Question about Hoover U8171-900 / U8172-900 / U8173-900 / U8174-900 Savvy Bagless Upright Vacuum
Hoover Savvy self propulsion not working
I have the Hoover Savvy U8174-900. The on/off switch is acting up (hesitates) as if it is shorting out. Recently, the self-propulsion feature has stopped working. The carpet brush seems not to be turning as well.
  • Anonymous Jan 21, 2009
    I have a similar problem. Except mine will not turn on at all now. Used to, I would play with the switch and I could get it to work. Not all now.
The switch contacts are burned out and the switch must be replaced. This link sells the whole handle with switch but, check your serial number to be sure to get the right one. If you can use a Philips head screwdriver, you can do this easily.
http://buyitnow64.stores.yahoo.net/hovarepaswki2.html
Posted on Mar 19, 2009
My Hoover savvy won't turn on
Unplug from Power FIRST!
If you can find the backside ot the OFF/ON switch you can see if it is worn out or broken. Do you have a voltage tester? If so carefully expose the leads into the switch, then plug in power, and test if both sides are HOT (110volts) when switch is turned on. If so, then it may be the motor is bad. If only one side is hot then the switch is likely bad.
Take to a VAC Store to get a replacement.
Aug 13, 2014 | Hoover U8145-900 Savvy Bagless Upright...
Self propulsion doesn't work on my upright. Vacuum works fine otherwise
You will need to look @ your owners manual to see where the self propell belt is located i am sure yours is broke and need to replace,- it will not be hard to replace-Lance
Oct 21, 2009 | Hoover Vacuums
How do I install the timing belt on my Hoover Savvy Vacuum? Modle # u8174-900 Where is it located?
http://www.vacshopusa.com/hoover_savvy.htm
This is a parts schematic for your hoover savvy. You have to take off the brush guard on the bottom and also the cover on top (there is a screw under the round hoover logo). You will then see how the belt is attached. Very easy to do. Hope this helps
Jul 02, 2009 | Hoover U8171-900 / U8172-900 / U8173-900 /...
Hoover savvy will not move
the reset button is in the handle, under the cover for the switch. remove the two screws and pop apart. you need to pull up the little post under the lever switch, and push it back down. hope this works for ya.
Jul 01, 2009 | Hoover U8145-900 Savvy Bagless Upright...
Hoover savvy upright, replaced belt, but brushes will not turn
One of the common problems with the Savvy models is the upper handle switch. However if it is newer, you may also have an issue with the lower cable. To test it, turn on switch in carpet mode, and at the bottom rear, wiggle thr exposed black cable. if the roller starts and stops then it is bad and needs replacement. the cost of the part is about $10 but labor intensive to replace.
Feb 26, 2009 | Hoover Vacuums
Hoover US8174-900 Savvy Bagless
It uses a cogged belt, turn it over, remove the bottom plate, remove the other screws from the bottom, turn vac back over and remove the Hoover emblem, there is a screw there to remove and the top comes off, then you can get to and replace the belt.
May 26, 2008 | Hoover U8145-900 Savvy Bagless Upright...
Hoover savvy no suction on carpet setting
Check to make sure you hear the vac. motor is running when in that position. The switch in the handle could be bad if it is not.
Apr 29, 2008 | Hoover U8145-900 Savvy Bagless Upright...
Hoover Savvy on-off switch does not work (very intermittant)
Hi All-
I found the solution to this issue. You need to take the switch apart. Having a set of small jewelers screwdrivers from radio shack helps a lot.
First, take the switch enclosure off to expose the mechanics of the switch. There are 3 clips on either side that need to be worked free.
There are 4 springs inside the switch that push down 2 metal contacts (one other spring is used to hold the switch in position). If you expand all 4 springs (stretch them out about double there normal size) the increased pressure helps the switch make more solid contact and prevents arching which is what ruins the switch in the first place. After you stretch the 4 springs be sure to clean up the contacts on the switch chassis with a wire brush.
On the slider part of the switch there are 2 contacts which also need to be cleaned up. If you have a dremil tool use it to file a point on opposite the ends of the messed up contact. Be sure there are no burs after making the points . If there are burs the contacts will hang up and springs can't do there job. This is because there are slots the contacts need to float in on the plastic slide.
With the 4 springs stretched out it will be very difficult to put the switch back together. However, with some patients, mini needle nose pliers and jewelers screwdriver set you can be successful.
You may want take the switch circuit board off the vac before putting the switch back together (to do this remove the handle). The switch is much easier to put back together removed from the vac and on a clean well lit table. Assemble the switch in a place where you can find small parts on the floor if the contacts or springs shoot out during reassembly
This hoover savvy runs like a champ now, no more arching in the switch to destroy the contacts.
I would only attempt this if you are mechanically inclined… worst case scenario however is you break the switch and need to order the replacement though… oh yea make sure the thing is unplugged when you do the above procedure.
Dustin
Nov 24, 2007 | Hoover U8145-900 Savvy Bagless Upright...
Hoover U8171-900 / U8172-900 / U8173-900 / U8174-900 Savvy Bagless Upright Vacuum Logo
260 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
