Question about Samsung Digimax A400 Digital Camera
Samsung digimax s700
Hi. My lens is stuck. it extends out only 1/16" - not even enough to grab. I get three beeps when I turn camera on, screen is dark. Please tell me how to fix this. I put brand new batteries in - still have problem.
  • 2,071 Answers
TIPS:
1.)NEVER PUSH THE LENS IN AFTER CAMERA DIES, BUY A NEW BATTERY IMMEDIATLY AND TURN IT BACK ON, CLOSING THE LENS!
2.)NEVER USE AN AC ADAPTER, USE A RECHARGEABLE BATTERY OR A REGULAR BATTERY!
..to fix this...
Do as i say..
1.) Remove battery
2.) Remove front plate (screw driver may be needed)
3.) Check all gears, make sure they are correctly fitted in place)
4.) Move the gear manually to make the lens come out.
5.) keep it out, put the front plate back together.
6.) reinsert the battery, turn it on.
or...
1.) Remove the battery.
2.) Wait about 6-8 hours.
3.) Reinsert the battery.
or...
2.) Try hooking it up through AC adapter, put correct voltage.
3.) Try turning it on.
4.) Remove AC adapter, reinsert battery.
5.) Turn it on.
If nothing happens just tell me..
Hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE
Posted on Aug 21, 2008
  • LORETO LACARON
    LORETO LACARON Aug 21, 2008
    Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on.
    Fix #2: Remove the batteries, then remove the memory card. Then install the new batteries, when you turn it on it should come back to life. Error E30 means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
    Fix #3: Insert the cameras AV cable, and turn the camera on in picture review mode. Have no idea why this would work, except that quite a few people have reported some success with it.
    Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
    Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
    Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
    Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
    Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera. The following photo illustrates unseated guide pins that would cause a lens error.
    DON'T FORGET TO RATE;
My camera turns on then beeps 3 times then shuts off is it broken or is there a reset button?
The three beeps mean that the lens motor is unable to extend the lens assembly.
This could be due to a low battery situation, but the most likely cause is the lens drive train stuck or jammed. You'll find generic instructions on solving some cases of jamming here.
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Unfortunately, more serious cases (due to falls, shocks, and most of all, the camera being turned on while some resistance prevents the lens from extending: e.g., if the camera accidentally turns on while in a pocket) require the repair shop.
Apr 27, 2010 | Samsung Digimax S730 Digital Camera
Samsung digimax s700 gives 3 beeps and turns off
The Samsung digimax takes standard AA batteries (but you already new that). The beeps sound like a flat battery warning.
A lot of reviews of this camera note its very high drain on batteries. Are you using good quality AA batteries (for example Duracell M3 or Energizer lithiums)?
If you are trying to run it with "very inexpensive" alkalines (or worse yet - common zincs), then you may proceed directly to flat battery warning, as they cannot provide enough sustained current to run it.
Feb 28, 2010 | Samsung Digimax S700 Digital Camera
Lens stuck in out position, beeps 3 times then off.
Just had same problem with mine, I wiggled/turned the lens a couple of times before turning it on, and it popped out of the stuck position and closed again. It's working - but clicking when I move the lens in or out.... :(
Jun 09, 2009 | Samsung Digimax S700 Digital Camera
Samsung L730 wont extend lens and dosent turn on right
Met the same problem. I disassembled camera and found a lot of sand in lens transmission. I couldn't move lens even by hand. It was strongly jammed. I had to disassemble lens block completely to remove all sand. Now camera fully functional.
Dec 15, 2008 | Samsung Digimax L730 Digital Camera
Camera not turning on
my camera just wont turn on period and just used it like half an hour ago
May 31, 2008 | Samsung Digimax D53 Digital Camera
Digimax samsung s500 beeps 3 times lens stuck wont stay on
Mine got stuck with lens out. The batteries were new so I never imagined it could be the batteries, but they were cheap ones so I recharged a pair of good ones and once I put tried them on it worked just fine again. Conclusion, the "new" cheap batteries had only enough energy to turn it on and then they couldn't give it enough energy to make it work anymore and that's why I couldn't retract the lens or even turn it off properly. So in your case, try using a couple of good and new batteries.
Dec 14, 2007 | Samsung Digimax S500 Digital Camera
Samsung Digimax S700 is frozen with lens open
I had this same problem, and all i did was pop out the SD card, and tried turning it on without it in there.  It powered up just fine.  I then replaced the SD card and all was well.  Possibly a problem with teh SD card.
Nov 30, 2007 | Samsung Digimax S700 Digital Camera
Jammed camera
A temporary fix to power up is to press the menu and power button at the same time. When the lens is extended and it beeps, on my camera , the lens is *stuck* Give it a gentle tug , then try the power button again
Oct 19, 2007 | Samsung Digimax S800 Digital Camera
Camera turns on for three seconds, beeps three times, then stops.
It's the optical zoom. The motor that pushes it in and out died.
Oct 10, 2007 | Samsung Digimax S700 Digital Camera
It dont turn on
I had the same problem. Try to turn it on, 3 beeps and then it would shut down. Screen would come on for that time. Also, the lens was stuck open. It wouldn't close.
I twisted the lens (gently) and it appeared stuck. A gentle screw motioned seemed to free it. I hit the power button and it come on, but this time no 3 beeps and shut down. I then turned it off and this time the lens retracted and closed.
So, it appears that if the lens gets stuck open, it has a shut down feature that doesn't allow the camera to go further into its operation modes. I believe this stuck open problem occured on our camera when the batteries went low.
Again, a second of gentle twisting seemed to unstick it and with fresh batteries in, it was able to operate and shut down properly.
As far as batteries, I use the rechargeable Ni-Cad 2500 mA. They last a while.
Blessings to you!
Jun 02, 2007 | Samsung Digimax S500 Digital Camera
Samsung Digimax A400 Digital Camera Logo
145 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Samsung Camera Expert? Answer questions, earn points and help others
