Intel D845HV (735858149143) Motherboard Logo
Posted on Aug 21, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Processor Upgrade and Memory query
What is the maximum processor upgrade I can go to on the D845HV Motherboard ?
I also have just added 512MB of RAM into the empty memory slot the first two contain 2 sticks of 256 MB is there any particular order they have to be installed in.
  • brickie tony Aug 21, 2008
    Many thanks
    Hi
    Regarding the processor what is the maximum I can upgrade to I'm currently using a Pentium 4 2.2 GHz
Anonymous
Level 3:
  • Master 6,487 Answers
  • Posted on Aug 21, 2008
Anonymous
Master
Level 3:
Answers
6487
Questions
6
Helped
1556552
Points
18452
This motherboard supports up to 3gig of RAM so you can go ahead and upgrade it, There's no particular order fo install the RAm just put it to the empty slot then that's ok..
Hope that helps.........
  • Anonymous Aug 21, 2008
    You're welcome feel free top contact me again if you have any further question....
Fdmdgo-03014s
For a Chaintech 9BIA motherboard;
Motherboard chipset is an Intel 845,
http://en.wikipedia.org/wiki/List_of_intel_chipsets#Pentium_4_chipsets
http://www.firingsquad.com/hw/168/Chaintech_9BIA/
PC133 (SDR Sdram at 133MegaHertz;
{Single Data Rate. The proper term, not just Sdram.
Double Data Rate Sdram is Sdram.
Double Data Rate 2 Sdram is Sdram.
Double Data Rate 3 Sdram is Sdram.
DDR Sdram, DDR2 Sdram, DDR3 Sdram.
Synchronous Dynamic Random Access Memory )
Low-Density, Unbuffered, Non-ECC, Cas Latency of 3
(Don't get some cr@p off of Ebay.
It's usually high-density, ECC, that was used by old server computers)
http://www.newegg.com/Product/Product.aspx?Item=N82E16820146305
WHEW! Unless you just want to run 1GB of ram memory, I would toss that board! (Two 512MB sticks) ->
-> Need two 1GB sticks of SDR Sdram at 133MHz
http://www.directron.com/ct128m72s4r75.html
$400 smakeroos USD!!
Bah! That is just cra-zy!
Maximum TOTAL Amount is 2GigaByte. (2GB)
Maximum Amount for EACH ram memory slot is 1GB.
IF, you only have ONE ram memory module ('Stick'), it goes in Slot 1. (DIMM 1)
That is the ram memory slot closest to the processor socket.
The Processor reads ram memory Slot 1 first.
http://www.cpu-upgrade.com/mb-Chaintech/9BIA.html
Regards,
joecoolvette
1helpful
My Wifi is not working. My laptop sound is scratchy. I want to upgrade my processor from celeron to core 2 duo which one i should select for cpu upgrade?
Two main things to know before you can attempt a Processor upgrade.
1) What Processor socket is on the motherboard?
2) What motherboard chipset is on the motherboard?
(Northbridge and Southbridge chip. Unless it's a motherboard that supports Intel Core 13, Core i5, Core i7, and Core i9 processors)
According to specifications I found online just now, the BenQ Joybook A53 comes with an,
Intel Core2 Duo T7250 processor,
http://laptops.techfresh.net/benq-joybook-a53/
Scroll down.
(Only 512MB's of DDR2 Sdram (SO-DIMM) ram memory that operates at 667Megahertz?
{ PC2-5300} Yecch! You need at LEAST 1GB of ram memory. (512MB + 512MB = 1GB.
2GB would be best)
http://www.laptop-software.com/benq/benq-joybook-a53-features-and-specifications/
Information on the Intel mobile Core2 Duo T7250 processor,
http://en.wikipedia.org/wiki/List_of_Intel_Core_2_microprocessors#Core_2_Duo_2
Scroll the page down until in the left column you see T7250. Then read across, and match the headings above.
Uses a Socket M processor socket,
http://en.wikipedia.org/wiki/Socket_M
Is your problem directed to a BenQ Joybook A53 Notebook PC, or is it another model?
2helpful
2answers
I own a compaq presario 6450nx and I would like to upgrade it. like adding more ram and replace the cpu if its posible, what could be the suggestion?
This is info on your motherboard:
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&dlc=en&cc=us&docname=bph07843
Your system comes with Intel P4 2.53 GHz processor and 512MB ram. total ram could be 1GB, bt adding another 512MD stick. You have Socket 478 and processor would be up to you. The system comes with a 200w power supply so, in an upgrade, you should up the power supply. You have an AGP expansoin slot and, you could upgrade to a graphics card but again, power supply is only 200w. The system as it stands is not Windows 7 compatible. If you incraesed your ram and got a graphics card, you would get better performance.
2helpful
2answers
I have this motherboard PACKARD BELL BV GA-T671MG. how much ram memory can it have? can i use ddr3? my pcie port supports a 2.2 graphic card?
System
System : PACKARD BELL BV ISTART F2310 AIO
Mainboard : PACKARD BELL BV GA-T671MG
Bus(es) : ISA AGP PCI PCIe USB
Multi-Processor (MP) Support : 1 Processor(s)
Multi-Processor Advanced PIC (APIC) : No
System BIOS : Phoenix Technologies, 255.255
Total Memory : 767MB
Intel Pentium D 3.00GHz
Packard Bell BV (GA-T671MG)
SiS chipset (Si671V11)
DDR2
1024mb ram
PACKARD BELL BV
Model GA-T671MG
Chipset Vendor Silicon Integrated Systems (SiS)
CPU Intel Pentium D
Cpu Socket LGA775 [Socket 775]
Processor Upgrade ZIF Socket
Max CPU Speed 3000 MHz
System Slots 2 PCI, 1 AGP
Memory Summary
Location System board or motherboard
Maximum Capacity 1024 MBytes
Memory Slots 2
Error Correction None
Use System memory
Maximum Memory Module Size 4096 MBytes
Manufacturer PACKARD BELL BV
Model GA-T671MG
CPU Intel Pentium D
Memory Summary
Memory Slots 2
Use System memory
it seems this might vary i have listed 4
hope this helps
I am having hp 530 laptop with intel core duo inside,512mb RAM,80 gb hard disk.I want to upgrade my processor,ramand hard disk. can i do it ? upto what limit ?
Unfortunately I would have to say no, you won't be able to upgrade the processor. I located a user manual at
http://h18000.www1.hp.com/products/quickspecs/12722_na/12722_na.PDF
According to specifications you can increase the Ram to 2 MB and the hard drive should be a 120GB hard driver Sata
System Memory 1024-MB 533/667-MHz DDR2 SDRAM in one slot
Two SODIMM slots; supported memory 2048 MB2
Operates at a maximum of 533-MHz with 667-MHz memory
Hard Drive 120-GB3 5400 rpm SMART SATA
The processor will be limited to what the motherboard can support and it was designed for that 1.6 Ghz processor. Unfortunately it is very difficult to upgrade processors in laptop machines. I do have to ask how old this machine is. The specification indicates MegaBytes of ram and this is actually very little Ram in today's computing world. Most machines support at least 2 gigaBytes of Ram to start with.
I have ATXmodel intelceleron1.2Ghz cpu1.2 cache 256KB Intel 810E chipset motherboard can i upgrade my processor to pentium 4 and ram to 512mb
No, u can't. ur motherboard is designed for pentium III processors with FSB -133 MHz, Socket-370 type. Pentium 4 processors have 400 MHz FSB, 423 Socket at least. But yes for memory, u can upgrade it to 512 MB.
1helpful
T2742 Desktop eMacine I want to upgrade the RAM from 256 MB to 1 GB. Can I replace the single 256 MB memory board with a single 1 GB memory board? Or, should I use two 512 MB memory boards?
Maximum Total Amount is 1GB.
EACH ram slot's Maximum Amount is 512MB.
Note* If you only install one ram memory module, make sure it goes into Slot 1.
(On the motherboard it may have DIMM 1, printed next to the slot)
Slot one is closest to the Processor. The processor reads ram memory that is in Slot 1, first.
5helpful
4answers
I have a intel 845GL motherboard with 1.7Ghz
2 x 184-pin DDR DIMM socket support up to 2 GB
recommended: 1GB x 2 DDR 333
http://www.svbinternational.com/motherboards/motherboard_845_chipset.htm
contact ur system admin/vendor for more details....
1helpful
2answers
851 MHz Celeron Processor
*********** board will support a max of 1GB of RAM. Your processor is an Intel at 1.8 GHz. The preceding is only true if your PC is the Emachines T1840 as you chose in the category listing of your post. Again if that is true, you can achieve the max RAM by installing a 512MB stick in each of the two memory slots.
Good luck.
PS: Gdlkn84as528 is correct in assuming that a less than 1.3GHz Intel processor would be a P3 or equivalent processor. So which is it, it can't be both ways?
Top Intel Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
