Question about Acer Aspire™ T180 PC Desktop
Audio problem the speakers won't work even though they connected properly and the power light is on, the system shows the yellow triangle against AMD Athlon ( tm ) 64 x 2 dual core processor 4000 + high definition audio controller pci standard isa bridge UMBus root enumerator usb mass storage device A FRIEND SUGGESTED I NEED TO DOWNLOAD THE "CHIPSET DRIVERS" ...... HELP !!!!
  • 177 Answers
Your friend is right,do it.
Posted on Aug 21, 2008
SOURCE:
Ouku single din no sound from rca cables
Sorry I did not use the video out RCA cables. My audio RCA cables worked fine... I ran them to my JBL amplifier through a conversion adapter. I did not run it direct to the amp.. I used Metra TYTO-01 03-08 Toyota Vehicles Harness for JBL SYS (Ebay item 160560648718) and it worked great.
Here is the wiring color coding that I found online:
Code on stereo for steering wheel is 0000
2011 Toyota Camry Car Audio Installation Diagram
F6 Pins:
1.Light Green (LG) Front Right (FR) plus (+) speakers source
2.Pink (P) Front Left (FL) plus (+) speakers
3.Grey (GR) Accessory power [switched on with the ignition switch] +12v
4.Light Blue with Yellow Stripe (L-Y) always +12v [radio memory]
5.Light Blue (L) Front Right (FR) minus (-) speakers return
6.Violet (V) Front Left (FR) minus (-) speakers return
7.Brown (BR) Ground (GND) radio ground
8.Orange (O) Antenna Amplifier (ANT) power source
9. No Connection
10.Green (G) Night Lighting [+12 when the taillights are turned on]
F7 Pins:
1.Red (R) Rear Right (RR) plus (+) speakers source
2.Black (B) Rear Left (RL) plus (+) speakers source
3.White (W) Rear Right (RR) minus (-) speakers return
4.No Connection
5.White Black (W-B) Lighting Intensity [Pull down circuit, voltage level drops {Bright Dash Lights}or raises {dim Dash Lights} Caution with this one, DO NOT CONNECT DIRECTLY TO +12 VOLTS, you will mess up your instrument panel cluster.
6.Yellow (Y) Rear Left (RL) minus (-) speakers return
F8 Pins:
1.No Connection
2.No Connection
3.Violet (V) Speed Pulse Connection (SPD) [Pulses from the speed sensors applied here. This is for the automatic sound level system. The volume raises when the speed is above a specified level, if enabled.]
4.No Connection
5.No Connection
6.Pink (P) Steering Wheel (Switch) Ground (SWG)[common]
7.Orange (O) Steering Wheel (Switch Group) one (SW1) [source for Seek+, Seek-, Volume+, & Volume-]
8.Yellow (Y) Steering Wheel (Switch Group) two (SW2) [source for Mode, (if equipped On Hook, Off Hook & Voice)
9.No Connection
10.No Connection
11.No Connection
12.No Connection
13.No Connection
14.No Connection
15.Orange (O) Auxiliary Right Input (ARI)
16.Brown (BR ) Auxiliary Shield Ground (ASGN)
17.Red (R) Auxiliary Left Input (ALI)
18.No Connection
19.Green (G) Auxiliary Input [Sense](AUXI)
20.No Connection
Car Radio Battery Constant 12V+ Wire: Blue/Yellow
Car Radio Accessory Switched 12V+ Wire: Gray
Car Radio Ground Wire: Brown
Car Radio Illumination Wire: N/A
Car Radio Dimmer Wire: N/A
Car Radio Antenna Trigger Wire: N/A
Car Radio Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Tweeter Size: 3 1/2? Tweeters
Car Audio Front Tweeter Depth: 2?
Car Audio Front Tweeter Location: N/A
Left Front Speaker Positive Wire (+): Pink
Left Front Speaker Negative Wire (-): Violet
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Blue
Left Rear Speaker Positive Wire (+): Black
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Red
Right Rear Speaker Negative Wire (-): White
Apr 02, 2014 | Crown Ouku 7" Car Dvd Player
Speakers will not work on e machine et1331g but are installed
Hi,Dear User..Flow instruction:-
1> Check you speaker all connection point.2> Check you connect speaker lead out put Point.3> Power point Check to speaker.4> Installed Audio driver to mother board. Not any other Driver install only proper driver.5> If driver install then check it. a> Go to control panel- Add or remove program, hear show audio driver or not. if not show then install.
b> My computer right click- property- hardware- device manager, if audio point yellow then install driver. if not yellow then install driver.
6> If all thing check then you speaker not support in you PC.
Note:- Batter then Contact good Computer Hardware Engineer.
More Computer Support.
Thanks...
Feb 13, 2013 | E-Machines eMachines Desktop PC
On 2001 Crown Vic, radio lights are on, channels change,etc but no audio. Fuse issue or any other possibilities?
sounds like your speakers aren't connected properly. check your speaker leads coming from your radio and make sure they are positive to positive and negative to negative. if you're using an external amplifier,check your RCA cables and your speaker outputs on the amp. make sure thr remote turn on lead is connected, otherwise the amp won't even power on.
hope that helped, good luck
May 31, 2012 | 2001 Ford Crown Victoria
We hooked them up to a Dell computer, but there is no sound. We checked the audio drivers and they are all working properly. What can be the problem and possible solution?
You can try to plug in an external headphone to see if the issue is with your sound card, if external headphone works, obviously the speaker is faulty but if same problem persist. Check if your using an expansion sound card (usually for gaming computers) and make sure it was set primary sound device on BIOS and the integrated Audio is disabled. On windows you can check the sound settings on playback make sure that primary Audio Device is Set to default and no Hdmi Sound Audio is connected Hope this can help you!
Dec 07, 2010 | Dell A215 Computer Speakers
I have a Gigaworks 750, the Audio Pod is not working, however, there is power going to the subwoofer though the power light is flickering. Hope you can help me in solving the problem. Thanks
I did fix this problem and the whole bunch of other ones with the s750 system.
"light is flickering" is a very common! It shows that there is a problem with STANDBY power supply:
1) Yellow glue became conductive (needs to be completely removed)
2) Capacitor malfunctioning C61 (68uF 450)
3) mine had TH1 cracked (replaced from PC power supply) and D9 diode.
If this successfully fixed, you will be able to get 2nd stage power supply on (Relay or power on button)
If you will have problems there, there is a whole bunch of test needs to be done (capacitors, IRF740 etc.)
Aug 29, 2010 | Creative Labs Gigaworks S750 Computer...
Inbuilt speakers not working
Since you limited the details. See if the speaker wire is connected properly and to the proper audio card connection. See if the speaked control panel is not set to mute output and see if the volume control is not at min.
As you plug in the speaker wire to the card with the PC on do you hear andy crackling noises at all.
If not see if the speaker hardware is powered amd the hardware dials are working.
See in the device manager that the drivers for the audio is correct.
Aug 23, 2010 | Lenovo Computers & Internet
The speakers on my computer are not working. When I look under properties, it tells me there are no speakers. I tried unplugging and replugging the wires. I know the speakers work, just not on my...
Hi GB
You need to check and see if your audio device is working.That's what will determine whether your speakers will work or not.
So,go to Start-Control Panel-System-Hardware-Device Manager (In Windows systems up to XP)
In Vista or 7,go to Start-Control Panel-Device Manager
Then look down to the Multimedia or Sound,Video and Game controllers category,name depending on Windows version.
Is there a yellow triangle or red x on the category anywhere? If there's a yellow triangle right click on that and select enable. And try your speakers to see if they're working now.
If there's a red x,your audio controller isn't working and Windows is almost definately asking for drivers.Double click the device and see what the next window tells you. If it needs drivers you can tell Windows to automatically install them,and to let Windows connect to the internet to look for them.
If you do have a driver problem and that doesn't work for you,look on the back or sides of your case,possibly even the bottom,for a sticker called the Service Tag.
Please post back with that code,your version of Windows and your exact model number,in case there were any additional letters or numbers,and I'll try and lead you to the drivers to download.
If this helps you out,would you rate my post please?
I'll be here
Bob
Aug 22, 2010 | Dell Dimension E310 PC Desktop
There is no sound from my speakers, even though the system says it is installed properly
Hi. There can be a problem with connection. Check if you have connected the speakers in green audio jack at the back of the computer.
Jul 16, 2009 | Dell Audio Players & Recorders
No LAN conection displayed in network connections
check that proper driver is installed, in the device manager that shows excmlatory mark that indicates proper driver not been installed, update the driver it will works
Mar 22, 2009 | HP Pavilion a6547c Refurbished AMD Desktop...
Microphone
Open system properities. click hardware tab & than device manager. Scoll down to Sound, video & game controller. Do you see a yellow ! point there. That means the driver may need to be reinstalled. Asus is famous for having defective mic controllers & yes the sound works but no mic. You can also open control panel open sound & audio devices. You should have the same device under Audio & Voice. If you do, again your intergrated mic controller is bad. Your manual most likely will not have the correct number to call tech. They moved in 07. So I'll put it in here: 812-282-2787Tech IL Eastern Time. Good luck!
Please vote...........
Jan 15, 2008 | ASUS M2N-MX Motherboard
Acer Aspire™ T180 PC Desktop Logo
140 people viewed this question
Ekse
Alun Cox
Steve Sweetleaf
Steve Sweetleaf
