Question about Bosch Axxis+ WFR 2460 Front Load Washer
Cleaning filter the place we rented has a Maxx Bosch Washer, and I have been unable to unscrew the fluff filter to clean it (I think it is on the lower left hand corner, it hardly turns) how can i take the filter out? thanks
    President:
  • 1,462 Answers
It just unscrews - take a pair of pliars to it
Posted on Oct 16, 2008
My Bosch wfmc2100 continues to add time to the timer and when I place it in spin mode I hear pump come on and drain but it acts like its still agitating the clothes and never Ramps to speed.
Some times if you wash large and small items the washer cannot get the clothes balanced enough to go into high spin. The washer being out of level can also cause this problem. Another issue that can cause this is the drain fluff/filter is plugged a bit and wont let enough water to the drain pump fast enough and when the timer sees that there is still water in the drum it adds more time to allow for the water to be removed. front bottom access panel will get you into the fluff/filter to clean it out. Make sure to get all the threads clean of sand and debris and use light oil to replace the cap or you will break it trying to reseal it.
Jul 29, 2016 | Bosch Washing Machines
How do I clean the filter on the Novotronic W 310 Miele washing machine
Cleaning the fluff filter and pump
Check the fluff filter initially after 3 - 4 washes to ascertain how often it is likely to require cleaning. With normal cleaning approx. 2 litres of water run out.
If the drain outlet is clogged, more water will be retained in the machine (up to 25 litres).
Caution: if laundry has been washed at a high temperature,
water draining out of the machine will still be hot!
Take the (yellow) filter flap opener from behind the detergent drawer facia panel. Open the flap.
Place a dish under the drain fixture. Turn the fluff filter lid round 2 - 3
times. Do not take it right out.
With large volumes of water when the dish is full, screw the fluff filter back into position and empty the dish before repeating the procedure.
Once the flow of water ceases, remove the fluff filter completely and
clean it.
Remove any foreign bodies (e.g. buttons, coins, etc.) and fluff.
Turn the impeller by hand to check that it is free to rotate. Any foreign objects causing an obstruction should be removed.
Clean the inside of the fluff filter housing. Remove any deposits of lime scale and detergent or foreign bodies from the thread of the filter housing and filter unit (as these objects can cause a leakage
of water). Put the fluff filter back and screw it in firmly.
Cleaning and care
To clean the water inlet filters
The washing machine has two filters to protect the inlet valves. These filters should be checked every 6 months or so, or more often if there are frequent interruptions to the water supply.
To clean the filter in the union in the open end of the inlet hose:
First turn off the stopcock.
Unscrew the threaded union connecting the free end of the inlet hose to the stopcock.
Remove the rubber seal from the recess. Using pointed pliers, take hold of the plastic filter bar, remove the filter and clean.
Put the filter and seal back in the reverse order and reconnect the
hose. Turn on the stopcock and check the connection is watertight.
Inspect the inlet hose which is subjected to high pressure while the machine is in operation. The hose should be replaced if there are small cracks in the surface, or if it has been otherwise damaged.
If replacing the inlet hose only use a hose able to withstand pressure up to 70 bar. Miele's own hoses meet this requirement.
To clean the filter in the water inlet valve:
Using pliers, carefully loosen the ribbed plastic nut on the inlet valve,
and unscrew.
Use water pump pliers to withdraw the plastic filter by the bar.
Clean, put back and secure.
The two filters must be put back in place after cleaning.
Mar 08, 2015 | Miele W310 Front Load Washer
How do I find clean the filter of our bosch maxx classic 900 rpn front loader? I can't even find the filter.
Filter is located bottom left of machine it has a small black hose tucked inside ,you would remove the Plug on the end of the hose and drain any excess water into a container then unscrew the filter anticlockwise to remove the filter any object within will now bw apparent... Good luck.
Feb 16, 2015 | Bosch Washing Machines
I have a Bosch classixx 1200s Expresss. When I press the start nothing happens and a get a 12 beep alarm (4 then 4 then 4) every 60 seconds. There is power and water
I'm not an expert. I just had the same error (on a Bosch Maxx 6) and fixed it by chance.
My area has a lot of debris in the water supply, and it turns out that the small filter in the hose connected to the water supply was completely clogged up. You can either replace this filter, or clean it as outlined below.
Here are the steps to cleaning it:
1) Unplug washer
2) Turn of the water supply, either by a turning the handle to the washing machine water supply or by turning of the water main.
3) unscrew both ends of the water supply hose
4) Screw the washing machine end of the water hose into the water supply outlet
5) On the other end of the hose, there is a small filter. Hold this in place with the tip of your finger, and turn on the water supply for a few seconds, while keeping the free end of the hose in a bucket. This will flush water through the filter in reverse, thereby cleaning it. Do NOT reverse water flow with one end still attached to the washer machine, as this will flush all the debris into your machine!
6) Turn of the water supply, unscrew the water hose, and reconnect both ends as specified by the manufacturer.
Hope that helps!
-Dennis
Apr 07, 2011 | Bosch Classixx WFL 2066 Front Load Washer
Cannot get out and clean the washing machine lint filter. We can open the service flap and unscrew the pump cover, but the lint filter does not come out. Our washing machine ia a MAXX Classic. Thank...
Manual is here...
https://portal.bsh-partner.com/TCcustomBSH/controller/download_file?PDFOBID=rhdu2Hjcdcso0pdmdb---hNm&UMOBID=rhdu2Jhcdcso0pdmdb---hNm
Go to page 26 for instructions.
Mar 20, 2011 | Bosch Nexxt 700 Series WFMC6401UC Front...
Bosch maxx 1200 has stopped draining half way through the cycle?
Probably a blocked filter.
This is located at the bottom front right of washer.
Unscrew anti-clockwise to remove and clean.
Have bucket and cloths ready!!!.
Feb 13, 2010 | Bosch Washing Machines
Bosch Maxx Classic wont drain cannot open drain cap seems jared is there a correct way
The correct procedure for removing the filter is to unscrew it anti clockwise, and pull it out.
If it does not come out, then it is possible that there is something stuck in the filter, or the filter seal has swollen
As you unscrew it, try moving it from side to side at the same as you are pulling on it, then screw it back in again, and try the same procedure.
Hope this helps.
Dec 21, 2009 | Bosch Classixx WFL 2066 Front Load Washer
My Bosch Maxx 2000 WFO 2060 is leaking from the bottom. Could it be that a filter somewhere needs to be cleaned? If so where is the filter located?
The filter is usually located at the bottom right front of washer, sometimes behind a removeable cover, or a drop down flap.If you can locate it, then unscrew it anti-clockwise to remove and clean it.
There is also a possibility that there could be a hole or tear in the door seal so check the seal as well.
Hope this is of some help to you .
Dec 07, 2009 | Bosch Washing Machines
Is there a filter that I can clean out located behind the round cover on the lower right front of my Bosch Nexxt 500 series washer?  If so, how do I get the cover off?
just pop it off with a small srewdriver and yes you can get to the fluff filter through the round cover
when you open the filter there will be about two litres of water come out beware
Jan 21, 2009 | Bosch WFMC 3200 Front Load Washer
Bosch Axxis+ WFR 2460 Front Load Washer Logo
284 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
