Have a look at your reference guide. (adobe pdf format)
http://h10032.www1.hp.com/ctg/Manual/c00186904.pdf
Which operating system are you running?and describe your model of hp psc all in one scanner
First, start your computer and then plug in the cables that came with your printer. You must have at least one cable which connects the hp psc to your power outlet and one which connects the it to your PC. After you plugged all the cables, start the printer. To start the printer, you will either find a button that does this or it starts automatically. When it does start, it might do a "warming-up" sound or it might light a led so that you will know that is working.
Installing the printer
Now you have to install the appropriate drivers for your printer. Drivers are programs that drive the communication process between applications and devices such as your printer. If your printer is not detected and installed automatically by Window, then you will need to install the drivers yourself. They can be found on the site of hp or on the CD that comes with the printer. since you do not have the cds , then follow this procedure:
Click on the Start button and go to Control Panel.
In the Control Panel window, beneath Hardware and Sound, click on Printer.
In the Printers window click on Add a printer.
In the new window, select Add a local printer.
Now you have to choose the type of connection between your printer and your PC. Choose the type from the scroll down list and click on Next.
If you are not sure what to choose, read the printer's manual. Most modern printers use USB cables to connect to your PC. Older models may use LPT. If the cable looks like the one shown in the picture below, select LPT1.
Now you must go to your printer and check the name of the company that made it (e.g. Lexmark, HP, etc) and the model name & number (e.g. Lexmark Z52, Hp psc 4250, etc). In the next window you will see two columns. Go to the Manufacturer's column and select the name of the company that produced your printer and in the Printers column, select the model. Once you've found it, select it and click on the Next button.
If you cannot find your printer, insert the directory where you have downloaded the driver. Windows Vista will search for drivers and try to install them. Another option is to click on Windows Update and have Windows Vista search for drivers on the internet.
Now you can change the printer’s name and assign it as a default printer by checking the appropriate option. When done, click on Next.
The printer will now be installed. At the end you will receive a notification. Click on Finish and you are done.
If it hasn't said "You've successfully added ..." then click on Finish and you check the link below select your hp model and download the driver follow the instructions above when installing http://h20000.www2.hp.com/bizsupport/Tec...
Follow instructions from link below
http://h10025.www1.hp.com/ewfrf/wc/setupCategory?lc=en&cc=gr&lang=el&dlc=el&product=303736
I DO NOT HAVE A SUPPORT DISCE
