Hi,in Auto scanning menu the country option is stuck on Austria.It was working fine and had scanned all english channels on digital but is now stuck on Austria.It is an internal Freeview model so now only have analouge.
It needs factory remote reset. This sound wierd but it will fix it and you need to be handy with a soldering iron. Open up you remote control and solder 2 wires onto pins 15 and 21 of the micro. Re assemble your remote and leave these two wires poking out. Point remote and set and touch the wires. It will say test. Type in 01 and drawer will open. It should now be back in uk mode.
Does work. Remember the pins on the IC are numbered anticlockwise with the dot as no.1 Turn the remote so pin 1 is nearest you on the right. When TEST appears press 01 before it goes out. Once CLR appears on display, turn machine off for a moment, then once it is back on it should say AUTO and tune itself.
I have shorted out pins 15 and 21 as said here but test does not come up, what do I do now and why as it gone like this in the first place, is the not a combination of buttons you can press on the remote to get into enginers settings and test mode?
please get back to me as i'm at my witts end here and it's still stuck in Austria.
where to find a region code hack for lg lra 850. If in setup menu, what letters (2) do I need to...
(More)
where to find a region code hack for lg lra 850. If in setup menu, what letters (2) do I need to enter to be able to play both American and European DVDs?
LGDR787T won't read DVD's. Took it apart and cleaned laser pickup but still sam eproblem. Says...
(More)
LGDR787T won't read DVD's. Took it apart and cleaned laser pickup but still sam eproblem. Says unrecognized disc. Needs a new drive. Is there a good place to pick up a drive for unit.
