Remove the bottom panel and their is a pull ring yall can release the door.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
rfbqwerty
03-28-2006, 06:22 AM
Easy
method to open a stuck Kia Rio door. Full credit to 'fastkia' for explaining
how to open a stuck lock but after opening my lock by his method I found an
easier way to do the job. You need a piece of straight wire (clothes hanger is
good) and make a 3/4 inch square bend on one end. Wind down the window &
push a tapered (plastic) wedge between the glass and the inside rubber to get a
gap to work through. Poke the wire down beside the glass and pull up on the
lever that is operated by the outside door
handle. This is not the wire from the door handle but
is the lever the wire connects to in the lock. While the lever is held up by
your hook you can now pull up the locking button. Remove the wire from the door
and everything works and it can be opened and closed as often as you like but
don't press the button or use the key
lock or it will be stuck again. The lever is normally held up by a small spring
that has a sharp bend at one end and the spring will ALWAYS break at this bend.
I used the same spring with a 'new' loop made from a section of paper clip to
replace the old loop. Better than the original. No cost and it took less than
30 minutes
