Please AVOID answering questions of which you know NOTHING.
1. Remove the lower panel under the door by loosening the three screws under the bottom edge on the front of the washer. HINT: If you prop up the front feet of the washer with some small blocks of wood, this will make access to the screws much easier. 2. With the screws removed, the lower panel should drop down then come off. If the panel sticks, a light tap on either side will knock it loose. 3. Reach your hand up inside the washer behind the front casing on the right-hand side. This is where the door latch assembly is located. 4. At the bottom of the door latch assembly is a small pull tab. This is the manual release for the door. Pull the tab straight down and the door will come open. (Tip Courtesy JSRock)
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
"F22" is a door latch failure error code. At the beginning of the wash cycle the door will attempt to lock several times. If the latch fails to lock, the washer shuts down and the error code is displayed. The following link explains how to troubleshoot and repair:
In some cases, the error code can also be displayed if the CCU goes bad. There is a door latch relay on the board that controls the door locking mechanism. The CCU is not serviceable and must be replaced if defective. In addition, make sure all the connector plugs between the CCU and door latch are connected and snug.
There is a tech sheet located inside the washer behind the lower kick panel under the door. Refer to your tech sheet for more detailed information concerned connector plug numbering and troubleshooting of the CCU.
If you still have questions, please let me know. I hope this helps you.
This error code indicates that the door is not locking. Is the washer door firmly shut? The door must be completely closed for the washer to operate. The door may look as if it's closed, but it may not be latched. Open the door and firmly close it. Were you washing a large load? Before you close the washer door, check for laundry items sticking out beyond the door opening. Leave enough space in the washer to allow the clothes to freely tumble. Reduce your load size if needed.
Is there a dl code? If not note the door striker position as the door closes. If you have to push it shut you need a door lock and if the striker is hitting below the latch too much a hinge will fix it. Finally look for a black pin above the striker for any damage as the latch will need to be replaced if broken too. Because with this and a door hanging low will not close the circuit and the ccu will believe the door is open also.
