My computer cannot find my sat nav i have loaded the softwear but it still cannot find it . it comes up error code 28 and com1 amd 2 and usb need drivers?
  • 177 Answers
You need to update your drivers to correct this error. If your Satnav never came with setup disk go to the relevant website to download the latest drivers.
Posted on Aug 21, 2008
I have been told that I need to update the maps on my sat nav
then go to their website and get them we can not do it for you.
Jan 04, 2017 | GPS
How to fix the error and get the sat nav to update
go to tom tom website and enter your error code it will tell you or an agent will advise you.
Oct 09, 2015 | Tomtom Go Live 820 UK Sat Nav Vehicle,...
How do i update my sat nav b350
usually they come with a disc that needs to be installed on your PC, then when you connect your device you should be notified of any updates. Failing that, try going to their web page, or drop them an e-mail
Jul 16, 2014 | DURAGADGET USB Data sync computer...
Sat nav not speaking
Mercedes commans sat nav version 4.1 for E220, is saying off road, and when at home is showing on map that I am somewhere in the National Park Peak District. I have been told to remove fuse for sat nav should be no 28 but in boot of car near sat nav cassette fuses in box only go upto 20. Am I looking in the right place?
Sep 12, 2012 | 2009 Ford Focus
Hello, my wireless is not showing on my computer and when i go on device manager on my computer it has a question mark on ethernet controller and say erro code 28, how can i fix this?
Do your Wireless Device (PCI or USB unit) comes with an installation CD? If so, use the CD to install the software/drivers.(Instead of using the Windows wizard). Remove any previous installation before reinstalling with the CD.
Resit your device to a different USB port or PCI slot. If the drivers/software are properly installed, windows will detect and installed the device correctly.
Cause of the Code 28 Error (In general)
A Code 28 error is caused by a missing driver for that particular piece of hardware. There are several of reasons that a driver might not be installed for a device but your troubleshooting of the problem will be the same no matter the root cause.
Resolution
1.Restart your computer if you haven't done so already.
There is always the slim chance that the Code 28 error you're seeing in Device Manager was caused by a fluke with Device Manager or in your BIOS. If that's the case, a reboot might fix the Code 28.
2.Did you install a device or make a change in Device Manager just before you noticed the Code 28? If so, it's very possible that the change you made caused the Code 28 error.
Undo the change, restart your PC, and then check again for the Code 28 error.
Depending on the changes you made, some solutions might include:
•Remove or reconfigure the newly installed device.
•Roll back the driver to the version prior to your update.
•Use System Restore to undo recent Device Manager changes.
3.Update the drivers for the device. Installing the latest manufacturer supplied drivers for a device with the Code 28 error is the most likely solution to the problem.
Important: Make sure you install the drivers for the correct operating system. Example, if you're using Windows 7 32-bit, install the drivers designed for that specific version of Windows. Most Code 28 errors are caused by updating or install the wrong drivers for a device.
4.Update your OS to latest Windows service pack. Microsoft regularly releases service packs and other patches for their operating systems, one of which may contain a fix for the cause of the Code 28 error.
**Note: Certain service packs for Windows Vista and Windows 2000 have contained specific fixes for some instances of the Code 28 error in Device Manager.
5.Replace the hardware. As a last resort, you may need to replace the hardware that has the Code 28 error.
It's also possible that the device is not compatible with this version of Windows. You can check the Windows HCL to be sure.
Note: If you still think there is still a software/operating system component to this Code 28 error, you could try a repair install of Windows. If that doesn't work, try a clean install of Windows. Not recommend doing either of those more drastic options before you try replacing the hardware, but you may have to if you're out of other options.
Hope it helps.
Aug 22, 2010 | Microsoft Windows XP Professional
Sat nav stopped working
Jun 30, 2009 | 2005 Mercedes-Benz Mercedes Benz E320 Cdi
Problem with serial connection with AMD motherboard
Software that accesses serial ports usually allow you to specify WHICH port you want to connect via.
Your new board should have COM1 and possibly COM2... but perhaps your old setup was running from COM3?
Connect the Casio to COM1, and check the software you are using... set that to "look" at COM1 also. That should work!
Apr 20, 2009 | Casio Serial RS-232 Cable (CELL-300)
Accidentally deleted the map on my MYguide 3000
In the box you should have a backup cd for this instance, just plug the sat nav into your computer with usb and run the cd
Apr 09, 2009 | MyGuide 3000 Portable Sat Nav Car GPS...
PSP Com Sat Nav?
You have a ta-082 and can't go above 3.11
you need to downgrade to the origional firmware
http://dl.qj.net/General-IdStorage-Repair-...13178/catid/114
you will find what you need here.
Aug 02, 2008 | Sony PlayStation Portable (PSP) Console
My camera is showing an error code. How do I trouble shoot
normally this problem comes when the apparture selector ring is not sat to highest appartutr. i.e. f22 or whatever highest apparture available with the lense. just lock it there .
Nov 11, 2006 | Nikon N80 with 28-100 lens 35mm Film...
Computers & Internet Logo
41 people viewed this question
David Payne
David Payne
