My Grundig TP 711 TV has good signal, but the vcr channel (channel 8) has started making alot of unnecssary noise. Do I need to re-tune it? If so, how?
4 Suggested Answers
SOURCE:
  • 121 Answers
SOURCE: tuning
please post your model number and I may be able to post a link where you can get a user manual for your tv
Posted on Apr 23, 2008
  • 9 Answers
SOURCE: Trying to tune a UMC
The tuner is probably faulty. Got the same tv, no probs.
Posted on Mar 10, 2009
  • 8457 Answers
SOURCE: TV is making a loud ear piercing noise.
Ur high voltage is going through FBT,the big black block of plastic with a wire red or gray solder to the board.The Flyback transformer.There a steel "3 inches like a paper clip like steel.Put some supper glue on that "3 steel paper clip look like, will help or stop loud wishling noise all together.
Posted on Apr 22, 2010
How do I tune a Grundig TV/DVD with no remote? Is it a combination of buttons on the front panel? Thanks
Get a pen and a piece of paper.
If I remember correctly, each button has a bizarre symbol next to it.
Draw the buttons on the paper and draw the symbol that appears beside each button.
With the TV on, press the first button and note what it does. Press it a second time to see if that progresses to something further or cancels the operation.
Repeat this for the other buttons.
I seem to remember a vertical green line appearing on Grundig sets which indicated that the tuning was activated. Look for buttons such as > or >> or < or << that suggest scanning for channels. Make sure you can pick up analogue TV signals in your area.
It also helps if you have a VCR or DVD recorder which is already tuned and you can tune the TV to that signal.
Jan 06, 2015 | Grundig 15 in. LCD TV/DVD Combo
Grundig tv loses the digital channels
Did you try disconnecting the TV for a few hours to reset it?
Mar 03, 2008 | Televison & Video
User owner's manual Grundig T55-732/5 text
Dear......
My father in-law who has died used to own a classic 14" Tv Model T 20-6210/6, with a remote control Model TP 711, when I switch it ON a Key with 4 stars shows up, I tried few numbers including 0000, but unfortunatly no luck,
pls. advice for the following:
1 - what is the (manufacturer) original password (key password)
2 - If I need to reset it where is that and how
3 - I need to reprogram the TV how is that
Knowing that :
- I do not know german language and I have been adviced by Grundig main site to download from Buchproduktion.......
Many thanks in advance
Eng. Nazir Touma (Lebanon)
May 13, 2010 | Televison & Video
Connect vcr to jvc c2033us tv
You will need to put your aerial into the rear uhf socket of the VCR then take another connecting lead (flylead) from the out of the VCR & put this into the aerial socket of the TV. You will now need to select a channel on the TV (best to use channel zero) & tune the TV to the VCR signal. The best way to do this is to put in a recorded tape eg a film /press play/ then tune the TV until you pick up the playback of the film, then store this on the TV. This will give you your VCR channel. You will now need to tune the VCR to your broadcasted stations so that you can record.
Apr 01, 2009 | JVC Televison & Video
Tuning a Grundig Tele Pilot 750c Television
It might be an old hotel tv. Try this, it worked for me
http://www.tvtuning.co.uk/makes/grundig.htm
basically you hold the i button whilst turning on the tv.
ta
Jan 07, 2009 | Grundig GF70-600 TV
How to tune to tv channels
There is a switch [tv-vcr] somewere in the front.When pressed to tv, you can change the channels FROM the vcr.You will need an "air wave" ANTENNA signal because the cable box individual channels cannot be seen when you place the switch to tv.Now if you have a cable box connected properly and turn that tv-vcr switch to vcr the individual CABLE BOX CHANNELS will show through the vcr.
p.s. There is a small switch (someware in the back of the vcr & the back of the cable box,dish box, etc., etc.) ch.3 or ch.4 and the VCR have to be on the same INPUT channel as the box.
Dec 09, 2008 | Televison & Video
Panasonic NV SJ205 changing RF settings
Your VCR has input to record video-audio signal. Here is 2 options to record program in vcr.
1= You need to hook up video-audio cable at Monitor Out in TV and video-audio in at VCR. select Line-1 or Line-2 (where you hook up cable) in vcr and insert cassette with Record Tab intact, VCR is ready to record TV program. select desired channel on tv and hit record button of vcr, recording will start.
2= Plug RF antenna / cable wire in RF In of vcr and tune desired channel in vcr (get help of vcr's user manual for that) and push record button to start record directly in vcr.
Have further query, let me know please.
bye.
Sep 09, 2008 | Panasonic NV-SJ205 VHS VCR
Grundig TV - Tuning DVD & VCR
Hi there!
If the DVD recorder has an RF out then you should be able to tune it on UHF bandwidth. The cable should run from the RF Out on the recorder to RF on the TV. Switch the recorder on, put in a DVD and press play before tuning. Some DVD's require a disc before a Menu appears. Good Luck, Regards, JUS004
Mar 23, 2008 | Grundig GF70-600 TV
How to tune an old Television
If you are in the US, the TV set has to be on channel 3 or 4, if your in the UK, the TV would have to be on a UHF channel. It should say on the RF output of the VCR what station you must tune to ,or in the instruction book of the VCR. Good Luck
Mar 25, 2007 | Philips 26PW6341 26" TV
Toshiba tp50f60
1. Check the TV's horizontal and vertical hold. 2. If there is a VCR connected: Shut off the VCR. If the problem clears up, the VCR is not properly ?fine-tuned.? Turn the VCR on and troubleshoot the VCR problems. 3. If a converter is connected to your TV and VCR: The VCR needs to be on channel 4. VCR may not be ?fine-tuned? to channel 4. Locate and adjust the fine-tuning mechanism until the picture comes in clearly. The <3/4> switch may be in the wrong position. Locate the switch on the back of the VCR and set it to <4>. 4. Check the fine-tuning of your TV. good luck :-)
Jan 11, 2006 | Toshiba TP50G60 50" Rear Projection...
Televison & Video Logo
279 people viewed this question
Top Televison & Video Experts
Ekse
