Question about Frigidaire FRS26R4A Side by Side Refrigerator
Water filter leaking
Everything was just fine until I changed my water filter on my side by side frig. Now water is leaking from the filter inside the refrigerator. I've changed my filter many times without a problem, but now the cup that covers the filter is filling up with water and overflowing onto my top shelf. It is a frigidaire pure source plus
  • Anonymous Mar 18, 2014
    red filter light stays on although both filters have been changed. Inside and outside the fridge
  • Anonymous Mar 21, 2014
    filter cup does not seat correctly and water is leaking from the top of the cup
This happened to me and was the o-ring, the cup is sealed by the o-ring and in my case I did not realise it dopped off after I unscrewed. Either your o-ring is missing or needs replaced as it is worn out.
Posted on Aug 24, 2008
  • Ciri Evans
    Ciri Evans Nov 08, 2013
    Where do you get the O ring and where does it go on the filter?
I have a side by side whirlpool, water was coming out fine then replaced with new filter and a month went by the water started to come out very slowly I thought the filter may be plugged so put anothe
Cut water supply off to frig disconnect water supply line to frig water inlet valve turn water back on to make sure you are getting good water supplied to water inlet valve some times water cut off gets stopped up. If you are getting good water flow to water inlet valve then check to make water valve is opening up all the way. if not then replace valve.
Oct 27, 2014 | Whirlpool Refrigerators
Why is there water dripping from the bottom of the water/ice dispenser
The solenoid valve that controls the water dispenser is leaking internally. It will be a double valve (one for ice, the other for chilled water) located at the bottom of the frame in the back of the unit. To find it, just trace where the plastic tubes originate from.
Easy to replace.
These leaks are sometimes caused by particles getting trapped on the valve seat. This can be prevented by use of an inline water filter on the copper supply line.
Oct 20, 2014 | GE Profile PSW26P Stainless Steel Side by...
I have a Dometic RV frig and a week ago it started to smell of spoiled dairy. I cleaned every surface and checked all the refrigerated products, but the smell continues and is getting worse. Please
My rv refrigerator doesnt have a drain but I do know how to get stink out of a refrigerator providing everything has been wiped up. My freezer at home was accidentally unplugged for weeks with two bears and half a deer in it. Life altering stink ensued. I tried every kind of cleaner and procedure including running it with charcoal briquets in it. Nothing worked and I was getting ready to throw it out until I was told to wipe it down with vanilla extract. It worked immediately and has been fine ever since. Cheap and easy.
Jun 10, 2017 | RVs
Water flow is extremely slow after filter change.
Those filters are for refrigerators that have heavily treated water in the household. You could have a filter that filters your water supply and not use the filter inside the frig. Why use both? Now, if your home is not filtered, you may need it. Check to see if the water supply line is crimped somewhere or frozen when it gets inside the frig.
Jul 15, 2010 | GE Refrigerators
Samsung frig is leaking water at the bottom - it does not appear to be leaking from the inside because it is dry, but from somewhere internally at the bottom. What would cause this? The temperature...
SMALL PLASTIC water pipe under front of door has joiner which changes from 8mm ? TO 10MM ? this leaked on mine and had to be replaced .any good plumbing supply shop could supply. May need to be tightned.
May 05, 2010 | Samsung RS2630AWW Side by Side...
My frig is leaking water & bottom tray is full
you need to change the filter on the bottom of the refrigerator, take off the outside cover on bottom of fridge and on the left hand side right above the tray that keeps filling up there is a round filter that unscrews. unscrew it and replace the filter. You can get the filters at Lowes or Home Depot for about 20 bucks, hope this helps.
Jul 12, 2009 | Refrigerators
Water leaking from bottom of unit
check to see if if drip pan leaking may be water line
Apr 07, 2009 | Magic Chef CTF1826AR Top Freezer...
Kenmore side by side frig with icemaker
The water smells funny and taste moldy/musty. Where is the filter to change it? I've looked inside and out and can't find it.
Jul 14, 2008 | Kenmore 53082 / 53084 Side by Side...
11 year old amana frig icemaker
you most likely have a short in the ice maker ..the ice should be ejected before the water is call for... you need a new ice make or if you can change the ice maker head let me know and I can help
Jun 27, 2008 | Amana SXD524VW Side by Side Refrigerator
Ge water filter cracks
The issue is with length of the filter and the space behind the filter allowing it to bend.
Along with many people we put a lot of things in our frig. When you jam things into your frig they can hit the filter causing it to bend towards the back of the frig. The long filter becomes a lever putting extra force on the plastic threads on the filter causing them to crack and leak.
Luckly we noticed our leak early and did not have a big leak into the floor below. But when I was removing items from the frig to get to the filter we had just bought two big gallons of milk and one was jammed into the filter.
You can try to remember to not put to much on that side, but within a month you will for get. Best thing to do until GE comes up with a better filter is to tape a wedge to the filter that fills the space between the filter and the back of the frig. That way if you jam a big gallon milk into the filter it will not bend and crack.
Jan 20, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Frigidaire FRS26R4A Side by Side Refrigerator Logo
918 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
