a side by side fridge!
You need a hands on tech for this repair!
Posted on Sep 02, 2008
  • Neil
    Neil Sep 02, 2008
    Friend,
    ngfam1 At your service!
    I came to your service on fixya.com some days ago!
    And gave you some good advice!
    But, I did not receive a rating from you yet!
    Can you please give me a rating at our fixya.com site!
    Bless, You ngafm1
    PLEASE GIVE ME A GOOD RATING BEFORE YOU SIGN OFF
Frigidaire frs6lf7fm. Ice maker dispenser, the auger won't turn (tested with ttay out). It makes ice and dumps it into the bin no problem. And the water side is fine.
[FIXED] Icemaker auger motor won't turn - ApplianceBlog
www.applianceblog.com/.../18196-FIXED-Icemaker-auger-motor-won-t...
Apr 16, 2010 - 9 posts - ‎2 authors Does the auger motor need to be re-set or something? I wonder if it shut itself down to prevent burnout (because it had been unable to turn the ... FIXED Auger won't turn to dispense ice.
Jun 1, 2014
Ice maker auger will not turn
Mar 17, 2013
FIXED Ice Auger won't turn
Sep 3, 2012
GE Icemaker: Makes Ice, Doesn't Dispense In Door?
Apr 19, 2005
More results from www.applianceblog.com
Oct 01, 2015 | Frigidaire Refrigerators
Ice maker auger not moving ice when you press glass under
Remove the ice container and look in the slots or grooves where the container rests. You should find a build up of frost that is elevating the container slightly. When it is raised just a bit, the auger drive fails to engage adequately into the dispenser auger.
Use a hair dryer and a dry towel to sop up the frost melted with the hair dryer. Be careful not to use 'high' heat position as you could warp the plastic of the compartment.
Good Luck !!!
Feb 19, 2015 | GE Refrigerators
Whirlpool refrigerator ED5RHEXMT00 makes plenty of ice but is not dispensing any when the door lever is pressed. The water part is fine.
The ice bin slides down in little tracks and the drive mechanism engages the auger. It sounds like you have frost build-up in the bottom of the little slots that the ice bin rests in. The build-up keeps the drive from engaging the auger. I use a hair dryer to defrost all the accumulation under the bin once it is removed. Remove the bin by tilting out and then lifting up and out at an angle. Also empty the bin of ice cubes and check underneath for ice build up on the bottom of it too.
Dec 10, 2014 | Whirlpool Refrigerators
NEED PROCEDURE FOR REMOVING THE ICE MAKER FOR INSPECTION AND TROUBLESHOOTING. FRIG IS NEW...ICE MAKER NOT MAKING ICE !!!!!
Are you sure you have the ice bin properly in place?
Ice bin must be locked in place for proper ice dispensing. If necessary, turn auger driver behind ice bin counterclockwise to properly align ice bin with auger driver.
• Press the switch ON to activate ice maker. Slide bin into guide rails located on either side of the enclosure. Push the ice bin in until resistance is felt. Raise the front slightly and push the ice bin completely in. An audible "click" is heard when the ice bin is located correctly.
• After freezer section reaches between 0° to 2° F (-18° to -17° C), ice maker fills with water and begins operating. You will have a complete harvest of ice
approximately every hour.
• Allow approximately 3 to 6 hours after installation to receive first harvest of ice.
• Discard ice created within the first 12 hours of operation to verify system is flushed of impurities.
• Stop ice production by pressing the ON/OFF switch located on the front of the ice maker.
• The first one or two batches will probably contain undersized and irregular cubes because of air in the supply line.
• When the ice cubes are ejected it is normal for several cubes to be joined together at the ends. They can easily be broken apart. The ice maker will
continue to make ice until the supply of ice cubes raises the ice maker arm, shutting the ice maker off.
• Certain sounds may accompany the various cycles of the ice maker. The motor may have a slight hum, the cubes will rattle as they fall into an empty storage bin and the water valve may click or "buzz" occasionally.
Jun 01, 2011 | Maytag MFI2568AES Stainless Steel Bottom...
Everything works fine for this refrigerator except that when you press ICE on the control panel and insert your glass into the discharge area, the ice maker paddle (auger) does not turn to extract ice from...
Does the auger sound like it is turning ? If it sounds like it is turning there maybe a drive gear that is missing drive teeth or a shear pin has sheared preventing the auger from turning and despencing the ice
Dec 28, 2010 | Refrigerators
Ice maker makes noise when you try getting ice but arm doesn't spin
It sounds like the auger is not lined up properly this can happen if someone removes the ice bin to get ice. remove ice bin and ck auger for ice jamming it and try reinstalling bin. good luck
Aug 08, 2010 | Kenmore 54603 / 54606 Side by Side...
Ice dispenser will not dispens ice . light dims when pushed. ice maker works fine
It may be a good Idea to remove the ice bin, clean and dry ant the same time with bin removed see if while pushing the door light switch and the dispense ice control if the auger fork in the rear of the ice bin that normally turns the auger will rotate. Sometimes ice or water collects in the bin and locks the motor from turning and sometimes the motors go bad. Tell me your results, Thanks, Sea Breeze
Apr 23, 2010 | GE Profile 23.3 Cu. Ft. Counter-Depth...
Ge profile refrigerator ice maker
I have a GE Profile PSW26P Stainless Steel Side by Side refrigerator that makes plenty of ice but will not dipense when the lever is pushed. The dispenser makes not sound when engaged. What do you think the problem is.
Sep 28, 2008 | GE Profile PSW26P Stainless Steel Side by...
Ice maker dispenser and frost
outside moister cause making frost, probably you can not do it youself,if you know , do it.
Jun 17, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Ice maker will not dispense ice.
ON THE AUGER MOTOR IS A COUPLER THAT SLIDES INTO THE AUGER WHEN THE BIN IS INSTALLED. SOMETIMES, THE COUPLER WILL ROUND OUT THE FLAT SIDE OF THE CENTER HOLE. THIS WILL CAUSE THE MOTOR TO CONTINUE TO TURN, BUT THE COUPLER WILL REMAIN STILL DUE TO THE RESISTANCE OF THE BIN AUGER. ALSO, BE SURE THE ICE IN THE BIN HASN'T MELTED TOGETHER BINDING UP THE AUGER. IF NECESSARY, REMOVE THE ICE AND START OVER WITH FRESH ICE. YOU MAY NEED TO REPLCAE THE COUPLER OR AUGER MOTOR.
Apr 14, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Hotpoint HSS25GFP Side by Side Refrigerator Logo
525 people viewed this question
Top Hotpoint Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
