Question about Sansui DTV2760 27" TV
Please Help I have had the Sansui DTV2760 27" TV for much over 1 year, and it wont come on. I push the power button and i get nothing. First it started by toggling to aux1/aux2 while I was watching a program, TV went completely blank, I couldn't turn it off by remote so I unpluged it.I've pluged it back in and now it wont come on at all. Can You Pleas Help Me, with what could possibly be going on Thank You, Tamara
  • msxxplorer Aug 21, 2008
    Thank you, I appreicate you trying to help.. I see this is not an easy fix! Im not technical enff to handle this matter. Can I ask if I was to take it to the a repair shop approx how much it will cost to fix?
  • 2,071 Answers
First, locate the horizontal output transistor. This is found very close to, or next to, the horizontal output transformer (also known as the flyback). The flyback should be on an aluminum heat sink, or on the side of the metal chassis. Disconnect or unsolder two of the three legs of the transistor. Measure it with your meter, or plug in the set with the light bulb attached across the fuse.
If the transistor is shorted, or the light bulb doesn’t glow bright anymore, replace the transistor and plug back in. If the light bulb glows bright again, you must replace both the flyback and horizontal output transistor simultaneously. In some cases this will fix the set, but sometimes there are multiple problems with a set.
Go to where the flyback is, and start measuring the diodes and capacitors on the flyback itself. If you don't find any shorts there, it could be a shorted vertical output IC, a shorted sound IC, a shorted disc capacitor in the Hi Voltage/sweep circuit, or in rare cases, a shorted capacitor or tuner.Feel free to ask and post whatever the result of your troubleshooting..
Hope this may help;
Posted on Aug 21, 2008
Tv not coming on has a blinking power button
Toshiba CX36F85 36" TV Blink - Questions - Fixya > ... > Toshiba > Toshiba CX36F85 36" TV
Toshiba CX36F85 36" TV, blink related issues. ... Every brand TV will have its ownblinking ... stand by light blinks 6 times, wont power on tv is only 4 years old. ...From the number of blinks occur at one time switch ON, you can get an idea ...
Toshiba CX36F85 36" TV Blinks - Questions - Fixya > ... > Toshiba > Toshiba CX36F85 36" TV
Toshiba CX36F85 36" TV, blinks related issues. Get free help ... Every brand TV willhave its own blinking codes. From the ... Push power button and it ... and then ... stand by light blinks 6 times, wont power on tv is only 4 years old. Junk! it wont ...
Toshiba power light blinking not turn Standard (CRT ... - Fixya > ... > Standard (CRT) Televisions
Jan 10, 2016 | Toshiba CX36F85 36" TV
My sansui LCD TV won't turn on or do I have volume any ideas to fix it
What do I check if my Sansui TV Model SLED2490 will not ...
iFixitJul 9, 2014 - A friend of mine gave me a Sansui TV after a power surge caused ... led ·sansui · tv power ... The most common problem that I've researched and experienced with your tv's is that when they get unplugged, the wont turn on, just stay in ... though they'll still be frustrated, they won't trash their tv and go get a ...
I have a sansui tv and it wont turn on but is getting power ...
Nov 28, 2015 | Sansui Televison & Video
Tv wont come on at all..push the power button.. nothing, use the remote..nothing, not even a flicker...please assist
hi..this is probably an issue with the power supply
of the tv.check the power supply.
thank u..
kindly rate my response..
May 09, 2009 | Protron PLTV-37 37 in. LCD Television
Unlock child proof lock on Sansui TV
you can try it by pressing the power button and the tv/av  button at the same time, that worked for me ,My tv is about 8 years old
Jan 15, 2009 | Sansui TVM1916 19" TV
Insignia TV code for RCA Universial Remote Control (RCR450)
If its a four digit code remote. I may be able to help.. Try these...0171, 1204, 1326, 1517, 1963, 2002..
Good luck
Nov 11, 2008 | RCA 4-in-1 Universal Remote Control
I get a dark square in the middle of the picture after about 1 minute of play on one channel
Press closed caption button on remote repeatedly until nothing about closed captioning come up on the screen.
Aug 25, 2008 | Sansui TDC2075 20 in. TV/VCR/DVD Combo
on some tv's you can get to the menu by pushing both the channel up and down buttons at the same time.
May 04, 2008 | Sansui COM311AD 13 in. Combo
Universal remote wont work with this TV
Questions: Who is "Sansui", the digital box ? or the TV? Is the "digital box=remote control"? turn on what you want to control.
Face the RC face down or away from TV,or whatever you want to control. Usually:: push & hold TV & SEARCH button until light blinks, two, three times? FACE THE TV and put the code for the [TV=Sansui ?] You said #189 try 0189 [zero,one,eight,nine]
2nd) TV power ON!,....HOLD down (and if you have a SEARCH) button and the tv power button on RC, two or three blinks, push up arrow once, press power button for TV on RC, nothing!, continue...up arrow, power button. when the TV turns off, you have found the code,. YOU MAY HAVE TO DO THIS 50-150 TIMES because the RC is looking through EVERY code!
Apr 26, 2008 | Sansui CDVD1300W 13 in. TV/DVD Combo
Tv just wont turn on
power supply fault it could be any component if not qualified dont risk taking a look inside, high voltage supply.
Oct 14, 2007 | Panasonic (LSSQ0372) Remote Control
Sansui DTV2760 27" TV Logo
70 people viewed this question
Top Sansui Televison & Video Experts
matt martin
matt martin
Are you a Sansui Televison and Video Expert? Answer questions, earn points and help others
