The apect ration control on my pioneer plasma is stuck on full
  • 125 Answers
Please go back to the customer menu and check if you did set the tv only full option. if everything is ok let me know I will see what else can do.
Jose
Posted on Aug 21, 2008
Is my Pioneer 50" plasma PDP-503HDE HD ready?
Yes it is but upto 720P only. It is not full HD(1080P).
Jan 10, 2011 | Pioneer PureVision PDP-503HDE 50 in....
I have a Pioneer PDP-5030HD plasma and the plasma display does not turn on. The standby/on power indicator light on plasma display is blinking red (after turning it on with my remote, it turns green for a...
First check batteries in the remote are charged.Try pushing one of the channel selection numbers on the remote as it may be the off/on on your remote is stuck or has died completely. if this does not fix the problem try unplugging the set from the wall wait 5 mins (approx) and re plug into wall socket and try turning on .
Oct 25, 2017 | Pioneer PureVision PDP-5030HD 50 in....
I have a pioneer pdp 5040 plasma and it just died on me. It will turn on then turn off after 3-4 sec. The standby light flashes 3x pauses then flashes 3x again, can I fix this
PDP-5040 turns on then off after 3-4 seconds / display in upper right corner says user full and record timer led is lit on box / rrepairable?
Sep 27, 2010 | Pioneer PureVision PDP-5040HD 50 in....
Pioneer pdp5000ex code for remote
I assume you want the remote code so you can program an universal remote? The "code" for the remote is specific to the vendor of the remote control you purchased not the TV per-se. The directions for the remote control should have a full listing of all brands it supports. usually it has several options for each brand and unfortunately you have to try them all to find out which one best matches the features of your TV.
Sep 21, 2010 | Pioneer Elite PRO-1140HD 50 in. Plasma...
I am unable to reset my pioneer deh p4100. I see
remove the unit and disconnect the battery+red and yellow cables.check the front unit for derfomed plastics or stucked somehow microswitches!someone stucked from the heat!
Jun 05, 2010 | Pioneer DEH-P4100
Pioneer PDP435PG inadvertently reprogrammed by Casablanca remote.
Some ceiling fans have jumpers that can be moved to select a different frequency but you have to be sure both the remote and the fan receiver are set the same. Other than that, you may have to use some creative control. For example, I can turn on my TV by pointing the remote at the wall opposite the TV
Mar 29, 2017 | Pioneer PDP-4350HD 43 in. Plasma...
I cant get the fans to turn on!!!!!!!!!!!
Call up the 'Integration Menu" - the fans can be switched between 'auto' and 'full speed'.
To do this switch the display into standby. If the standby light flashes 4 times it is indicating a fault in the Thermal Sensor Assembly which will explain why your fans aren't working. With the display in standby press the menu button and within 3 seconds press the power button. The display will turn on with the integration menu. Select the option tab and scroll down until you see 'fan control' - press 'set' to toggle between 'auto' and 'max'. When you select 'max' the fans will run at full speed within a few seconds. The fans are a bit noisey at full speed so you may want to look into replacing the sensor eventually.
Feb 19, 2009 | Pioneer PureVision PDP-503CMX 50 in....
Televison & Video Logo
27 people viewed this question
Top Televison & Video Experts
